Measure with a ruler the size of the form in inches that you are going to use .
Calculate the number of lines you have by relating it to the Line Density using the formula
Form Length = Form Size * Line Density
For example for 11 inch paper at 6 lpi = 11 * 6 = 66 Lines
You must disable the Printers Menu Lock before you can change any settings - (power on holding down SETUP)
Press SET UP button on the Control Panel.
Select the MENU Option on the Control Panel Display.
Select the NEXT Option on the Control Panel Display until PAPER is displayed.
Select the PAPER Option on the Control Panel Display by pressing the button directly beneath it.
Select the Desired Paper Path for the Form Length change - The different Paper Paths can be stepped through by using the NEXT Option on the Control Panel Display.
Select Paper Path by pressing the button directly beneath it.
Select FORMLEN by pressing the button directly beneath it.
Select LINES and then increase or decrease the value on the Control
Panel Display by using the two arrow buttons until the desired length in lines has been achieved.
Select the SET Option on the Control Panel Display by pressing the button directly beneath it.
Set the Printer back ON-LINE by pressing the ON-LINE button.
This will set the form length on the printer, see the support section of www.dascom.co.uk for more info
