Trying to use my tv as a moniter
I hooked up the pc to my tv and i don't get anything but a blue screen on the tv under VGA input. so how do i get my tv (Mitsubishi projection 1080-WS65908) to properly work as a moniter with the pc?
  • The Cactus May 11, 2010
    Hello pickee,
    I need a bit more information to help out here. What is the model of your computer, and is it a desktop or laptop? Do you only have a single VGA connector on your computer, or do you have more than one?
    As a second note, I found this note with a tiny bit of online searching:
    "There is also a VGA input for computers
    that is only compatible with 640x480 data at 60 Hertz.", fromhttp://www.laaudiofile.com/ws65908.html
    If you try setting your display to that, it may work. Let me know if you need assistance in doing that. Sadly, if it is only compatible with that resolution, I can't imagine it looking very good on your tv anyway.
    ~Cactus
  • 104 Answers
If you still have the pc monitor pluged and want to use the tv as an exetended desktop
you have to activate the second monitor in the - control panel - Display - settings
Posted on Sep 18, 2008
Hello trying to connect dell lattitude d600 to TV not getting active screen
Make sure the external port you are trying to hook up to (I am assuming it's the vga port (blue one)) is hooked up and that you have selected the pc or vga input on the tv. Then go into display properties and select to enable that monitor on you dekstop (you can extend it or mirror it you will see options) There is also a hotkey combination that does this (FN + F8)
May 16, 2011 | Computers & Internet
Hooking up TV to use as computer monitor. Snowy screen is all I get please help
Make sure your pc input is selected. Also make sure your BLUE vga inputs are connected with a vga to vga cable.
Mar 13, 2011 | Computers & Internet
How do I hook up a flat panel tv w/hdmi to a dell d630 laptop. I tried vga cable from laptop to hdmi input in tv .no sgnal
You are going to suffer from quality issues because vga is the best connection for video out the D630 has. You should be able to hook the vga up directly. this gives around 480p i think. If you don't have that input, then look for vga converter boxes.Don't forget to change the display in graphics properties so that the video actually gets sent out.
Nov 12, 2010 | Dell Latitude D630 PC Notebook
How do I hook my tv up to my acer netbook? I dont have a tv port but do have a port for a second moniter and have the cord to hook it up but it will not work...
If the TV doesn't have a VGA input, you have two options. If the TV has component video inputs (3 RCA jacks color-coded red, green and blue, not just a single video jack coded yellow), you can use a simple adapter cable. Here is an example.
If your TV only has a single yellow video input jack (called composite video) you can't use the simple cable. But you can get a VGA to video converter. This device takes the VGA signals and converts them to the form the TV can use.
Hope this helps. Thanks for using Fixya!
Mar 30, 2010 | Acer Aspire One PC Notebook
Cant use TV as Computer display
If you can disable the blue screen via the tv menu you might see something happening behind that blue ,you might be able to figure it out from there, also try to connect as directly as possible (tv/computer) even if you have to physically move one or the other, that way you can eliminate possible problems. good luck
Nov 03, 2009 | Samsung DynaFlat TX-P3064W 30" TV
Trying to hook compaq presario laptop to philips lcd digital tv
hey fox,
sounds to me like a connection problem. If the compaqs output is vga, you need to convert the input (tv side ) to hdmi, component, s-vidio... what ever you can find. Typically when you hook up your computer to a flat screen or such, its best to try to use the hdmi ports or the rpg. But if thats not available you need to take the outout from your laptop ( whatever type that might be and input it into your flat screen tv. If you input laptop into tv under ( eg..HDMI) then when you VIEW it you need to select the correct source on your flat screen. Such as hdmi or pcmi or rpg.I know that the do sell alot of cables that adapt from one type of connection to another. Typically only one cable is required from the laptop to the flat screen. If you think about it you are only using the flat screen as a monitor.
Feb 14, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Display in two monitors
There is an S-Video port and VGA for external display
but you can see display in any one of them not on two monitor
simultaneously
Apr 29, 2008 | Dell Inspiron 6400 Notebook
How to hook this monitor onto my computer
You would have got a CD with this moniter..
we ahve install that cd..
and its better to check the cables first which would be the
VGA CORD that is blue in colour which connects your moniter with the tower.
We can check the connections with the moniter for the Tower and then install the cd.
Feb 06, 2008 | Computers & Internet
Computers & Internet Logo
109 people viewed this question
David Payne
David Payne
