Whirlpool GU2400XTP Built-in Dishwasher Logo
Posted on Sep 24, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Normal light flashes, unable to operate - Whirlpool GU2400XTP Built-in Dishwasher
Anonymous
Level 3:
  • Master 2,341 Answers
  • Posted on Sep 24, 2011
Anonymous
Master
Level 3:
Answers
2341
Questions
Helped
636197
Points
7414
Hello.
The reason the ligh keeps blinking is because it is displaying a error code. How many times in a row does the light flash before it pauses and blinks again?? the number of times it blinks in a row is the number of the error code its displaying...example if it blinks 7 times in a row before a brief pause its is displaying the E7 code and so on.
This tip i wrote will tell ya how to reset the control board but be sure to reply with the amount of times it blinks and i will let ya know whats its telling ya.
Here is that tip to reset it http://www1.fixya.com/support/r10357661-get_whirlpool_dishwasher_start_when
GENE
  • Anonymous Oct 22, 2011
    normal wash and cancel /drain just keep blinking continuously
Start/pause light flashing green on Indesit washing machine but none operational
Try cutting the power again for 10 minutes. If it doesn't fix it, you will need a service call.
My portable unit just flash's red when turned on
http://www.ehomeservices.com.sg/articles/how-to-solve-air-conditioner-light-blinking-problem.html
If you see the red flashing light during regular operation, this usually means that the outdoor unit was shut off due to a problem and is currently "locked out" from normal operation. When you see the red flashing light, it is usually in a diagnostic feature to alert the HVAC repair technician to what the problem is.
https://www.onehourheatandair.com/bay-area/about-us/blog/2016/may/what-does-a-thermostat-red-blinking-light-mean-/
I have a delta touch faucet and the blue led light stopped working. The red is still lighting and the touch feature is working properly. How can I fix the blue led light?
  • Solid Blue - Normal operation, "Touch" mode is activated.
  • Flashing Blue - Normal operation, the hands-free mode is activated.
  • Solid Red - Warning mode - Replace batteries as soon as possible. While the water is running Solid Red LED is illuminated. When the water is off, the Red LED flashes once every 5 seconds. The faucet operates normally, solenoid valve is open.
  • Rapid Flash Red - Alert Mode - Battery Failure Imminent. The Red LED flashes once a second. The first time the faucet is used, the Red LED will turn ON, the solenoid valve will be opened and remain open. The manual valve must be used until the batteries are replaced.
  • Solid Red - Lockdown Mode - Replace Batteries. Extremely Low Batteries - The RED LED is ON, and water will not flow. The solenoid valve is closed and faucet will not operate until batteries are replaced.
  • Long Flash Red (2 seconds on / 2 seconds off) - Board error, replace electronics kit, RP53230 See manual bypass of electronics section of Installation instructions.
Cycle selector on normal mode. cannot operate water tempertures orsoil level light indicators on a infinityfaf
Ron kundrat,
So I understand that you are unable to operate the water temperatures and soil levels on your infinity washer, while on the normal cycle.
I suggest to give your appliance a hard reset. You will do this by either unplugging it or cutting the power off at the circuit breaker for 3-5 minutes. After the 3-5 minutes, bring power back and try to start a cycle.
If you are unable to change the water temperature and soil level settings, while in the normal cycle, I suggest to contact your local authorized technician. They will be be able to come out and diagnose the washer and see why you are unable to change the settings.
-Best Regards-
1helpful
2answers
HP Laserjet 1022 orange light keeps flashing
1. Check any paper jams in side.
2. Check cartridge.
3. Remove back cover, clean paper sensors.
4. Replace Formatter board.
1helpful
Timer light flashes twice on my asta09lcc but it wont work
If operation light is normal and timer light flashes twice, the error is:
Serial signal (reverse) error, at operation start up
Most likely a faulty outdoor controller PCB. Around $250 for new board plus labour.
I have twice been unable to start my Vespa. On each occasion the code light was not flashing. I turn the ignition and nothing happens although battery is properly charged. After some time it started...
something wrong with the (coded) key - it has to be reprogrammed
(probably it got exposed to a magnetic field)
the brown is the master key & the blue the normal onel
twice-unable-start-vespa-wq3avpzkaaw4sd2xavwlekgs-3-0.jpg Vespa Vector
Jan 18, 2011 • Motorcycles
1helpful
My nokia n70 bluetooth is telling me unable to perfome bluetooth operation what is solution
Hi, Most Nokia phone all have similar problem about blue tooth operation failing.
What prompt "Operation failed" is when there an application on your phone , and an application your transferred through blue tooth or any other means has contacted Virus and it's affecting the blue tooth operation.
Solutions to this problem is to restore the blue tooth device back to normal by flashing the phone.
Flashing of phone restore back the lost or corrupted data on phones.To flash a phone, you will need to purchase a device used for flashing of phones. But to save you the cost of purchasing a flashing machine, i would advice you go to the nearest phone repair store around you for assistance. Skill personnel.
Thanks for using fixya..................
3helpful
Epson c46 printer
If both lights are flashing, it means the Waste Ink Pads in your printer are saturated with ink and the waste ink ("protection") counter has exceeded its limit. The Waste Ink Pads should be replaced as soon as possible. You can overcome this problem temporarily by using the SSC utility - download from
http://www.ssclg.com/epsone.shtml
and reset the Protection Counter. This will stop the lights flashing and restore normal operation.
However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer. A copy of the service manual is available from a number of sellers - just Google "Epson C46 Service Manual". You will often find them for sale very cheaply on E-Bay.
If you decide to have a go at replacing the ink pads yourself, report back and I will provide further help.
Top Whirlpool Dishwashers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
