Question about Compaq (169174-002) - (Refurbished) ( 169174-002 ) Processor Board
Constantly running My computer is constantly running, How do i get it to run quietly? It has previously ran quietly and now it is being loud again.
  • 104 Answers
If it's a the cooling fan making noise try to clean it
If it,s the hard drive it's not much you can do
Posted on Sep 18, 2008
    Problem Solver:
  • 12 Answers
Hello KOKOBEAR,
Is your computer more than a couple years old? If so, then the internal components, like the fans and heatsink may be dusty. When those parts get really thick dusty, the fans are not as efficient, and have to run harder to keep the computer cool.
If you're comfortable opening your case, you can take a look and see if there's a lot of dust. You may want to have an experienced friend or technician do the cleanup, as you may need to take off a part or two to do the really deep cleaning.
Tappets are constantly loud when driving 1993 BMW 318i
How is the oil level in the engine? Have you actually checked that? Also, what kind of oil (and what weight) are you running in the engine, and how many miles are on the car? You may be running oil that is too thin for the amount of wear on the engine parts! oil leaks cause low oil levels!
Apr 18, 2017 | Cars & Trucks
Onga water pump not pumping water thru to house
either water lock or motor burnt out ,
Mar 17, 2012 | Plumbing
Rainbow motor makes loud noise
Depending on the age of the Rainbow, it could be the bearings. Does the noise happen with just the Rainbow or from the power nozzle?
RainVac
www.rainvac.com
800-523-0510
Mar 10, 2012 | Rainbow E series Canister Wet/Dry Vacuum
Minute timer is not loud enough. It was but now volume low.
Set the timer to 1 minute and then press the minus button to zero it.
This makes the timer 'beep'.
If it is quiet, press the minus button again and the volume of the beep will alter, running through 3 settings - loud, medium and quiet.
Jun 04, 2011 | Rangemaster 90D Range
My HP Pavilion a820n pc desktop fan runs constantly. I don't think it always ran this much. Previously ran then shut off then ran. We vacuumed the visible dust. Does this signal a problem? Thank you. ...
Fan is inteligent, has sensor when cooldown is reached auto slow down to fix needs to be replaced,will not hurt anything system running cooler is always a good thing i would run it till it dies unless noise is an issue
Jan 20, 2011 | HP Pavilion A820n (PP165AA) PC Desktop
I just got my Vaio PCG-K33 operational once again by installing a replacement LCD screen. Now I realize why I was not in a rush to return this laptop to running condition. The cooling fan runs constantly...
This over heating issue is a common issue for this model of VAIO Computer. You will get a free service or replacement of parts(Battery) from the Sony Service Center. For more information please follow the link below.
VAIO Battery Replacement program
Hope this will help you. All the best.
Sep 17, 2010 | Sony VAIO PCG-K33 Notebook
Desktop computer fan runs constantly
Desktop fans do run constantly, you cannot avoid this.
The reason they get loud is because there will be a build up of dust on the fan blades.
To rectify this problem turn off the computer and remove the power cord from the rear. Then you need to remove the side panel from the base unit to expose the motherboard.
You will see that inside the case it is full of dust. Look at the CPU fan (the fan on the motherboard) also take notice of any case fans too, they are at the back.
To clean the fans and the case you can use a clean dry paintbrush or compressed air.
Once the inside of the case is cleaned you will see a noticeable drop in noise.
Regards.
Jul 03, 2010 | HP Compaq Presario SR2150NX PC Desktop
Constant loud noise when frig turns on/comes from bottom
when the compressor is running unplug the ref. and if you hear the noise coming from the compressor then
a ballance spring may be broken inside the compressor.
The compressor will run normally with a broken spring it will just be annoying when it shuts down.
Jan 16, 2010 | Roper RT21AKXKQ Top Freezer Refrigerator
One day i ran out of gas i filled the tank it ran fine a couple days later i changed the oil again it ran fine, im getting ogg the freeway one night come to a light and it stalls i start it back up but it...
Best guess I can make with the limited info is check the fuel cap vent. If it runs fine with the cap off or open you found the problem.
Engines that are running very lean (not getting enough fuel) can sound terrible, Frank
Aug 27, 2017 | 2007 Gas Gas MC 250
Compaq (169174-002) - (Refurbished) ( 169174-002 ) Processor Board Logo
70 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
