Question about Logitech VX Revolution 931690-0403 Mouse
Mouse doesn't follow
I've bought the VX revolution and it worked fine for one hour then it didn't want to follow as smoothly as before. Next time I used it it worked for approx. one hour again and then it stopped.. First I thought it was the suface so I tried a bunch of different surfaces but it still didn't work. After experimenting with it from time to time I realised that it works if I lift the front up about 1-2millimeters... Now I have a piece of paper under the front of the mouse to make it work. Why is it so?
    Brigadier General:
  • 6,966 Answers
I would venture that for some reason, the LED light at the bottom needs that much space to bounce back the signal for the LDR (light dependent resistor) to read properly. This could be due to a slight misalignment, dust in the bottom optics, weak battery (for wireless). A temporary workaround (which for some works as good enough solution) is to add a smooth spacer atop the rubber feet. Personally, I use a paper puncher to cut little circles on a slightly thick automotive sticker. The circles are then peeled of from the protective paper backing and attached to the existing/original rubber feet. This raises the bottom height which do improve light bounce and therefore mouse action.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Sep 18, 2008
Mouse won't function at all
Buy a new one and see if that cures the problem.
Jun 05, 2017 | Dynex Computers & Internet
HI vx revolution mouse repair
no sorry, once the little pins and rollers inside have broken their isn't any way. I'm really sorry.
Dec 25, 2009 | Logitech VX Revolution 931690-0403 Mouse
My VX revolution is missing too much left clicks. Sometimes I need to click 5 times to get 1 click. All the others buttons are working fine. How I can fix this? thks
Seems that the left mouse button needs to be replaced. If you have an old mouse, you can use it as a source of a spare mouse button, & replace the defective button on your VX Revolution.
However, you need to make sure that:
1. The replacement button is identical to the defective one.
2. You have enough skills to solder/desolder electronic components.
Oct 25, 2009 | Logitech Cordless Click! Mouse
Wrong Receiver for Logitech Vx Revolution Mouse
logitech has connection software on their site you need to run
Jul 07, 2009 | Logitech VX Revolution 931690-0403 Mouse
Usb connector not working
Have you tryed a differant usb port? If the usb port does work at least some times it is more than likely a regestry problem. try this and see if it works. click "start" then "run" type in "regedit" "ok" click the + next to "Hkey_Local_Mechine" + next to "System" + next to "CurrentContro;Set" + next to "Control" + next to"Class" then click on "{4D36E965-E325-11CE-BFC1-08002BE10318} in the right field, right click on "Upper Filters" click delete, then right click on "Lower Filters" click delete, restart PC. if this doesn't work the yes get a usb card to install. GL hope this helps you.
Jun 20, 2009 | Logitech MX1000 Laser Cordless...
Unresponsive left mouse click
I have that issue too. At the beginning I tought it was a connectivity problem but it does it even with the receiver side by side. Latelly it is working perfectly.
Jun 10, 2009 | Logitech VX Revolution 931690-0403 Mouse
Mouse wheel is inverted
if you are using Windows go into conrol panel and click on mouse. it will show you the options to change the buttons..
pls rate this solution
Mar 01, 2009 | Logitech Wireless VX Revolution Laser ...
Vx problem:movement
First try this
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it. This should connect the mouse to the receiver and work properly. If not, try pressing the receiver button and then press the button on the mouse. This should be done whenever you change batteries or glitch.
If that doesn't do it theen try this.
Normal 0 Disconnecting the Mouse Receiver from the USB port and reinstall the CD software program. When the program asks you to connect the Mouse Receiver to the USB port, do so and it should work.
Hope this helps. Bud
Dec 30, 2008 | Logitech VX Revolution 931690-0403 Mouse
VX Revolution Cordless Mouse for Notebooks dead as a door nail...
I see no reason that the mouse should not work. They have the Xop driver and the install software. Download both and also read henote that they are talking about in. red. I didn not download it myself. If this doesn't work you can get a common PS 2 mouse for a small amount  most anywhere including Walmart.
http://www.logitech.com/index.cfm/428/165&cl=us,en?softwareid=4338&osid=1
Dec 30, 2008 | Logitech Cordless Mouse
Logitech VX Revolution 931690-0403 Mouse Logo
182 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
