Lg rear progetor tv model pf-43a20 no red how to repair
LG WASHER/DRYER COMBO PF Issues
pf is power failure,, need to replace main board... there should be a parts/repair manual inside unit.. usually bottom panel...
Aug 15, 2016 | LG Washing Machines
I Have 50inch Sony Bravia progetor tv and I have a yellowish colour in the middle of the screen
One of the color projectors CRT's is burnt out or is malfunctioning, the cost to repair this is very expensive, in the $500 range. With the new Flat panel LCDs now at rock bottom prices (saw a 42" at Best Buy for $499) I would really suggest you scape the old technology instead of repairing it, it will likely develop another problem within a year or so.
Feb 12, 2012 | Sony Televison & Video
My lg rear projection tv stopd working at onece and there is no light in the indicators .its model no is mw-60sz12. can it happn becouse of lamp
1. Unplug the cord & check if there is power at the
outlet.
2. Check for a busted fuse/or tripped off circuit
breaker at the main power panel pf your house.
3. Check for the busted fuse inside the case of your
projection TV. This is just near where your power
cable of your TV is connected.
4. When you are done, plug back your cord to the
power outlet, and put the power on.
This should correct your problem. Send us your email and keep us informed.
Sep 27, 2009 | Televison & Video
LG rear projection tv. sound but no picture.
Go to a repair centre, some parts must be fixed/replaced.
Jul 22, 2009 | LG RU-52SZ30 52" Rear Projection...
Need instructions on installing a lg w1941s monitor
Just connect the TV to your computer using S video / HDMI or VGA cable. Also your display card should support the same. You will see the TV listed there
Jul 03, 2009 | LG W1941S-PF Monitor
How do i realine the bulb in my samsung rear projection tv
use you're remote to enter code mute 183 while tv is on then press 7 for red 8 for green and 9 for blue control. arrows or knobbie will move cursor. if you still can not control the red you will need to change the red convergence ic...press perfect focus to save changes if pf is not on remote maybe on tv if neither you will need to get a remote that has it to save info.
Jan 27, 2009 | Samsung HCM4215W 42" Rear Projection...
Red screen on LG 44-inch DLP
Go to this site, follow the instructions, and it might fix your problems. I did, and my tv is better than ever!
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Mar 28, 2008 | LG RU-44SZ51D 44" Rear Projection...
LG Rear Projection TV - Model RT39NZ40RB
i repairs projection plasma and lcd tv's u can call me at 9811440932 (yogesh saini) only for delhi
Mar 23, 2008 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
