Question about Intel D101GGC Motherboard
Memory Upgrade I have Intel D101GGC motherboard, 256 MB RAM with Intel Pentium D Processor. Now I want to upgrade RAM to 1 GB. But I don't know which type of RAM is compatible with my motherboard. Is it DDR1 or DDR2 ? And while buying the RAM what should I ask for? I am also confused with PC3200 and some similar terms. Please specify which RAM to buy and what it costs approximately?
I have d101ggc board i put 2 Rams 512, 512 but os shows RAM just 488 in figure ??? i have changed my OS also i have check it in bios theres also shows 2 RAMs 512,512, any solution here?
Posted on Feb 19, 2009
  • 52 Answers
  • 4 Answers
Install this software sisoftware sandra this will give u detail info about ur hardware even i have the same mobo  its a sad thing that we need to go for a ddr 1 with ram speed of not more then 400mhz im using 2 ram of 1gb each sadly the slots r all full
Posted on Sep 25, 2008
    Sergeant:
  • 399 Answers
Ask for ddr1 ram of 1 gb.also take your old ram which is at present in your pc to match the locks with the new ram.
it will cost u near to 50$.
thanks.
Posted on Sep 18, 2008
I have intel 101 Ggc Mother board and intel pentium D processor , i was using 756MB ram (512+ 256MB) RAM. But after i brought 1 GB ram and Used it instead of 256 MB Ram the system started restarting...
There is a chance that you have faulty RAM module. If computer is stable on POST (until Windows boot-up) I would suggest to use some testing tools to test that RAM with your motherboard. There is a good program called MemTest. You can find it online if you search Hirens Boot CD. Download it, burn image to disk, put 1GB RAM into motherboard, start-up PC and boot from CD. Then you'll search for Memtest program. I would suggest to leave PC for at least 6 hours for testing to find out if it's faulty or not (better to leave for 24 hours).
Aug 17, 2011 | Intel D101GGC Motherboard
T2742 Desktop eMacine I want to upgrade the RAM from 256 MB to 1 GB. Can I replace the single 256 MB memory board with a single 1 GB memory board? Or, should I use two 512 MB memory boards?
Maximum Total Amount is 1GB.
EACH ram slot's Maximum Amount is 512MB.
Note* If you only install one ram memory module, make sure it goes into Slot 1.
(On the motherboard it may have DIMM 1, printed next to the slot)
Slot one is closest to the Processor. The processor reads ram memory that is in Slot 1, first.
Apr 16, 2010 | E-Machines T2742 PC Desktop
I want to upgrade my cpu, but dont know how to go about it.
it is not complicated for upgrade the desktop.as per my knowledge ur system configuration is-
Key Features
Form Factor Mini Tower
Processor Intel Pentium 4 1.6 GHz
Installed Memory 256 MB (SDRAM)
Operating System Microsoft Windows XP Home Edition
Recommended Use Business
ur system processor and memory both will be upgrade.
Memory-
RAM Technology SDRAM
Installed RAM -256 MB
Max Supported RAM 3 GB
Installed Video Memory 32 MB
Processor-
Processor Type Intel Pentium 4
Processor Speed 1.6 GHz
Processor Manufacturer Intel
Processor Upgradability Upgradable
Audio / Video-
Audio Output Type Sound Card
Max. Video Resolution 1920 x 1440
Hard Drive-
Hard Drive Capacity 40 GB
Hard Drive Interface DMA/ATA-100 (Ultra)
Thanks,
Nov 30, 2009 | Acer Veriton 7200 PC Desktop
851 MHz Celeron Processor
*********** board will support a max of 1GB of RAM. Your processor is an Intel at 1.8 GHz. The preceding is only true if your PC is the Emachines T1840 as you chose in the category listing of your post. Again if that is true, you can achieve the max RAM by installing a 512MB stick in each of the two memory slots.
Good luck.
PS: Gdlkn84as528 is correct in assuming that a less than 1.3GHz Intel processor would be a P3 or equivalent processor. So which is it, it can't be both ways?
Sep 18, 2009 | E-Machines -T1840-CELERON-1.8GHz,40GB...
UpGrade
download cpuz it will tell your specs
Oct 18, 2008 | E-Machines eMachines Desktop PC
UpGrade
you could only upgrade the processor and RAM in this condition i.e.
you can only change your an upgraded p-III processor like 1.0 GHz, 1.1 GHz or 1.3GHz and
upgrade the RAM by changing to 256 in each slot.
that is all what u can do with ur pc
Oct 18, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
UPGRADE
U have to find the motherbord's manual !!!! U will find there all u need. But most probably u won;t be able to put those processors (the speed diferences are too big, even if they are of the same slot type)
Jan 14, 2008 | Soltek SL-65KV2-T Motherboard
Intel D101GGC Motherboard Logo
189 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
