Question about HP LaserJet 2300 Printer
Hp 2300dtn Poor quality printing
My Hp2300dtn printing the page with half faded. Left hand side of the page prints fine but right hand side of the portrait page is faded. Tried everything on troubleshooting including replacing new catridge but no lack. Any advice for this problem?
  • Steven Brown May 11, 2010
    Luck is a pagan lucifarian term , the correct term is ( divine providance )
    Some Advice
    Get a new printer !
    Reasons listed below
    1. cost of repair more expensive than a new printer
    2. your printer is very outdated in printer terms
    The industry can't seem to make up it's mind about printers.
    The best you can do is Epson C82 or better if you wish to be able to do all the things
    a printer can do , like make T-shirts
    if you just need a photo printer the Canon series is not bad
    it's all up to you ...
    Thank you for choosing FixYa!
    Az.
  • 138 Answers
Well lets start with DISREGARD ALL THE ABOVE BULL in the above brainless clarification request first noted. Here's a little good advice for you from a 14 year veteran printer tech.
Lets start with the cheapest and easiest moving to the more difficult or more expensive. Your problem can be caused by a few differnt things.
Print a configuration page (on the printer menu press check button, scroll to info menu, press check, scroll to print configuration, press check. Once you have the look for the page count on the page.
Try fresh good paper from a sealed ****. If your paper has picked up moisture this will show up as light or uneven print.
Next if the printer is over 100K page count, replace the transfer roller (foam roller inside printer under the toner cartridge). Lets try cleaning it first if your under 100K or to see if it improves at all. Any improvement will verify the transfer roller as bad. Review the photo below as it shows the transfer roller end inside the printer. The screwdriver is showing where the release white clips are (two). Press the tabs and lift the left side. The right will come out of the hole socket on its own but note where the hole on the right is for replacement. Try not handling the roller with your bare hands any more than you must as oil from your hands can cause slight imaging defects if your hands are sweaty or damp.
Using a clean rag (like t-shirt material) dampened (not soaking) with 99% alcohol (not 70%) lets clean the roller. Gently but firmly scrub the talc and paper dust buil-up from the roller. Once you've removed the build up it should return to a dark grey color. Let the 99% alcohol dry (5 minutes or so)and reinstall.
Try printing again. If the problem is solved your done. If not and it has improved, you will need a new transfer roller. They are available on Ebay much cheaper than from a dealer. The part number to search for is RM1-0343. Here's a link to ebay for one at around $20.00 landed.
http://cgi.ebay.com/LJ-2300-Transfer-Roller-New-OEM-RM1-0343-Unopened_W0QQitemZ270247145853QQcmdZViewItem?_trksid=p3286.m20.l1116
If the problem is the same, your problem is more than likely a dirty laser scanner lense. You'll need to remove the covers from the printer to accomplish this. The laser scanner can be located under the top cover. It's the larger black box on the top side of the printer. Once the scanner has been located, remove the top cover. DO NOT TOUCH THE MULTI SIDED SPINNING MIRROR TO THE REAR OF THE SCANNER. You will be cleaning the clear lenses and mirror towards the front. You clean this gently with a CLEAN and DRY Q-tip. Use a few Q-tips rather than re-applying a dirty one. Heck they are cheap!
Re-assemble the printer and try printing again. One of the steps above should resolve your issue. I am enclosing a link to a free service manual for your printer to help you through the disassembly and in the rare case that your issue remains.
http://www.feedroller.com/Store/Service%20Manual/LASERJET%202300%20Service%20Manual.pdf
Hope this helps you a lot more than the first response you receved. If so rate me with a FIXYA!
Thanks.
Posted on Oct 02, 2008
Print quality: dark faded, but continuous
Open top cover and remove toner, shake toner cartridge and try a test print. IF image good then problem is low toner level in cartridge.
Apr 01, 2010 | HP LaserJet 4 plus Printer
Right hand side page print quality very poor, almost unreadable
this is cause of the lens is dirty with toner droping..
open the front cover and on the right side, there is a level for you to pull out.. at the right side of the printer, open the small cover and you will be able to find a cleaner. To clean..pull out the holder few times.. by applying slight pressure..that will clean the bottom lens..and u should be able to print out fine now..
Feb 26, 2010 | Epson Aculaser C1100 Printer
My Hp 3600 print output is poor on the right side
plz check ur drum & change it, bcoz i have same printer,
I also phase same issue, so i change my drum & pcr rod, now its working fine
Nov 13, 2009 | HP dx2250 Monitor Personal computer AMD...
Hp 2600n faded printing
you need to take the scanner out (not very easy to do)unless you are a printer tech.
and clean the mirrors.
Sep 14, 2009 | HP Color LaserJet 2600n Printer
Poor, faded print quality on left and right sides of paper
Have you check the teflon at the heater? have you clean the reflector of laser? Try that.
May 30, 2009 | HP LaserJet 8550 Printer
Print fades out from right side of page
Check out this website it will assist you with all the known printing problems out there,
This could be anything from a transfer roller to a defective ink cartridge. However the above link is for troubleshooting print quality problems with your printer
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=239135&prodTypeId=18972&prodSeriesId=239135&objectID=bpl12234
May 27, 2009 | HP LaserJet 1500L Printer
Page is printed but fade
The toner cartridge is faulty. It is possible that when you pulled out the strip that the whole thing didn't come out. Return the cartridge (with a couple of printed sheets to demonstrate printing) and the receipt and you should get a replacement.
Oct 24, 2008 | HP Color LaserJet 2600n Printer
New problem with hp 3380
hiii...
change the fixing unit....film inside fuser.....
Sep 15, 2008 | HP LaserJet 3380 All-In-One Printer
Poor print quality - top half page okay, bottom print faded and skips top half page okay, bottom print faded and skips problem Just installed a new cartridge
check the wright cartridge model you installed and well pluged to the printer
if it is ok
try to change printer properties and fix it correct options with there tabs ( ex: paper, print quality etc)
all are well try to reinstall the printer driver
Jul 16, 2008 | HP PSC 1210 All-In-One InkJet Printer
HP LaserJet 2300 Printer Logo
681 people viewed this question
Seeker5211
Seeker5211
