Question about Water Heaters
Honeywell heating controls
The room unit (T8617) of my Honeywell Smartfit control system suddenly will only display and control the water heating system not the central heating system. Is the defect likely to be in the room unit or the base unit and is there acure, please?
  • johngrainger Sep 27, 2008
    The room unit (T8617) of my Honeywell Smartfit control system displays both the water heating system and the central heating system but the heating will not work. Is the defect likely to be in the room unit or the base unit and is there acure, please?
  • lbmbfe Mar 04, 2009
    I keep getting F5 and a spanner displayed on my honeywall smartfit T8617 UNIT AND NOTHING WORKS. The heating is trying to come on but just stops
5 Suggested Answers
  • 171 Answers
SOURCE: Honeywell wall thermostat
Hi,Richmart
I'm Harvey the Plumber,
First, Your question is if your thermostat is wired correctly!
Assuming that it is correct, a common problem that most people and plumbers overlook is correctly setting the heat anticipater on the thermostat.
Assuming that you have a gas central heating system, then you must simply look on the gas valve for the amp rating.
For instance,if the gas valve printing says .4 amps then set the heat anticipater for .4
It's common for the unit to turn on and off erratically (short cycling) when this setting is not correct.
If all you are worryied about is the wiring, you must look at the wireing diagram that came with the thermostat.
Further diagnoses would requie detailed information about your central heating system.
Or the alternative would be to have a hands on tech help you out.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey
Posted on Sep 09, 2008
Da Brain
  • 11 Answers
SOURCE: Wiring a Drayton Room Stat into central heating system
9 TIMES OUT OF 10 THE COLORS ARE THE SAME. MATCH THEM UP. FIRST LABEL THE WIRES ON THE ORIGINAL STAT, AND PUT THEM IN THE CORRESPONDING PLACE ON NEW ONE.
Posted on Oct 27, 2008
  • 68 Answers
SOURCE: replacement of heating programmer
yea you should be able to just when you remove the old one mark witch wire went to witch connection by marking it some how i personaly take one wire at a time wrap it with a small piece of white tape and write the letters on the piece of tape then when i replace with the new one i cant mess it up also look for any of the wire connections to see if any have to be or have been jumped out
Posted on Dec 14, 2008
  • 5 Answers
SOURCE: Honeywell T403A1174 suddenly doesn't appear to call for heat
some times inside the boiler on the internal pipework you will see little sensors, on the central heating piping there sometimes is a thermastic sensor on side of flow pipe with a little reset button on ? i guess with the problem you said the poiler locked out and the pipe work overheated ? this is a safety feature on some boilers not, all and easerly reset via this button ?
Posted on Feb 05, 2009
  • 54 Answers
SOURCE: Central heating on all the time!
The zone valve needs replacing.
Posted on Sep 26, 2009
How to adjust thermostat
How to Adjust Honeywell T6360b1028 Thermostat? ' DIYnot Forums
www.diynot.com > Forums > How to... > Plumbing and Central Heating
Unless the thermostat is faulty, the point where your 'stat clicks is your actual roomtemperature. If your 'stat doesn't 'call for heat' when set to 18 and your room ...
Nov 01, 2015 | Honeywell T6360b1028 Room Thermostat
Honeywell ct87n wiring schematic
These are color codes wires for terminals that control fan relay,start,stop, temp-up/down ect. Also you can trace out those wires, Where they are going and what terminal on the wiring schematic they control.
Jun 27, 2014 | Honeywell Ct87n "the Round" Heat/cool...
T6360 dial not working
Turn system off then back on and see if it is working. The manual can be obtained at:
http://historical-products.ecc.emea.honeywell.com/2008_1/pdf/en0r8281uk07r1204.pdf
There is not enough information to give you any more help. What does "Dial not working indicate", the Honeywell T6360b1028 is a heating and cooling thermostat with the potential of having a heat anticipator.
Mar 16, 2014 | Honeywell T6360b1028 Room Thermostat
Honeywell t6360
Gas valve faultdetected
Copy following link to troubleshoot by type of gas control valve, and read how to replace gas control:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
There are basically two types of Honeywell gas control valves.
One for atmospheric-vented water heater, and one for power-vented
For both types of controls: 8 flash + 3 flash error: replace gas control valve.
Water heater does not need to be drained to replace this gas control.
Apr 01, 2013 | Honeywell Water Heaters
Pr sw failed to close
Troubleshoot by type of gas control valve
Repeated 3 flash on power vented honeywell gas control thermostat means system in lockout.
Repeated 3 flash on atmospheric-vent Honeywell gas control valve means temperature sensor failure.
Take apart gas control, and buy temperature sensor if sold separately at AO Smith dealer.
http://waterheatertimer.org/How-to-replace-Honeywell-gas-control-valve.html
Add a comment with more information
Mar 23, 2013 | Rheem 40 Gallon FVR NATGAS Low WATER...
Light stays on
Question posted under Honeywell thermostat.
If you have honeywell thermostat, then model number is located on back of device.
Google that model number in following format: Honeywell xxxxx4 .pdf
That will give you on-line pdf manual that is downloadable and searchable.
Then re-post question with exact model number and include what you are operating so expert can access and read manual alongside you.
If you have some other device, then post the brand and model number, and include what voltage, and what you are controlling for best possible solution.
If you have a timer or a switch, it is possible that more information is available on following links:
http://waterheatertimer.org/How-to-wire-switches.html
http://waterheatertimer.org/How-to-wire-timers.html
Aug 27, 2012 | Honeywell T6360b1028 Room Thermostat
I have an A. O. Smith Model FPSH 40-261 hot water heater. It won't heat water. there is a green light on the control flashing. What does it mean?
AO Smith uses the Honeywell ICON gas valve with green indicator light.
Some models use White Rodgers Intellivent with a row of indicator lights.
The gas control blinks the error code:
Open following links to identify gas control thermostat and read possible error codes:
http://waterheatertimer.org/pdf/Honeywell-Gas-Valve-LED-Codes-2000.pdf
http://waterheatertimer.org/BW.html#Temp
http://waterheatertimer.org/How-to-adjust-water-heater-temperature.html#intelli
Jul 18, 2011 | Water Heaters
Jan 31, 2009 | Honeywell Water Heaters
Water Heaters Logo
426 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
