Question about HP Pavilion dv2000t Notebook
Battery I would like to know whether it is advisable to plug the laptop into power while the laptop is being used...does it affect the laptop battery? and also my laptop shuts down smetimes while i am using just goes off...can you explain why it happens?
  • 441 Answers
Yes Its okay, if your laptop shutdown by itself when you use the battery, it may be because the battery is not charge enough or it may not be working properly
Posted on Sep 18, 2008
My acer wont start up
Acer laptops allow you to take your work and entertainment on the go.
You can work on a presentation during a long flight or watch a DVD in the middle of a park.
Acer laptops can do this because they are powered by batteries, allowing the laptop to run without having to be plugged into a power source.
Normally, the battery can be recharged by plugging the laptop back into a power socket.
But certain problems can keep the battery from charging.
Electrical Connection
For laptops to charge, they need to be connected to a power source.
Although it may look like you have the cable plugged in correctly on the Acer, make sure that the cord is firmly plugged into the power socket.
There should be a light on the Acer keyboard as well as a power symbol on the taskbar for your operating system that tells you whether the laptop is running off electrical or battery power.
If it is plugged in, make sure that this icon shows that it is on electrical power.
Also check the socket where the Acer is plugged in and make sure that it isn't turned off at the main circuit breaker.
Turn the Acer over and make sure that the battery is properly placed in the battery compartment. Most laptops will have locks that keep the battery securely in place.
These locks can sometimes come loose.
Use a piece of strong tape as a temporary measure to keep a loose battery in place.
Clean the terminals on the battery to ensure that there is a good connection.
Remove the battery from the battery compartment.
Apply rubbing alcohol to a lint-free cloth. Rub this cloth over the shiny metal terminals on the battery.
Over time, batteries lose their ability to be recharged.
If neither of the aforementioned steps works, you may just have a bad battery.
Check with Acer or other vendors to find a replacement for your model.
BIOS Update
The BIOS (Basic Input Output System) controls a number of basic functions for a computer, such as assigning the hard drives and other system functions.
The BIOS also controls the battery charging function.
Certain Acer models have a bad BIOS that operates the computer normally but doesn't charge the battery.
To solve this problem, you need to perform an operation called Flashing the BIOS where you download a new version of the BIOS and upload it to your Acer.
Check on the Acer support site to see whether your computer model could possibly be affected by this.
The power adapter, the part that plugs into the Acer from the power socket, can go bad.
Check for a power light on the adapter.
If the light is not lit, you probably have a bad adapter.
Replacement adapters can be purchased from Acer or other online vendors.
Mar 16, 2014 | Acer Extensa 5635Z Drivers Recovery...
Laptop Won't Boot
You'll need to troubleshoot your laptop in order to know what the exact problem is. First try to plug it in with the battery on and try turning the laptop on. Next would be to remove the battery and plug the computer. If this doesn't work then it's definitely the AC Adapter and you'll probably need to call toshiba to purchase a new one from them or if you're still under warranty then have it replaced. They also have some qualifiers on whether an AC adapter or battery is qualified for replacement even if it's under warranty. Just call them on 1-800-457-7777 and ask their technical support reps about this.
Sep 17, 2008 | Toshiba Satellite A105 Notebook
How to Maintain and Extend the Life of Laptop Batteries
Laptop battery is one important component that must be considered in use. Many laptop users admitted the batteries drop and not durable when the laptop is still fairly young age.
How to treat the batteries to make it more durable and can be used much longer? Learn some tips that are mixed following.
Set the battery power
In Windows there is such thing features power options. Through this feature you can adjust the power consumption of a laptop. The trick is very easy. Click the Start button, then open Control Panel and then double-click Power Options icon. Will appear a dialog box with a Power Option Properties. Then select the Power Schemes tab. On the drop down menu will have six options, namely Home / Office Desk, Portable / Laptop, Presentation, Always On, Minimal Power Management, and Max Battery.
Try click on one of six choices. Setting the turn of the monitor, hard disks, System standby, or System hibernates time will vary, depending on the option you choose.
If you want a more durable battery, you should choose 'Max Battery'. This option will save battery usage because it only requires a minimum processor speed such as to read the documents or check e-mail. Max Battery will affect the speed of the laptop in the sense of a laptop's performance will decrease.
Do not let any device 'parking' on the laptop when not in use
Often, allowing laptop users have the device plugged in the laptop - whether it's cable digital cameras, USB memory stick, PC Card - though such devices are not used anymore. Make sure the appliance is unplugged from the laptop when not in use because it will drain battery power.
Notice the use and recharging of the batteries
Do not half-hearted when to recharge the battery. Charge up to full 100 percent. If the battery is running low, the rechargeable battery back up to full but do not wait until the battery is completely empty. This will make the battery capacity to work well.
To note again, remove the battery from the laptop if you do not use the laptop for a long time. Would be better if the laptop plugged directly into the adapter if you will work in a long time.
Reduce the brightness launch that the LCD will eat battery power. Therefore you are advised to reduce the brightness of a laptop as minimum as possible but still comfortable to the eye.
Use the Screen Savers 'Blank'
Screen saver is turns out to drain the battery. Therefore, use a screen saver 'Blank'. The trick, right click on Desktop and select Properties. It would appear the Display Properties dialog box, then select the Screen Saver tab. On the drop down menu there are a lot of screen saver options, including FlowerBox 3D, 3D Flying Objects, 3D Text, Blanks, Marquee and so forth. You are advised to choose 'Blank' and set the time waiting (Wait time) up to 2 minutes and then click OK. This step will make the battery more efficient.
Reduce resolution
Another way to make the battery last longer is to reduce the screen resolution and number of colors used in laptops. To reduce it, you can right click on the Windows Desktop and select Properties. In the Display Properties dialog box select the Settings tab. Then set the resolution slider by pulling it to the left to reduce the resolution. Then in the drop down menu select the color quality (color quality) is lower, and then click OK.
Turn off Wi-Fi
Wi-Fi certainly participate actively consuming the battery consumption. If it does not intend to take advantage of wireless access, or to the Internet, make sure the Wi-Fi in the dead so that batteries last longer.
on Apr 18, 2010 | Computers & Internet
Battery can be used to power computer. Plug cannot. Tried a different power plug from a different computer with around the same voltage and whatts, but still didn't power. This is a DC in power plug...
The problem is most likely the DC connector in the computer. I have replaced many of these. Normally what happens is the connector is stressed by moving the computer while plugged in stressing the connector. It could also be the DC converter board but .... that would probably affect battery operation also.
To replace the connector, you have to completely disassemble the system down to removing the main board.
Jun 21, 2011 | Acer Aspire 5050-3371 Notebook
..switch-on problem
remove the battery , take all the external device out , disconnect the ac adapter , then press and hold down the power button for 1 min then plug the battery and power adapter try to turn on the system if it does not turn on check with a different power outlet , check whether the ac adapter is warming up .if its not warming up that means its the ac adapter problem
Jul 04, 2010 | Acer Aspire 5050-3242 Notebook
How do I know if my laptop is charging?
If you are using Windows XP go to control panel (Start> Control Panel) and select Power Options, then Power Meter.
This will show the status of you battery and whether or not it is charging.
If you are using a different operating system please advise by replying here - add a comment and I will be pleased to help.
Mar 05, 2010 | Toshiba Satellite A100-S8111TD Notebook
Couldn't switch on my laptop;adapter light blinking !
Please take out the battery, and use the AC adapter to boot up only, then put the battery on.
If any abnormal situation occurs, please do a battery calibration as instructed in the manual. Adapter info:
Power problems with AC adapter
Step1 :
Please remove the battery first to verify the AC adapter's problem
Step2 :
Please check the power outlet on the wall by plug another device to the outlet
Step3 :
Please plug the adapter directly to the power outlet on the wall
Step4 :
Please make sure both the wires between the adapter to the wall and to the notebook are well plugged and the LED on the adapter is alight
Step5 :
Please check the power status indicator to make sure whether the notebook is powered on
Step6 :
Please make sure whether the CPU fan perform the testing run when the power is switched on
Step7 :
Please stick into the hardware reset button at the bottom of the machine and reboot
Step8 :
Please remove all of the removable hardware (exp. mouse, PCMCIA card, power adapter, battery, external drives, memory and etc) and install only the necessary components.
Step9 :
Please remove the AC adapter and re-install the battery
Step10 :
Step11 :
If possible, please change another battery to make sure whether it's the battery's problem
Step12 :
May 04, 2009 | Computers & Internet
Beeping Noise
I Can help you out Here.
Get yourself a new Battery, and A New AC Adapter.
Before you do extensive damage to your Motherboard If You Have,nt Already.
If you know you,ve got faults, Then They Need Repairing Urgently.
Thats The Best Advise Any Expert would Offer You.
Mike @ compurepair.
Apr 25, 2008 | HP Pavilion zd8000 Notebook
My laptop battery won't charge
possible when the old AC adapter blew it took part of the power management circuit with it, This is the circuit that detects and charges the battery, I'm not sure whether this a seperate replaceable daughter card or whether it is part of the main motherboard. you will need to investigate this (or send it for a service)
Oct 09, 2007 | Dell Inspiron B130 Notebook
HP Pavilion dv2000t Notebook Logo
44 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
