Question about Samsung LE32R41BD 32 in. HD-Ready LCD Television
Samsung tv how to set up my tv dvd & sky box
  • looseunit1 May 11, 2010
    can you please tell me i have a samsung LCD 46IN series 5 and would like to know ,where do i connect the sky cables etc so as i can record from sky through my dvd philips hard disk/dvd recorder .Which cord goes where..cheers Dumb blonde
I rang the shop i brought it from it was cheaper than yuor offer
Posted on Sep 19, 2008
3 Suggested Answers
geordie rob
  • 7 Answers
SOURCE: Struggling with Sky remote codes for new Samsung TV LE32A457
0060, 065, 584, 037, 245, 476, 398, 516, 292, 318,037
these are samsung codes for sky remote
good luck
Posted on Dec 29, 2008
chain saw
  • 94 Answers
SOURCE: My sky remote has stopped working on my samsung tv
PHONE UP SKY FOR THE CODES..THEY WILL HELP YOU OVER THE PHONE.. HAVE THE MAKE AND MODEL OF YOUR TV TO HAND....
Posted on Mar 10, 2009
Trying to connect 46"samsung smart
200px-multiconnector-scart-chti.jpg magnify-clip.pngMulti-AV SCART adaptors with Input/Output signal switch (gold & nickel). A common misconception among game console owners is such connectors will allow RGB quality, while they are only CVBS and S-Videocompliant. THESE CAN BE USED FOR NON HD DEVICES SUCH AS YOUR DVD-VCR, AND SKYTOP BOX YOUR TV WILL HAVE AT LEAST 1 OF THE YELLOW WHITE RED COMPOSITE CONNECTION
May 05, 2011 | Computers & Internet
Unable to set TV channels on dvd recorder since connected to Sky box
Actually you don't have to get other devices, Just cables, take the sky box output and connect to AV input of DVR
Feb 18, 2008 | Televison & Video
Can you show me how to connect up the scart and aerials up to the following so they operate correctly Samsung PS42C450 42-inch 600Hz Widescreen HD Ready Plasma TV with Freeview SAMSUNG DVD-SH893M 160GB...
hello firstly scart lead from sky box to tv1 in) this is at the top there are two AV inputs ,,,on the bottom AV slot this is where your DVD conects too).iff you are using sky you will not need aerial in back of tv as this is for analogue use such as indoor antenna or outdoor antenna or iff using horizon the scart lead will suffice for all goodluck
Mar 19, 2011 | Samsung PS42C91HDX 42 in. Plasma TV
I have recently bought a sky plus hd box and want to connect an external dvd recorder to it(Sony). Followed instructions but it will not pick up a signal from the hd box by the way I live on the costa del...
if you connect the dvd to the tv using scart socket 2 (av2) it should send a signal to the dvd, depending on the make/model of tv, you also may have to set the av2 output in the menu.
Alternativly, connect the sky to the dvd input and the dvd output to the tv, this should also work.May have to watch the tv with the dvd on set to av.
Nov 20, 2009 | Televison & Video
I need a wiring diagram to connect a samsung tv, sky+HD, DVD recorder, Wii and Playstation 3...thnx
all you have to remember is out of one into the other IF got Ariela on house that goes into sky then out of sky in to DVD recorder and out of that and into tv
on back of sky hd if you are going to use HDMI cable put cable into sky box and other end into tv ( you will have ot put tv on HDMI input/source)
or use scart lead in stead
THIS DEPENDS ON HOW YOU WANT TO CONNECT PLAYSTATION
everything else is colour coded
Nov 08, 2009 | Samsung 37" 720p Flat-Panel LCD HDTV
I AM LOOKIN FOR A SETTING UP DIAGRAM SO THAT I CAN RECORD FROM SKY TV, CAN U HELP?
your best way is to use scart cables 1 from sky to video/dvd recorder other from sky to tv your sky box should have 2 scart sockets
May 13, 2009 | Lite On Lite-On LVW-5045 DVD Recorder with...
I hvae just purchased a Samsung HXT 30 sound system and connected it to the tv anbd sky hd box how do I get sound from the tv it would appear it is a problem what cables do I need I have aq HDMI from the...
You need to run a cable from your Sky (satellite box) box's 'Audio Out' jacks to the sound system's 'Audio in' jacks. Make sure the Sound system is set on the same function as where you plugged in the cables (RCA type, red & white) on the back of the sound system. (example: if you used the 'Auxilliary' jacks, set the sound system on 'Aux')
If it's sound 'from' the TV as well as the sound system you'll need to connect another set (of red & white RCA) cables from the Sound System's 'Audio Out' jacks to the Television's 'Audio In' jacks. This should give you sound from both the TV's speakers and the Sound System. Good Luck!
Nov 30, 2008 | Samsung HT-Q100 System
Connection advice needed
hello.on that samsung you probably have more than one hdmi conection so conect your dvd/vcr with hdmi cable to tv and sky box with hdmi to if its have hdmi or with scart if not.if you still have problems with conection,make some photos of tv,dvd/vcr and sky box all back panel and send to me (dodzio24@o2.pl) and i send you the best solution i can.
Aug 14, 2008 | Samsung Televison & Video
Setting up
on the back of your sky box there are two scart ports. one says tv and the other video.
from the sky box connect a scart from the tv port to the back of your tv.
from the DVD connect a scart from that to the video scart port on the back of your sky box.
now when you turn your DVD player on it will override the sky and come through on your telly without having to change the scarts around.
what i would like you to do now. is get an RF lead. ( aerial lead) plug this into the RF out socket on the back of your sky box either one will do ie RF out 1 or 2 makes no difference.
Then plug the other end into the back of your Tv if you have an aerial cable coming into your home then simply plug this straight into the aerial port on the back of your sky box.
The last thing your going to have to do now is tune your telly in. if you click on channel 6 on your telly then go to menu, setup, and manual tune.. A good tip for you put your sky on the TV GUIDE screen this will make life easier for yourself as you will know its the sky channel.
once you find it STORE.
now when you turn your dvd player on if you select channel 6 you will now have the sky channel so you can record whatever you like
Hope this sorts you out.
cheers
Little Dish Fitter
Dec 28, 2007 | Samsung DVDHR738 (250GB) DVD Recorder /...
Samsung home cinama
Most likley your scart cable is the culprit, check whether the scart cable is the AV I/O type. And also better check the audio settings of the DVD player. Hope u hook up the speakers correctly. Cheers, Rifaa
Sep 04, 2007 | Samsung HT-Q100 System
Samsung LE32R41BD 32 in. HD-Ready LCD Television Logo
55 people viewed this question
Henry  Thomas
Henry Thomas
