Question about HP Office Equipment & Supplies
Im having problems printing to a network printer an hp Laser j 1200 using a Vista machine
I had to configure some rules on my firewall particularly allowing port 9100 access and turning SNMP to enabled in the printer settings.Thanks
Posted on Sep 19, 2008
Hp fax machine does not picks up incoming fax calls automaticly
check your settings to ensure that it is set to automatically answer fax calls. Also ensure that if you have distinct ring tone service that you have that feature enable properly for the ring tone that denotes faxes.
Sep 06, 2014 | HP LaserJet Pro M127FN Laser Multifunction...
Hp laserjet1200 series does not print. I have Vista x84 paltform. It used to work but now will not
Download and install Hp laserjet 1200 driver->click here
Please click on the link below and follow the troubleshooting guide.
h20000.www2.hp.com/....
Apr 08, 2011 | HP LaserJet 1320 Printer
I have a Dell desktop running Vista 64 Home Premium with a Lexmark P6250 all in one hooked to it via usb cable and shared on my home network. I also have one dell laptop and one HP laptop connected to the...
The printer drivers must be installed on each computer. If computer A runs XP, you must install driver for XP on computert A; If machine B runs Vista, then you must install printer drivers for Vista on machine B.
Hope it helps.
Sep 11, 2009 | Lexmark P6250 All-In-One InkJet Photo...
Ok here is the long version present configuration.. 2 computers one running vista and one running xp 2 printers one hp all in one series 1400 and one samsung laser I had a tech network the printers so...
Why don't you get 1 wireless printer and install the software on both computers and print from both? Also if/when you get a network printer set the IP manually. That way it never changes. (read on...)
Sharing printers was all the rage back in 1985 (Back to the Future movie) ... not anymore. Your probably having Windows networking problems. Disappearing hosts on the Windows network ... and everytime you reboot whoever comes on 1st gets to be the Master Browser and keep the list of computers on the WIndows network. And often that one just doesn't "get" the other computer (or two or 3) on the network for some reason.
Also problems can happen if the ip addresses are DHCP assigned (very likely) so they keep changing and one computer remembers an old ip and it gets broken all over again.
Jul 07, 2009 | HP PSC 1315 All-In-One InkJet Printer
Vista cannot connect to xp printer
It sounds like your are using your Windows XP computer as the print server, and you are trying to connect your Windows Vista machine to the Windows XP print server. Your Vista machine is trying to download the XP drivers from the Windows XP computer to your Vista machine. This won't work. Windows XP and Vista print drivers are not compatible.
If the printer is truely networked (it has it's own IP address on the network, it has its own ethernet connection). Then instead of trying to map out to this shared printer, add new printer to the Vista machine using Vista drivers for the HP Deskjet 3940. The type of port you would need is a standard TCP/IP port. To get this address, print a settings page from the printer. Look for either a TCP/IP address or IP address on this print out. This is the port address you want to create and then connect to.
May 04, 2009 | HP Computers & Internet
Too light of print
Blowing out dust is not a good idea. access to the laser optics is open on this machine, and you will only make the problem worse, by blowing dust and toner inside.
Dirty laser optics are the cause of our problem. The only way to solve is remove top cover of machine remove several wire connectors, remove cover of laser unit and clean all mirrors, motor, and reflectors.
Apr 02, 2009 | HP LaserJet 1200 Printer
HP LJ P1008 can be used as network printer ?
I have one of theses D-Link PD-301U. It does NOT support a printer like yours. According to D-Link's Web site, here are the HP Laser printers it supports (note the P1008 is NOT in the list):
LaserJet
  • 1200
  • 1500 (USB 2.0)
  • 2200
  • 2200D
  • http://support.dlink.com/faq/view.asp?prod_id=2135&question=DP-300U%20/%20DP-301P+%20/%20DP-301U%20/%20DP-311U%20/%20DP-G310%20/%20DP-G321
    Feb 10, 2009 | D-Link DP 301U (DP-301U) Print Server
    Network printer installation problem
    Are you using the proper Windows Vista Driver? You can't use the XP version...here's a link to the download page:
    http://www.ricoh-usa.com/downloads/downloads.asp?tsn=Ricoh-USA&path=http://support.ricoh.com/bb/html/dr_ut_e/rc2/model/cl7000/cl7000en.htm
    Jul 11, 2008 | Ricoh Aficio CL7000 Laser Printer
    26 people viewed this question
    Ben Johnson
