Question about Acer AL1717 17" LCD Monitor
Fix my monitor
I have a monitor acer model AL1717 looks good, but it has a vertical line that were happening one after another, which may be the screen or something else
  • Wassim Ibrahim
    Wassim Ibrahim Jan 10, 2009
  • The Cactus May 11, 2010
    Hello seferi1,
    I've fixed this one before. The line moves slowly down the screen every few seconds or so, horizontally. If I recall, it had nothing to do with the screen itself, rather, it was the computer. I updated the video drivers, and I think that the line went away. What model is your computer?
    ~Cactus
And prove it with another monitor and works well
Posted on Sep 20, 2008
  • 25 Answers
As saferi1 have stated you can try your cpu with another monitor so as to be sure.The problem is similar to the one i saw on the horizontal out put check that area.
Posted on Sep 18, 2008
Why in my Acer monitor AL1717 comes vertical lines in middle of the screen ?
Try updating your display driver and also try with another monitor cable, in case its broken.
Apr 28, 2014 | Acer AL1717 17" LCD Monitor
Why Vertical lines in the middle of the screen ??
This could be your graphic card is aging or the Hard Drive or even the monitor saying goodbye. Troubleshoot with another monitor, you will be able to narrow it down more. Good luck!!!
The screen is blinking too fast to do anything I am on another computer now how can I fix it?
inputs are wrong. use the proper cable. Set up your video to extend displays. Change resolution.
Mar 31, 2014 | Chief Manufacturing Chief Flat Panel Dual...
Why does it take so long to see my desktop icons when I power on my Acer AL1717 monitor?
bsellers, Tell me in "seconds", "minutes", how long is "so long". Do you even see the "boot screen" pop-up when booting the pc? You should see that first if lcd monitor is turned on first. Are you running a Windows OS? Will a "known-good" VGA monitor work ok when connected to your PC?? Will your AL1717 do same thing when connected to different "known-good" PC?? Did you even look at the "date of manufacture" on the rear of your monitor? Retrevo .com lists 1717 as time to retire??? Was your unit produced in "06" or "07"?? Let me know results of doing some simple "swap-out" tests. 12fixlouie
Dec 15, 2010 | Acer AL1717 17" LCD Monitor
Vertical Red Line down the screen of my Acer Al1717.
Try hooking an external monitor. If it will still show on the other display, possibly it is a video card problem. But I highly doubt it. Usually for this issue, it will have a good display on an external monitor. Try if it will still appear n the BIOS page. Press F2 several times immediately after turning the computer on. If problem still shows there, then it is the LCD that is causing it to happen. You need to replace the LCD.
Sep 21, 2010 | Acer 17" AL1717 Flat Panel Color LCD...
My acer al1717 just started having resolution
This is 2005 model year, it is due time to check for capacitors with bulging top/seal, leakage in the power supply. See example of failed monitors as a guide here so you know what to look for:
http://s807.photobucket.com/home/budm/allalbums
http://www.badcaps.net
http://en.wikipedia.org/wiki/Capacitor_plague
Post back what you find so we can guide you further.
Apr 05, 2010 | Acer AL1717 17" LCD Monitor
MY Acer AL1717 was shuting down but the CPU is already open How to do this my acer
The prblem will more likely to be caused by bad capacitors in the power supply, look inside for caps with bulging tops or seals, post bakc what you see so we can guide you further, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Mar 12, 2010 | Acer AL1717 (Silver) 17 inch LCD Monitor
Acer AL1717 lcd plss help
Your resoulutions are Hz are too high in the game settings for your monitor. Reinstall your game.
Jan 08, 2010 | Acer AL1717 17" LCD Monitor
Black lines in Acer AL1717
On the power supply PCB are two 25V 220uf capacitors that will be leading. Replace them and the picture should be back to normal.
Dec 28, 2008 | Acer AL1717 17" LCD Monitor
Acer AL1717 17" LCD Monitor Logo
101 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
