Question about LG Cell Phones
When i try to set up my email on this phone and try to connect the phone comes up with a error message stating `network open fail` please help. thanks.
I had a similar problem. It turned out, I had the wrong access point in the email account settings. It was set to "Contract Internet" but as I'm a PAYT customer, I switched this to PAYT Internet and the problem was solved.
Hope this is of some help.
Daibhidh
Posted on May 17, 2009
Help yahoo com
Symptoms You can try these basic steps to troubleshoot Mail on your iPhone, iPad, or iPod touch. If you see a specific error message, follow the basic steps, then the steps for that error message. For example, you might see one of these messages:
  • Cannot get mail
  • Unable to move message
  • Username or password is incorrect
  • Relaying denied
  • Email address rejected by the server
Resolution First, try these basic troubleshooting steps:
  1. Tap Safari and load a webpage. If you can load a webpage, then your device has Internet access. If you can't load a webpage, check your Wi-Fi connection or try a different Internet connection:
    • Try a different Wi-Fi connection.
    • If your iOS device has an active cellular data plan, tap Settings > Wi-Fi and turn off Wi-Fi.
    • If the affected email account is provided by your Internet provider, see if your issue is resolved while connected to your home Wi-Fi network.*
  2. Log in to your email provider's website to make sure that the account is active and the password is correct.
  3. Make sure your settings are correct using Mail Settings Lookup.
  4. Restart your iOS device.
  5. Delete the affected email account from your device.
    1. Tap Settings > Mail, Contacts, Calendars.
    2. Tap the affected email account.
    3. Tap Delete Account.
    4. Add your account again.
* If you can only use your email account while connected to your home network, this might be a limitation put in place by your email service provider. For help, please contact your email service provider.
Follow the steps below for specific alerts.
"Cannot get mail" Make sure you entered the correct password. If you enabled two-step verification through your email service provider, contact them to see if you need a special password for your iOS device.
"Unable to move message"
  1. Tap Settings > Mail, Contacts, Calendar, then tap your email.
  2. Tap Account.
  3. Tap Advanced.
  4. Tap Deleted Mailbox and make sure it's set to Trash.
  5. Tap Advanced > Account, then tap Done.
    Note: If you see the issue again, repeat steps 1 through 3, tap IMAP Path Prefix, then Inbox. After you make your changes, tap Account, then Done.
"Username or password is incorrect" with POP3 account Before you check your email on your iOS device, close it on your computer and other devices.
To see if your account is a POP3 account use the Mail Settings Lookup tool or:
  1. Go to Settings > Mail, Contacts, Calendars and tap the account.
  2. Look for the label POP ACCOUNT INFORMATION.
If your email provider offers IMAP, remove the POP3 account, then add the account with your provider's IMAP settings. POP3 communicates with one mail client at a time. If more than one mail client tries to connect, you might see a username or password error.
"Relaying denied" or "Email address rejected by the server" when you try to send email This error indicates that either an email address is incorrect or your settings aren't correct for your current connection. Make sure the email address is correct for messages in the Outbox or try a different port:
  • If you're on a Wi-Fi network connected to the same network as your email domain, such as your Cable or DSL provider, try port 25:
    2. Tap your email account, then tap Account.
    3. Scroll down and tap Outgoing Mail Server.
    4. Tap Primary Server, then tap Server Port.
    5. Delete the current port and enter 25.
    6. Tap Done.
  • When you connect to a cellular data or a different Wi-Fi network, you need to use an alternate port and authentication, if your email provider supports it. The most common alternate ports are 465 and 587. Check with your email provider for specific settings.
If you still can't send email, you can set up an alternate SMTP server.
Get help troubleshooting iCloud Mail.
Aug 29, 2014 | Yahoo Mail
I cannot connect to wi fi , error message reads connection failed check network setting
can ask what brand carrier you are currently using. if it is smart just type on your write message SET send to 211. then a reply message telling you that an internet settings has been sent to you, Save it. Use it as your default settings. Then try to check if your wifi connections is active or readable. if it is from globe they usually send internet settings.
Jan 03, 2013 | Cell Phones
My N8 is recently not connecting to the internet. It shows the following messages when I try to connect it through my AIRTEL connection : Connection failed Connection Unavailable and Network Error -...
Bro first delete all the setting from ur cell phone ask for new setting 4m ur operator.after saving settings pls switch off d phone & start it after few seconds and now try connecting to net
Jan 20, 2012 | Nokia N8 Cell Phone
Email connection and picture messages
you just have to contact your network operator and ask them to send the settings of internet and MMS. When you received the same install them and restart the phone....
If you have already done the above procedure then First set your gadget to factory defaults and follow the above mentioned procedure... Hope this has helped you... Please rate the answer... Thanks..
Jul 21, 2010 | LG enV VX9900 Cellular Phone
I am trying to set up an email on my phone but it keep on saying dns error/failed how do i set up an email from my phone?
just giving you an idea,
on your computer, login to your email account then go to your account settings.. just copy your email configuration to your mobile..
on menu > messages > settings > email > email accounts
> Your email account.. input your configuration from your email..
(e.g. smtp.mail.yahoo.com & pop.mail.yahoo.com) for yahoo accounts
on menu > messages > settings > email > email profiles> choose your connection (e.g. wifi connection, gprs/edge connection)
May 28, 2010 | Samsung Star GT-S5233 Cell Phone
I can not send SMS message. SMS Message Center Number Error
I had the same problem and came to this site for help but the solutions didn't solve the problem of "cannot send text message" on htc touch hd. All service numbers correct. Went to START/SETTINGS/CONNECTIONS/ADVANCED NETWORK/SMS SERVICE then changed from "gprs" to "gprs preferred". Double checked and had reverted to "GSM" but sms now works - finally!!! Hope this helps.
Aug 26, 2009 | HTC Touch Diamond Smartphone
''Connection Error & Message Sending Failed''
Try doing a Factory Reset. (PLEASE DO IT ON YOUR OWN RISK - FACTORY RESET WILL DELETE EVERY THING OUT OF YOUR PHONE)
Dial *#7370# now it will ask restore original device settings,yes,it will ask for password its-12345, your phone will restart, all the data on our phone memory will be deleted,and it will be like when you first bought it.
But i don't think so that gonna help you out that much. It seem to be issue with the network. Try using some other Mobile service provider. See if problem still remain their on your mobile.
These kind of error message comes when you have WEAK NETWORK.
Dec 28, 2008 | Nokia 6680 Handheld
Samsung SYNC SGH-A707 Cellular Phone wont send pictures anymore
Check your phone's network connection option to ensure it is at the right one. Goto settings,connectivity, IMS settings,profile, then chose the providers network option.
Oct 29, 2007 | Samsung SYNC SGH-A707 Cellular Phone
Cell Phones Logo
117 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
