Question about Toshiba Satellite M30 Notebook
How to access windows drive to backup data through using the recovery disk
My satellite laptop can't enter Windows at the moment, not even through safe-mode. Is there anyway to access the data inside the windows drive without actually going into Windows? I was thinking if its possible using the recovery disk, but I'm unsure of the commands etc. Please help anyone
  • dre86 Sep 27, 2008
    hey, thanks for descriptive answers you given and sorry for the long response i had no time to check it out after the last time i posted...
    you answer has helped me for other means but i do have another problem and was wondering if you can help me..
    So far, the hard disk unable to access windows. It keeps coming out blue screen after it loads windows for abit. What i tried to do is using the recovery disk to access the data, but what mistake i did was I loaded the recovery disk and it was loading some stuff to the hard disk... I'm not sure if it was formating the disk or copying windows to the disk.. it was the recovery disk of the toshiba satellite m30 so maybe you know the process.. I shutdown the process just after it loaded like 1% or someting so it wasn't a complete reinstallation... what I'm wondering is that is the data still inside the hard disk? Windows was unable to see the partition so what i was thinking is maybe the partition is gone but the actual data is still inside? or does windows delete all the files already?
  • danlekh Apr 03, 2009
    my laptop starts up but goes to the black and white screen for the safe mode and where it says start windows normally and when i try all of the options on the screen it starts windows and goes back to the same screen again, which is the safe mode and start windows normally and gives me 26 seconds each time and starts all over again.
    Problem Solver:
  • 5 Answers
You are in luck. There is a wide variety of solutions available to you, but which you can use will depend upon your configuration. You will need access to another computer that is working, and has a cd-burner and an Internet connection.
Go here:
http://www.download.com/UBCD4Win/3000-2086_4-10550208.html?part=dl-UltimateB&subj=dl&tag=button&cdlPid=10861574
Download it (300+ MB) and burn it. Once burned, insert it into the optical drive on your laptop. Turn on the laptop, and it should automatically boot from the cd. If it doesn't, You will need to reboot the laptop an get into the BIOS utility. This is done when the POST screen is up, which may be just a simple black screen with lettering, or it may be an elaborate logo from the maker of the laptop. There are usually instructions on this screen to the effect of "press [key] to enter Setup". Depending how your laptop is configured, these instructions may not appear. If not, the key will still work, it has just been set not to display. You will have to hit a key during the POST screen to enter setup. This key will be one of the following, depending upon your manufacturer:
F1, F2, F9, F10, Esc, Del, or (rarely) a combination of keys. I can tell you for sure if I know who made the laptop.
Once inside the setup utility, navigate to a screen that gives Boot options. This may be called "Boot Options", "Boot Settings", Boot Order" or some such, again depending on your manufacturer. Make sure the CD- or DVD-ROM is at the top of the list. Exit setup, being sure to save your changes.
The machine will automaticly reboot, and boot from the cd drive. If it does not automaticly reboot, it's because your changes were not saved.
Once in the live boot desktop environment, you should be able to find your way to your hard drive, and any files you need can be transferred to a USB stick from there.
If you encounter a password or encryption problem, let me know, as that would be too much for me to put here if you don't need it.
If you are for some reason un-able to do the above, you may be able to boot your machine from a USB memory stick, though this is rather involved, and I won't put it here unless I know you need it.
Failing that, you can hook the laptop up to another machine and boot it from a cd, floppy drive, or USB stick and network with it to remove the files.
The last option is to remove the hard drive and place it either in another laptop (not recommended unless the laptop has two separate drive slots because if it does boot in the new laptop, windows will go nuts about the new hardware) that has a CD-ROM and do as above, or get a special drive cage that allows you to hook it via USB or your internal SATA or IDE to a desktop PC. You can find one here:
http://www.ameri-rack.com/ADAPTER.htm
There may be more solutions to your problem, such as using the windows installer cd/dvd to re-install Windows WITHOUT re-formatting your disk, so that the new installation will be alongside the old one, but without more information I can't know if these options would help you.
If you want to fix your current Windows installation, that may be possible as well if you have your Windows cd. If you have only an OEM installer/restore disk, chances are these options will not work for you.
Good luck
Posted on Sep 18, 2008
    Problem Solver:
  • 19 Answers
All the Files that had been copied to the HDD is corrupted so what you need to do is redo th system recovery and do not touch the NB until its finished with the prosses. it will automaticaly restart for about 10 - 15 times dont worry its perfectly fine and after about an hour and a half, it will ask you to create a new user acct and password thats the only time you could touch the NB.
Posted on Aug 21, 2009
Why won't Windows Error Recovery tools work?
This means that the hard drive is corrupted such that the Windows Recovery tools can't solve the problem. You may have lost the MBR or the partition table.
The PASS means that there are no bad sectors. However, it doesn't check for bad files. If the problem is in the MBR, you will need a Windows OS install or upgrade disk for your OS (x32 or x64) or a recovery disk. Some members of a Windows Users group may have spare copies of the install disks. Alternatively, a third-party partiton management recovery disk may work. I hope you have a recent backup though since restoring from the backup may be needed.
If the problem is with the MBR, press F12 repeatedly on powering up the computer. Select the CD/DVD drive from the list (This is the one-time boot option. If you miss the timing, power down and retry.) With a Windows CD/DVD, follow the on-screen prompts to access the disk and choose Repair your computer. (This option is in smaller text below the Install now button.) Select the command prompt option. From here: type in "bootrec.exe /ScanOs" (without the quotes) and press enter. If any Windows installs are found, you are good to continue. The command, bootrec.exe /RebuildBcd , may be sufficient. If it isn't, use the bootrec.exe /FixMbr and bootrec.exe /FixBoot commands after rebuilding the BCD file. (Press enter between each set of commands.) Try starting the computer and create a new backup soon if it works. For other partition tools, follow their directions for MBR repairs.
If bootrec.exe /ScanOs doesn't find any Windows installations, try accessing other drive letters until you find your Windows OS. (For example, type C: or D: and press enter. Then type dir and enter.) If you have access to another computer, pull the drive and use a hard drive dock or USB to hard drive adapter to check the disk out elsewhere. I recently had a drive that reported having a RAW format with most tools. In my case, I was able to use a specific recovery tool, TestDisk for Windows, to salvage a few files that were newer than the last backup. Sometimes, this tool will be able to recover the partition table. (Use this tool with extreme care, it may render any original hidden backup partition unusable.) There are other disk recovery tools out there; some may work. You may want to run additional disk health tests while at this second machine.
If the system is faulty but the drive is otherwise healthy, restore using your last backup or the Dell Backup and Restore Utility. The Utility may be in that list of options after you press F8. (Note: the Dell Backup and Restore will return the system to the factory settings. Since the system started with XP and the above header indicates the Vista OS, there may not be a recovery partition available. Similarly, if you upgraded the hard drive, the recovery partition might not be usable.) Follow the directions from your manual/on-screen. If your backups are on CD/DVD or you have a recovery disk, use the F12 process to access the backup.
I will admit that with the recent drive I just fixed, the restore from the back up left a problem. This system was a Win8.1 drive and ended up with a MFT mirror issue. I solved this with the chkdsk c: /offlinescanandfix command on the next restart. (This is a switch option only available with newer Windows systems and the NTFS file system. The usual command would be chkdsk c: /f /r /x .)
I hope this helps.
(The Windows 8.1 system above had a hard drive replacement 2 years ago and was built in late 2008.)
Mar 30, 2015 | Microsoft Windows Vista Home Premium with...
Recovery of my r51
The O.S is corrupted and you want to format the HDD of your Laptop.before formatting backup your all data,so that you can easily format and install new O.S.
Laptop Hard Drive Recovery
Laptop Data Recovery Laptop Hard Drive Recovery
Feb 14, 2014 | Lenovo ThinkPad R51
Won't boot up
Ed unfortunately it sounds as if the hard drive has failed. Make certian you do not have a CD in the drive and there are no external drives or flashdrives connected also.
Jan 16, 2014 | Toshiba Satellite L455D-S5976 Notebook
My Dell Inspiron 6400 (Windows XP Home) won't reboot. It's giving me a "Loading PBR for descriptor 1 ... done" line on a black screen. What can I do to fix it. Can I salvage my content / files
Before you use the Recovery CD you need to backup your data because to restoring your laptop will wipe your data off the hard disk.
To backup your data when you cannot boot up your laptop, remove the hard drive and connect it to an USB hard drive adapter. Connect this hard drive/USB adapter into the USB port of a working computer. The computer will see it as an external storage device, you can then open the folders and backup your data.
You can then fit the hard drive back into the Dell laptop and boot up with the Dell recovery CD to reinstall Windows etc.
Mar 04, 2013 | Dell Inspiron 6400 Laptop Computer Core 2...
I need to reset my laptop
Hello, here are the steps to resetting your computer.
Reinstall Windows from a Disk
1 Turn on your Toshiba Satellite. Insert your recovery disk or the original Windows operating system DVD
into the Satellite's CD/DVD drive. Turn off the computer.
2 Turn on the Toshiba Satellite. In the first few seconds while it is starting up, press and hold the F12 key on your keyboard to access the Boot Menu. (Note: Some Toshiba models may tell you to press "C" to boot
from the CD-ROM). The screen will display boot for this boot up session only.
3 Use the arrow keys to navigate. Select the CD-ROM/DVD drive to highlight it. Press "Enter." Be aware that this setting is for this session only; it is not a permanent change.
4 Allow the computer to start up. Follow the onscreen instructions for reinstalling the operating system from the disk.
Reinstall from a Recovery Partition
1 Boot up the Toshiba Satellite. In the first few seconds while it is starting up, press and hold the F8 key. This will begin the "Advanced Boot Options" menu.
2 Use the arrow keys on your keyboard to navigate the menu. Move the keys to select "Repair Your Computer." Press "Enter."
3 Select your language and keyboard; click "Next."
4 Select your Windows user name from the drop-down menu. Enter your password if required. Click "OK." This will begin the "System Recovery Options" menu.
5 Select the Toshiba Recovery Wizard and follow the onscreen instructions. The Toshiba Recovery Wizard will delete all existing data on the hard drive and reinstall Windows.
Hope this helps!
Mar 28, 2011 | Toshiba 173" Satellite L555S7008 Intel...
My toshiba will not boot up
If there a display but not booting up, either your operating system corrupted or your hard disk drive having problem. Try tapping F8 then select safe mode if it's loading through windows desktop, you have to backup your data to your secondary drive partition or to your flash drive. After you backup your data or files, it is time to reformat your laptop. Install your operating system or system recovery disk provided by your manufacturer. Good Luck
Nov 26, 2010 | Toshiba Satellite A135-S2276 Notebook
Safeboot corrupted (error 92h)
Check the BIOS setting to see if the hard disk is detected. If not either the hard disk controller or the hard disk is faulty.
First thing I would try is to remove the hard drive and connect it to an USB hard drive adapter and then plug this adapter into a working computer's USB port. If this computer sees this hard drive as an external hard drive and you can open the various folders and files, then I would backup your data.
If the hard drive is not detected then the hard drive is dead and data cannot be retrieved with this method.
Retrieving data from damaged hard disk is possible. There are companies that can remove the disk platters from the damaged hard drive and with special equipment may be able to recover your data, but it will cost you an arm and a leg for their services.
Jun 24, 2010 | HP EliteBook 2530p Notebook
Need administrator password
there are many programs out there that can clear off passwords, and you can even use a flash drive to do it. so u just simply put the files on the flash drive.. pop it into the locked pc, restart the pc and then follow the directions on the program. I will not say the names of these programs as people can use them maliciously
Dec 21, 2009 | Dell Latitude E6400 Laptop Computer PC...
Mbr error
1. You can fix the MBR error by booting the Computer with a Windows Setup disk.
2. Boot from the Windows CD, and press "R" to enter the Recovery Console.
3. In the Recovery Console Enter your Administrator password.
4. Type in the following: bootcfg /rebuild
5. Then: fix mbr
6. Type: Exit
Good Luck!!!!!!!!!!!!!!!!!!
Sep 13, 2009 | Gateway Computers & Internet
Want to know the steps to reformat Toshiba - Satellite Pro
Your data - In order to ensure don't copy any infected data backup as few executables as possible. BEFORE restoring your data make sure you have antivirus installed and up to date. Perform a full scan after copying the data back to your lt. Put in the recovery disk and restart your computer. Look for a prompt on the screen to "boot from disk" while it is booting. Press the key it says to press and follow the directions from there. If there isn't a prompt to boot from disk try pressing Alt and F10 while it boots.
Jun 03, 2009 | Toshiba Satellite Pro 490XCDT Notebook
Toshiba Satellite M30 Notebook Logo
171 people viewed this question
Top Toshiba Computers & Internet Experts
Brian Sullivan
Brian Sullivan
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
