Question about Bosch Dryers
How do I replace the Heating Element in a Bosch WTA4409 Dryer
    Sergeant:
  • 399 Answers
Why does my Bosch Washing Machine (Classixx 1400) no longer heat the water? I have already tried replacing the washer heating element.
This video will show you how to replace the Bosch washing machine heating element and thermostat with step by step guide on the process
Jun 10, 2011 | Bosch Classixx WVF 240S Front Load Washer...
I have a Bosch nextt 500 series dryer and after 2 years of use the problem I have is the heat will shut off and the dryer will keep running and I have to press the reset button on the backside of the dryer
Open the front panel, remove heat exchanger and clean. also clean out lint tray. this might help a little. Now lets check if the thermal sensor or heating element needs to be replaced.
Unplug the dryer. remove the panel in the back of the dryer that covers the heating element. ( the inner panel). On top of the heating element you will see a thermal sensor with a small red button on it. Thats the manual reset button. To test if the heating element is working properly you can disconnect the wires from the sensor and clip the connectors together . Plug the dryer back in and start it. pay attention to the heating element. It should begin to glow shortly. if it doesn't then your heating element is bad and needs to be replaced.
Unplug the dryer. Connect the wires back to the thermal sensor. Plug the dryer back in. Before you start the dryer, press the red button on the thermal sensor. Start the dryer. If the heating element doesn't come on and dryer doesn't heat, then you need to replace that sensor.
Feb 01, 2011 | Bosch Axxis WTL 5410 Electric Dryer
Dryer does not heat
Well first all you may check out the heating element, it is possible that your dryer isn't heating because its heating element is defective. Heating elements are not repairable. You need to open your dryer's cabinet and locate the heating element so that you can test it. and you need a multimeter to check it out. Secondly you may check out the Thermal Fuse Once a dryer's thermal fuse has blown, it is no longer of any use. If your dryer's fuse is blown, you need to replace it. Post further comments for further help or information.......
Good Luck!!
Thanks for using FixYa!!
Jan 26, 2011 | Bosch WTMC632SUS Electric Dryer
My Bosch dryer is running but there is heat?
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Jan 04, 2011 | Bosch Nexxt 500 Dryer
This is a Bosch electric dryer that is 10 years old. The heating element is gone. Is is worth fixing? Or should I buy a new one.
are you sure it is the element, and yes repairing it is a whole lot cheaper:
http://shop.ebay.com/i.html?_nkw=heating+element+dryer+bosch&_sacat=0&_odkw=heating+element+dryer&_osacat=0&_trksid=p3286.c0.m270.l1313
this should assist you:
http://www.espares.co.uk/advice/tumble-dryers/a/9/1344/how-to-replace-the-heating-element-assembly-o.html
Dec 03, 2010 | Bosch Axxis WTA4400 Dryers
I have a Bosch WTL5410 dryer, which has no heat going to the otherwise functioning tumbler. Do you know where I could purchase another heating element and where I can get instructions regarding the...
Open front panel, remove heat exchanger and clean.
Unplug the dryer. remove the panel in the back of the dryer that covers the heating element. ( the inner panel). On top of the heating element you will see a thermal sensor with a small red button on it. Thats the manual reset button To test if the heating element is working properly you can disconnect the wires from the sensor and clip the connectors together . Plug the dryer back in and start it. pay attention to the heating element. It should begin to glow shortly. if it doesn't then your heating element is bad and needs to be replaced.
Unplug the dryer. Connect the wires back to the thermal sensor. Plug the dryer back in. Before you start the dryer, press the red button on the switch. This is your reset button. Start the dryer. If the heating element doesn't come on and dryer doesn't heat, then you need to replace that sensor.
Mar 24, 2010 | Bosch Axxis WTL 5410 Electric Dryer
Not heating
Probably the heater element has failed, it would probably be better to think of replacing the dryer at 10 years old, as Bosch spares are very expensive.
Hope this helps you to make a decision as to what to do.
Jan 04, 2010 | Bosch Dryers
Dryer goes on but does not heat up
The heating element needs replaced. This is extremely inexpensive and practical to do yourself. You will need to order the part for your particular dryer, I would suggest contacting the manufacturer for pricing. I would estimate about $30 for a heating element.
Sep 27, 2009 | Bosch Axxis WTA 3510 Electric Dryer
Dryer won't heat
It could be a defective thermostat or heating element(In most of the cases it is the heating element).Open the service panel and check with a multi-meter for 115/220V on the heating element tags. If you can read 115/220V on its tags, it should be replaced. In case you can't read 115/220v on its tags, you should replace the thermostat. Good luck!
Sep 02, 2007 | Frigidaire FEQ1442ES Electric Dryer
Dryers Logo
188 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
