Question about ASUS Pundit-R Barebone
Problem with Pundit-R and PCI graphics card
I have problems with Pundit-R and Powercolor HD2400 Radeon 256 PCI card. The system runs on Vista and there are some conflicts between resources in Device Manager.
I cannot find the possibility to disable IGP manually, as in the BIOS I can find only setting for primary boot. After several experiments with the settings and various ATI drivers version I can see the PCI card in the DM, but with the yellow triangle sign (exclamation) - the error code is 43. The strange is that the card operates sometimes but only as VgaSave i.e. it gives some output signal. At the same time there is no problem with HD Audio integrated with the HD2004 card - seemless P'n'P instalation process during Vista startup.
What should I do to run the card? Change OS? Downgrade the MoBo BIOS (to which version)? Or maybe there are some switches/jumpers on the MB?
Does anyone have the similar problem with upgrading Pundit-R with discrete graphics card?
I had a similar problem when installing a GeForce 5200 256mb PCI card in my Asus Pundit-S running winxp which I overcame when I got the sequencing of installation right.
First, Physically install the card in one of the available PCI slots. Using the onboard graphics to your monitor, boot the system. Windows will detect your new card and prompt you to install. Cancel Windows installation and use the supplied Radeon install disc for driver and program installation. After that, Reboot and enter your system's BIOS. On my system, repeatedly hitting the delete key gets me there.
Now this is where it may differ. In my BIOS, I needed to select the ADVANCED Menu followed by PCI CONFIGURATION. If your BIOS does not have the ADVANCED menu, you may have to upgrade it by downloading from the Asus Global Site. That is a whole other challenge but it is possible...hehe
The two options that need to be changed in the PCI Config Menu are:
Primary VGA BIOS -> PCI VGA Card, and
Onboard VGA -> Disabled.
Save changes and exit BIOS however, on exiting, you will need to unplug the VGA/DVI cable from your onboard port and connect it to your PCI card port. My card will not display the content unless it is plugged in from initial boot so you might have to restart your computer if you are not quick enough to catch that boot cycle.
Selecting these options should avoid any onboard conflict between devices as the Pundit-R has an onboard Radeon 9100 chip. I suspect the two same-make chips is where the conflict problem lies plus you don't need to be running the onboard graphics if you have a dedicated PCI card.
I hope this helps.
Good Luck.
Posted on Jan 01, 2009
My Radeon card isn't recognizing the monitor and Catalyst won't read its full resolution (1024 x 768).
Hello there
The HD 2400 is a pretty old card and I doubt it will give brilliant graphics.or will it run DX11
However.
1)Have you disabled the 'on-board' graphics in your BIOS settings ? Your computer will not recognise it if the old on board chip is enabled.
2) Have you tried connecting the 2400 using the 15 pin video connector ?
3) You say it isnt 'recognising' the hd2400 and yet you are saying the monitor is working at 640 !!!! Which is it. Does the monitor work on the old onboard output or the HD2400 ?
4) The version of catalyst depends on your operating system and whether 32 or 64 bit.
Use the right one via here http://support.amd.com/en-us/download
and uninstall the old one first..
5) If the monitor does not work at all on the HD2400 try the card in a different PCI slot.
6) ALWAYS check after you start the PC that in 'Device Manager' that the display adapter (hd2400) is recognised.
7) run ' DXDIAG ' to see how good the monitor is. (type in dxdiag the start orb search box)
Sep 24, 2014 | ATI RADEON HD 2400 PRO Graphic Card
I have a video card radeon hd 2400 series for vista 64 bit compatibility, will it work on xp 32? what can i do to make it work?
Hi There,
Yes it will work with Windows XP operating system.
1. If you're going to change the Vista operating system to WIN XP 32bit, you have to find WIN XP 32bit drivers for *********** board as well as the HD2400. Install Xp 32 bit
2. For HD 2400 drivers just click the link. ATI The link includes Catalyst, OpenCL and Display drivers.
3. Wait for the download to finish, Run the 32bit display driver and follow onscreen messages reboot if prompted.
A. If you're going to use it in another machine just download the display driver and attach the graphic card.
Hopefully this information helps.
Thank you for using FixYa.
Aug 04, 2011 | ATI RADEON HD2400 PCI-Express Vcd w/TV-out...
When installing thge PowerColor AX6970 2GBD5-M2DH Radeon HD 6970 Video Card, does it need the 6 pin & also the 8 Pin power connected
This is a high end card that needs over $00 watts of power coming from a very good power source. So yes, you need both connectors.
Jun 29, 2011 | Power Color PowerColor AX6970 2GBD5-M2DH...
R92p drivers for windows 7
There are no Win7 or Vista drivers for this card, it's not supported in them since it doesn't have the minimum characteristics necessary for that.
May 01, 2011 | ATI PowerColor R92P-C3S RADEON 9200SE PCI...
I have been using a integrated nivida geforce and i barely bought the RADEON HD 6850. i put RADEON HD AX6850 into the pci-e and i tried to connect it to the video cable to my monitor but my monitor...
You will probably have to boot into your BIOS by pressing F2 or DEL, depending on your motherboard. I'm not sure what motherboard you have but I think you're smart enough to find the setting that says use the video card instead of on board graphics.
Remember to do this while connected to "motherboard" graphics then switch over to the video card.
I hope this helps.
Mar 24, 2011 | Power Color PowerColor AX6850 1GBD5-DH...
I had to reimage a system, i need the aTI Radeon hd 2400 DMS59 pci drivers, i lost my CD....Thanks...tell me where? sandersg@georgetownisd.org
Hi
You can get the latest driver at this website. Just make sure that you indicate the correct radeon series and correct operating system follow the 5 steps to download your driver.
http://support.amd.com/us/gpudownload/Pages/index.aspx
banaple
Sep 01, 2010 | VisionTek ATI RADEON HD2400 Pro Edition...
Powercolor x1650 512mb AGP problem
The one you bought is 16x but your MB supports only 8x..................sodeep
Jun 18, 2009 | Power Color 256MB PowerColor ATI RADEON...
Problems with running installation cd for radeon 9250 video card
There is currently no support for the 9250 Series as far as drivers for Vista is concerned.
Apr 12, 2009 | ATI RADEON 9250, (256 MB) PCI Graphic...
Choosing Graphics card.
NVidia Geforce series, i have found is the most reliable and less likely to screw with your system in a negative way like Radeon.
I have used all forms of video cards in the past. the GeForce series is stable. I have a Dual HDMI output card myself, its only a 512mb DDR2 but it does the work load of MMORPG's with ease and my system very rarely has issues unless i am trying to run more than i rightly should. So my suggestion is the GF9600T. It is powerful beyond beleif and will make resolution and texture ratio through the roof.
Thats my professional opinion on this.
Nov 02, 2008 | Computers & Internet
ASUS Pundit-R Barebone Logo
1,518 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
