Question about HP Pavilion dv4000 Notebook
Hp pavilion dv4000 screen is dark and unreadable
The screen on my laptop is working, but the lamps that make it readable are not. This occurred after my roommate used my hp printer power supply on my laptop instead of my laptop power supply. The printer power supply is 31 volts output, the laptop output 18.5 volts. The screen has been dark ever since. What can I do to fix this? I'm real poor. But if I knew what part to purchase I could fix this myself. Help.
  • Anonymous Dec 26, 2008
    my screen went dark. i can barely see the screen
  • mandyhege Feb 26, 2009
    I am having a similar problem. My screen is fine when I first start up and after coming back from screen saver, but it just goes out about 15 times a day. If I press the Sleep button, it lights back up but then goes to sleep. Sometimes when I do that, it comes back.
    Very frustrating.
    Any advice?
    Thank you.
  • 320 Answers
Hi this is a website where you can dawnload service repair manual
http://www.laptop-repair.info/hp_laptop_repair_manual.html
check with it
regards
Posted on Sep 18, 2008
When i turn my hp pavilion dv200 on everything on the motherboard can show that is working but no power can enter the screen and the screen can be dark.
but when u open u see a hp bios in screen and next they dark only the problem there is ah program try to format your computer or repair the operating system.
Aug 09, 2011 | HP Pavilion dv4000 Notebook
I have a hp pavilion dv4000 laptop but dont have restore disk
The hard disk has died, replace it and reinstall windows using someone's else disk and your key.
Mar 28, 2010 | HP Pavilion dv4000 Notebook
The labtop fall and i get white screen, motherboard and prossesor are are working HDD is also fine..what are the possible problem that might occured with the screen??
You may have a defective CCFL backlight, it may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight. It could be a faulty inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out; usually the CCFL lamp fails before the inverter.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site: -
www.ladparts.net
Oct 28, 2009 | HP Pavilion DV4000 15.4" LCD LEFT AND...
Monitor keeps shutting off after a few seconds- hp dv4000notebook
You may have a defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
Check out
www.lcdparts.net
Sep 09, 2009 | HP Pavilion dv4000 Notebook
Dv4000 hp pavilion dark screen
Have you replace the lcd inverter? if it works on external monitor, given the screen is new, then it leaves the inverter. Usually in the case of dark screen, it should be the first thing to check/replace.
Apr 07, 2009 | HP Pavilion dv4000 Notebook
Dark unreadable screen
If you see a dim image or flicking image on the LCD screen it means you have a backlight problem.
Connect an external monitor to the laptop and power it up, if you see a clear image on an external monitor, this means your video card is OK.
Check out www.lcdparts.net for parts, repair service and DIY info.
Mar 13, 2009 | HP Pavilion dv6000z Notebook
Bluetooth on HP Pavilion dv4000
i need bluetooth driver for hp pavilion dv 4000
Oct 06, 2008 | HP Pavilion dv4000 Notebook
Dark Screen
the ac adapter needs to be pluged in, try the normal mode..
its hard to fix it from here, if you could get someone to look at it?
Apr 12, 2008 | HP Pavilion dv4000 Notebook
When starting my DV4000 - the screen is dark other than a cursor in the left corner.
That error indicates a hard drive problem. You probably have to replace the hard drive.
Nov 23, 2007 | HP Pavilion dv4000 Notebook
HP Pavilion dv4000 Notebook Logo
554 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
