Question about Roper Dryers
Timer won't advance on autosense,seems to work normally otherwise. timer advances fine on all other settings. was thinking it was the cycling thermostat, but the blower seems to be cycling. puzzled
  • James Dunn Sep 24, 2011
    model number is rgx4635eq0
  • Roper Master
  • 2,699 Answers
When on auto the heat comes on and then shuts off and then the timer advances,when the heat comes back on the timer stops advancing,when on time dry the timer will advance no matter what's happening with the heat.next time send the brand name and model number so i can help you better,if it's gas you could have bad gas coils,you'll have heat for like the first 15 to 30 minutes then when the coils get hot they fail and no heat until they cool down,also if the vent line and the duct that the lint filter goes into hasn't been cleaned out the heat will shut down and if that happens the timer isn't gonna move.check that out and let me know what you find and send the brand and model number.
Posted on Sep 24, 2011
  • 2 more comments
    how do I test the coils?
  • Sal De Sep 24, 2011
    if you first have heat when you start the dryer the coils will read good with a meter,start the dryer,down on the left side of the front panel you'll see a plastic piece,pop it off and you can look in and see the flame lite,after 15 to 20 minutes check it,you'll hear a click and then another click and the flame will lite,if you hear a click and then no flame the coils are bad,when you start it and if the flame lites most likely you have bad gas coils or a block somewhere in the dryer,in the duct that the lint filter slides into or in the vent line,you should clean that out once a year,if the vent line is long i take it off of the back of the dryer and blow it out with a leaf blower,it blows all the lint outside.
    if it is the coils part number 279834 and they are around 20 to 25 dollars
SOURCE:
Haier XQJ50-31 drum quit agitating or spinning
If the timer stopped advancing on one of my machines (laundromat owner) i'd assume it's the timer motor. Kind of like when a top loader has no final spin but otherwise runs okay i always suspect the timer mechanism. For me it's a simple check; exchange timers with a neighboring machine. You probably don't have that option. Unfortunately, I don't know the Haier Brand of machines so i could be wrong.
Dec 23, 2012 | Haier XQJ50-31 Top Load Washer
Frigidaire FWT647GHSO when it gets to rinse first rinse cycle, it doesn't stop filling with water. It won't agitate or spin. It works well in the wash cycle, agitates and spins and advances
probably you've got something blocking the water pump from doing its job properly so check that the water pump is free running emptying all the water if not then there is a blockage in the pump normally ist a button, paper clip or other debris out of a trouser pocket eric
Dec 25, 2017 | Frigidaire Washing Machines
How to move around brandt wm 550
see this causes and fix it. God bless you
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Sep 22, 2012 | Washing Machines
Won't start and overheating
Hi Beverly Johnson...
Your problem is possibly a Clogged Vent
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry.
But...if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Heating Element
Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace the heating element. You can check for an ohm reading but will need to refer to the service manual for proper reading. This sometimes on the tech sheet located somewhere on the dryer. Usually between 9-13 ohms.
Cycling thermostat
Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork . This thermostat usually has four wires going to it. Check the 2 terminals that are opposite each other and are the closer together of the 2. These 2 terminals should have continuity. If not replace the thermostat.
Sep 19, 2012 | Whirlpool Dryers
Kenmore dryer 110.86864100 - Where is the moisture sensor?
Ain't no moisture sensor. This is is not an electronic sensing machine. It uses another method to determine dryness. An orange wire connects to the base of the heating element. The timer motor is driven by power from it in auto dry. The timer motor is VERY slow. Slower than most dryer timer motors.As the clothes get dryer the heat is not needed so the element is turned off by the control thermostat which is mounted next to the skinny white fuse on the blower housing. This allows for the turtle like motor on the timer to advance. Once the clothes get to the point of dryness the heater stays off way longer and the timer motor advances on over to the cool down and carry on over to the end of cycle. So the clothes won't always be dry due to factors like lint buildup in the blower housing, venting to outside and so forth. having said that my mom bought a brand new Kenmore dryer and I set it on 55 minutes timed drying. At the end of that them clothes is still damp. I then set it to auto dry high heat and that usually gets em dry. I think the main probo with this dryer is the thermostat ain't set as high as older models to keep the heat at a moderate temp so that the limits won't blow on models in apts and such. Just a theory.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 16, 2012 | Kenmore 659 Electric Dryer
Beko WMP652W washing machine will start cycle but get stuck at end of wash, doesnt go onto rinse or spin any help please?
see the next steps and use the common sense: God bless you
Aug 01, 2012 | Washing Machines
Water fills in, but wash cycle won't start. spin cycle works, changed motor still won't work
Its either in the lid switch or timer. Examine the lid switch. Try starting the wash cycle and press in on lid switch to make sure it activates. If the lid switch is good and you dont hear the motor trying to activate during wash than its in the timer. Does the timer advance? Please comment me back If you need further assistance.
Jul 28, 2011 | Maytag Atlantis MAV6000 Top Load Washer
Calypso will not advance past wash cycle. I have a Calypso GVW9959K washer that displays no error codes and will run all functions in test mode. Problem is - it will run forever in the wash mode (clock...
If the machine is filling and washing but not advancing then the timer mechanism is not fuctioning. There is no codes so all other parts must be working, likke the pressure switch. You might test the door or lid switch this can sometimes hang these up. to test simply jump across the switch with a jumper wire. Basically
  • If the washing machine fills with water and begins agitating, but the timer does not advance, the timer probably needs to be replaced
  • If the timer does not advance while the washer is in a spin cycle, the timer probably needs to be replaced
  • I am supplying the service manual for this machine. Please be careful when attempting any repair and always make sure the machine is unplugged before starting any repair. This manual include service guides for testing components as well if your capable of these tests. The link will lead you to the manual. These manuals are not easy to come by due to the fact they are meant for service personell who make a living on these so it is inclusive and should help you in you issue.
  • https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2c1e295a88aaaae885256c5d004632a4/$FILE/8178010.pdf
  • May 13, 2011 | Washing Machines
    Only can use the heavy wash cycle
    HELLO THERE
    The cycle doesn't advance or you are unable to use one of the cycles such as light or the normal wash cycle, your problem normally is caused by a bad timer It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance.and if you set it to the normal cycle or light cycle and nothing happens Then you need to replace the timer. ok? hope this is veery helpful for you
    Best regards Michael
    Jun 05, 2010 | Jenn-Air 24 in. JDB1090AWS Stainless Steel...
    Kenmore 11070702990 Gas Dryer - Timer does not work
    • The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
    • When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
    • The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
    This cycle continues until the clothes are dry. But…if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
    May 09, 2009 | Kenmore 60172 Electric Commercial Dryer
    Dryers Logo
    226 people viewed this question
    Top Roper Dryers Experts
    Sal De
    Craig Butler
    Craig Butler
    Marvin
    Marvin
    Are you a Roper Dryer Expert? Answer questions, earn points and help others
