Question about Pioneer Car Audio & Video
Pioneer KEH P9800R display
Display went blank.
SOURCE: Pioneer KEH-P6600 diplays "error-11"
use your user guide to read the problem related to error 11 .. most probably your wire connecting your changer witht he head uint is either cut or not functionall ... hope that answers the question
Posted on Jun 25, 2007
  • 40 Answers
SOURCE: PIONEER SUPERTUNER 3 KEH-P4200
tdohnke-So you need a wiring diagram,well lets see what we got
red-accessory-12volt key switched
orange-12volt constant-memory
black-ground
white-left front speaker-positive
white with black stripe-left front speaker negative
grey-right front speaker-pos.-
grey w/black stripe-right front-neg.
green-left rear-pos.
green w/black stripe-left rear-neg
purple-right rear-pos.
purple w/black stripe-right rear-neg.
blue- remote turn on
orange w/white stripe-dimmer-optional
Try out this diagram,they are pretty much all the same now,if I missed any let me know. cooltek Mar,4/08
Posted on Mar 04, 2008
  • 85 Answers
SOURCE: PIONEER P5450
Tiny led bulbs behind fascia face need replacing
Posted on Jan 08, 2009
ar15guy
  • 3 Answers
SOURCE: Trying to hook up a pioneer car stereo model # KEH M8550
Depends on the type of car you have. Do you have a harness or are you going to splice all the wires? Does your car have a premium sound system? Are you going to run an amplifier now or later on in the future??
Posted on May 04, 2009
Larrysito
  • 73 Answers
SOURCE: screen display blank
vga chip damage posible tu fix in london 3 tottrnha street ...micromend
Posted on Aug 30, 2009
Pioneer keh p6025
You need an extra part to use the AUX function, part number CD-RB20 or CB-RD10. You then have to turn the function on in the settings:
1) Press FUNCTION to select AUX.
Press FUNCTION repeatedly until AUX appears
in the display.
2) Select AUX on or off with 5.
Pressing 5 will switch AUX between on and
off and that status will be displayed (e.g.,
AUX :ON).
Dec 18, 2013 | Pioneer Car Audio & Video
Light display is working very low in pioneer keh p8600r. can i solve it by myself? thanks
Go into your menu for the deck, There should be a setting for the (Brightness) From 1 to 10
Oct 24, 2012 | Pioneer Car Audio & Video
PIONEER P5450
Oct 18, 2008 | Pioneer KEH-P5600 CD Changer
Setting clock
Display the time by pressing the Clock button below the 1+2
Adjust the hour by holding Clock and press 1 as many times as necessary.
Adjust the minute by holding Clock and press 2 as many times as necessary. Seconds start at 0 when you release the clock button.
Oct 04, 2008 | Pioneer KEH-1700
Hi, I need a wiring diagram for a Pioneer KEH-P3630R Radio/Cassette system
s.gif Faisceau avec connecteurs ISO pour autoradio PIONEER 12 broches
NEUF SOUS BLISTER
16 broches sur ISO - Dimensions de la prise environ 43 x 8 mm
Détail des câbles des haut-parleurs :
Blanc : HP avant gauche +
Blanc/noir : HP avant gauche –
Gris : HP avant droit +
Gris/noir : HP avant droit –
Vert : HP arrière gauche +
Vert/noir : HP arrière gauche –
Violet : HP arrière droit +
Violet/noir : HP arrière droit -
Détail des câbles d'alimentation :
Jaune : Permanent + 12 V batterie
Rouge : Alimentation + 12 V après contact
Noir : Masse
Bleu : Antenne motorisée
cote_g_olitec_j.gif Liste des autoradios compatibles :
cote_g_olitec_j.gif Série KEH cote_d_olitec_j.gifKEH-1100SDK
KEH-1150SDK
KEH-1200SDK
KEH-1300K
KEH-1300R
KEH-1300SDK
KEH-1311
KEH-1400R
KEH-1400SDK
KEH-1450
KEH-1450R
KEH-1500
KEH-1500R
KEH-1530
KEH-1530R
KEH-1540
KEH-1700
KEH-1700R
KEH-1730
KEH-1730R
KEH-1800R
KEH-1830R
KEH-1900R
KEH-1930R
KEH-2100R
KEH-2300R
KEH-2400R
KEH-2500
KEH-2500R
KEH-2520R
KEH-2530R
KEH-2700R
KEH-2710R
KEH-2720R
KEH-2730R
KEH-3400
KEH-3520R
KEH-3700R
KEH-3710R
KEH-3720R
KEH-3730R
KEH-4400R
KEH-4500R
KEH-4530R
KEH-4700R
KEH-4730R
KEH-5700R
KEH-5730R
cote_g_olitec_j.gif Série KEH-P
cote_d_olitec_j.gifKEH-P26R
KEH-P27R
KEH-P28R
KEH-P2800 R
KEH-P2830R
KEH-P3300 R
KEH-P3400 R
KEH-P3600 R
KEH-P3630R
KEH-P3700R
KEH-P3730R
KEH-P4300R
KEH-P4400R
KEH-P4500R
KEH-P 4510
KEH-P4530R
KEH-P4600R
KEH-P4610R
KEH-P4630
KEH-P4630R
KEH-P4700R
KEH-P4730R
KEH-P5700R
KEH-P5730R
Jul 14, 2008 | Audio Players & Recorders
Pioneer radio clock
as per pioneer site there is no model with number KEH4950,so how do i guide you ?
generally clock setting on pioneer sets( latest ones )is as follows:1)turn the car ignition ON (2)press multicontrol until display shows the blinking clock.(3)use multicontrol (press left or right to control hour or minute segments.(4)press multicontrol again to finalise and start the clock .
May 28, 2008 | Pioneer CDX-FM687 6-Disc CD Changer
Setting clock
Setting the time
This is used to set the time on the unit’s clock
display.
1 Press AUDIO to select the time.
Press AUDIO until the time appears in the display.
2 Select the portion of the time display you
wish to set with
2/3.
Pressing 2/3 will select a portion of the clock
display:
HOURMINUTE
As you select portions of the clock display the
portion selected will blink.
3 Select the correct time with 5/.
Pressing 5 will increase the selected hour or
minute. Pressing ∞ will decrease the selected
hour or minute.
Mar 30, 2008 | Pioneer KEH-P4020 Cassette Player
Jun 25, 2007 | Pioneer KEH-P6600 Cassette Player
Car Audio & Video Logo
78 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
