Question about Sharp LC-32GA5U/LC-32GA5E 32 in. HD-Ready LCD Television
Sharp Aquos LC-32GA3E turning off and on
Hi, my Sharp Aquos LC-32GA3E TV occasionally turns itself off and then on again. I think its a temperature trip. I've cleaned dust from outside of inlet and fan exhaust vents on back which has helped but don't know where any sensor would be inside or whether its worth opening up to clean inside? Is there an obvious component to change?
  • greg343 Sep 18, 2008
    Thanks for the suggestion. The TV is plugged into a Belkin extension block with say 8 outlets on it. When it goes off it goes onto standby and then turns itself back on after 30 secs or so. Could the extension cause that?
    I cleaned a lot of dust off the back which was blocking the inlet vents and across the fan vents as well. I'm no TV repairer but I do build and work inside my PCs. Do you not think it worth taking the back off to clean dust out or is this unlikely to be the problem?
  • sueboogaloo Dec 22, 2008
    We have had ours plugged in for a whole week and now, every couple of hours, it suddenly turns itself off (although the green power light stays on) and then it turns back on about 5-10 seconds later.  There has not been an opportunity for it to get dusty or anything yet.  I will call Sharp in the am and see what they suggest.
  • 50 Answers
This is not i a job you should do your self as it could do more damage than good this would be a job for a tv repair person.
QUESTION FOR YOU : are you running the tv straight from the power in the wall or a extension cord.
as an extension cord could definitely cause this problem too.
Posted on Sep 18, 2008
Do you see the backlight ever coming to the screen?
You will want to open the cover, disconnect the backlight inverter and try again to see if it will stay on even without an image.
If it does it's the inverter.
if it still shuts it's most likely (not guaranteed) either the power board itself or the main board.
A good tech should be able to test the power board independantly fairly quickly.
Jun 30, 2011 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
My tv turns off all by itself
If it can turn on again, it may ok. and you can enter to the service made to see what error is.
Apr 17, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Problem connecting my PS3 to my Sharp Aquos LC-C3237U LCD TV
Your PS3 set itself above the max resolution your LC-C3237U. Most likely the PS3 is doing 1080P, but the highest the Sharp can do is 1080i. So do this:
1. Connect PS3 to TV (you can use the current cable or analog cable)
2. Turn on TV and set input to port PS3 is on.
3. Make sure PS3 is connected via correct cable.
4. Power on PS3 via power button and HOLD IT for 5 seconds (release after the second beep). It should automatically configure your PS3 to the TV's native resolution for all settings.
Sep 15, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Aquos turned itself off and won't turn on again
hi....Your micro chip is faulty check the voltage comming out of the 42nd leg it shuold be 13 volts dc if you are not getting that voltage replace the microchip.and the eeprom IC....
thank u rate me!!
May 24, 2009 | Sharp Aquos LC-15E1U 15 in. LCD EDTV
Sharp LC-37D4U, the monitor doesn't turn on
It is hard to say without first looking at it.
Jun 28, 2017 | Sharp Aquos LC-32D40U Television
RE: Sharp Aquos LCD TV, MODEL LC-37D40U Tried to switch the TV on via remote, and I hear the TV turning on, but then it automatically turns itself off again. Tried it several different ways using...
A component is shorting out, and the TV is auto turning itself off for protection. Usually it is a shorted out horizontal output transistor. Only a tech can fix this.
Nov 13, 2008 | Sharp Televison & Video
No sound on Sharp Aquos 37' LC-37D4U
Call Sharp. They are fixing my 18 month old LC40C32U for free.
Jun 10, 2008 | Sharp Aquos LC-32D40U Television
Aquos Turns off by itself
no. It goes black, then about 5-10 seconds, it turns itself back on.
Jan 01, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
TV will lose picture then go into standby!
Yes it is a temp problem as you found out for your self Great call on that BUD.. the best thing to do is contact sharp to see if they have had simular problems and if there are any recalls on this model . If not they will instruct you where to send the monitor into to be fixed.
Mar 31, 2006 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Sharp LC-32GA5U/LC-32GA5E 32 in. HD-Ready LCD Television Logo
360 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
