Question about Dualit Vario 3 Slices Toaster
Dualit combi heating element 12/95
Yesterday one of the heating elements of my Dualit Combi Toaster serial number 12/95 decided to stop. We use the toaster every day and are very very happy with it. How can I replace the heating element, where can I order it?
Please help
Loppanstruving@hotmail.com
The Netherlands
All the element's are available on e-bay u.k. for about 6.00 gbp. Alternativley you may be able to repair it. Put the toaster on it's side with the bottom facing towards you and the knobs on the top. Remove the crumb tray and then remove the bottom (usually the screws are located in the feet). There may be one more visible screw remove that too, then you will see a rail at the bottom that secures the element's in place. Loosen off the nuts at each end and slide the rail down, undo the two bolt's feeding the power to the element's and slide the element out.Go over it with a continuity meter and see where it's broken then move the element wire about to bridge the circuit.Test it again and reassemble. I repaired mine this way.Or, simply replace the element using the instructions above.Easy!
Posted on Nov 30, 2008
How can i test the elements on my dualit 2slice combi toaster
You can do a visual by looking at them to see if there is a break in it. If they don't get red hot then they may be starting to go. But that usually is not the case because of the properties of the wire. It will suddenly stop working when the wire breaks. These usually are pretty reliable.
Jan 28, 2013 | Dualit Kitchen Appliances - Others
RH end element was not heating to same temperature as middle element. Bought and fitted new end element but still same problem ie this new element still not heating to correct temperature high causing...
the new version has a plastic cover over element wires its best just to change all elements to solve this if you have had this toaster a wile the old elements dont have it,,,make sure its correct ones fitted as they are all different watts ..
Feb 23, 2011 | Dualit Vario Combi 2+1 65-Slice Toaster
The side element in the toatie side of the toaster has failed.
Replacement elements are available on ebay. you can get to the element to replace by removing the bottom of the toaster. not a hard job.
Dec 22, 2010 | Dualit Vario Combi 2+1 65-Slice Toaster
How do you replace a centre element of a Dualit 3 slice toaster?
You can buy the elements from ebay uk and for 110 v also, they are so slim and light that they ship them in normal envelope and arrived in no time.
You can follow the instruction in the link what to order and how to replace.
We have the procedure here in this link
http://www.fixya.com/support/r4472039-procedure_replacing_heating_elements
Good luck
Jun 07, 2010 | Dualit 31213 3Slice Toaster
Dualit 4-slot toaster - is this how it's supposed to work?
your toaster is working correctly if both are off you are in BAGEL/BUN mode ( did i spell that wrong ? ) in that mode it will only toast the cut side .... Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob
Mar 02, 2009 | Dualit Vario Combi 2x2 65-Slice Toaster
Dualit Combi model (made in UK)
service center in US:
Electra-Craft
41 Woodbine St
Bergenfield NJ 07621
phone 201-439-1700 ask for Steve Karow
fax 201-439-1701
info@electra-craft.com
www.electra-craft.com
Oct 28, 2008 | Dualit Vario 3 Slices Toaster
Blown element...I think?
Where is SW18 located? What country? I would make an estimate that repairs would cost more than a new toaster
Loringh
Oct 25, 2008 | Kitchen Appliances - Others
Dualit Vario 3 Slices Toaster Logo
486 people viewed this question
Top Dualit Kitchen Appliances - Others Experts
Ross Keen
Piyal Perera
Piyal Perera
Joseph Hoffmann
Are you a Dualit Kitchen Appliances - Other Expert? Answer questions, earn points and help others
