If the water empty light is staying on when the water tank is full in your Polti Pro95 steam cleaner, it could be due to a malfunctioning float valve or a faulty water level sensor.
Here are some steps you can take to troubleshoot the issue:
- Check the float valve: The float valve is responsible for regulating the water level in the steam cleaner. If it is stuck or malfunctioning, it could be causing the water empty light to stay on. To check the float valve, remove the water tank from the steam cleaner and inspect the valve for any signs of damage or blockages. If the valve is damaged or blocked, replace it.
- Check the water level sensor: The water level sensor is located inside the steam cleaner and is responsible for detecting the water level in the tank. If it is malfunctioning or faulty, it could be causing the water empty light to stay on. To check the water level sensor, you will need to disassemble the steam cleaner and inspect the sensor for any signs of damage or wear. If the sensor is damaged or worn out, replace it.
- Check the wiring: If the float valve and water level sensor are functioning properly, the issue may be with the wiring. Check the wiring between the sensor, float valve, and control board for any signs of damage or wear. If you notice any issues, repair or replace the wiring as needed.
If you are not comfortable performing these troubleshooting steps, it is recommended to take your Polti Pro95 steam cleaner to a certified repair technician for further diagnosis and repair.
