Question about Tascam 2488mkii 24 Track Recording Workstation
Tascam 2844 mk2 24 track recorder
I accidently fryed the power board! dont ask! i can fix it. but i cant see the code/ number on the resistors. would you know or be able to find out what type they are?
What are the Behringer BXL 1800A most common problems?
If you overload them the output MOSFETs fry and tend to take the circuit board and a few resistors out. They are fixable but it's a pain hat the board fries. The tracks need building up with wire so they can carry the necessary current (or any once they fry). Apart from that they are a decent Amp for little bucks and sound pretty good. They'll need micing for anything but smaller venues but the functions are really useful in getting a good sound for the buck.
May 18, 2014 | Behringer Europower Pmp5000 Powered Mixer...
If I plug in powered monitors to the digital input... will it get rid of my error code 02 displayed on the screen ?
Never go from a PA (powered (amplified)) speaker signal to the inputs of a recording device. This can severely damage the electronics of the input/preamp. That error code may be getting caused by something else. For more details on how to use digital ins:
http://en.wikipedia.org/wiki/S/PDIF
Apr 13, 2012 | Tascam 2488NEO 24 TRACK RECORDING...
Buying a used Tascam 788. P.O. lost the power supply. How can I get a replacement? Couldn't find anything on TASCAM site.
Hi, Provided there is a tag on the back showing the units model number, on that same tag should be the power requirements for it-buying a universal power supply, or even a used working one to another piece of equipment is acceptable as long as the polarity is the same. Polarity is located right next to where the power supply plugs into the unit. It will be a " circle with a dash inside it with a line connecting to a C looking symbol with a line coming out of it connecting another circle with a plus sign inside. " that is a typical outer ground/inner positive marking. a power supply will be marked the same. If they match the polarities are the same. Next make sure the power supply says the proper DC voltage and Milliamps or amps-Ma/A example: 2400Ma, 2.4a. I hope this helps and thank you for asking FixYa, good luck and don't forget to write back and let me know how I did, Prodzilla.
Apr 23, 2011 | Record Tools Tascam Dp02 8 Track Digital...
How to load music to a tascam 2488neo
I think if you had the manual you would know the answer.
Register and download the manual for free at audio.manualsonline.com
Search for "Tascam Portastudio 2488"
http://music.manualsonline.com/manuals/mfg/tascam/2488neo.html
Jan 11, 2011 | Tascam 2488mkii 24 Track Recording...
I want to buy a Tescam 2488neo. But i got a question before I buy it. Question- Can I record songs or musics multi-times? I mean, record acoustic Guitar first, and then record ...
Here is a link for you to look at:http://www.tascam.com/products/2488mkii.html Look under resources to download the manual or a Beginners Guide to Recording.
Aug 28, 2010 | Tascam 2488mkii 24 Track Recording...
How can i assign diferent effects to indivdual tracks?
It's tough. For all that TASCAM touts this is not a user friendly system. I find that assigning compression to one track, removes my reverb from every track. It seems only one effect can be used at a time, and that effect effects them all. Tascam sucks. Never again!
May 04, 2010 | Tascam 2488mkii 24 Track Recording...
Conn organ powering on but not playing any sound
Check for a problem with the expression pedal. Some have a light and photo resistor and lamp burns out.
Feb 27, 2010 | Tascam 2488mkii 24 Track Recording...
Just bought a new Tascam 2488 portastudio. Following directions to record first song, but I can't get sound through either headphones or monitor outputs. I know I have a signal because I can overdrive it...
Read page 19 under Monitor section.You have to assign the signal to the monitor output you want. Page 36 has the details. All the info you need is here with some updates:http://www.korg.com/product.aspx?pd=191
Jul 26, 2009 | Tascam 2488mkii 24 Track Recording...
The unit will not boot up.
Hi Jerry, I had that same message come up and like you I hadn't used the mkii that much...I was able to reach a tech at tascam and he gave me the following advice and it should reset the unit;.
Here's what he said to do; first you power off and then you hold down the following buttons;
quick rout button....shift button....send button...and the shut down button.....while holding down these 4 buttons turn on your unit.....when it says initialize..let go and hopefully it will reset....
Hope this helps JP
Jan 09, 2009 | Tascam 2488mkii 24 Track Recording...
Tascam 2488mkii 24 Track Recording Workstation Logo
228 people viewed this question
Top Tascam Music Experts
Michial Gueffroy
Computer Links
drivealot
Are you a Tascam Music Expert? Answer questions, earn points and help others
