Computers & Internet Logo
Posted on Apr 06, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cao Bogdane Imam jedan problem. Naime, treba da izvrsim jedan eksperiment sa merenjem temperatura pomocu termoparova. Termoparove sam prikljucio na HP 3497 akvizicioni kortroler. Taj HP prikljucujem pomocu 488 veze sa PC preko ISA kartice (iee 488 card). Problem je u tome, sto nikako ne mogu da intsliram tu karticu da radi pod XP. Imas li neko resenje? I znas li neki program pomocu koga cu moci da ocitavam ta merenja. Neke programe sam ja pisao u qbasic. Instalirao sam Labview, ali cini mi se da je on dosta kompleksan. Treba mi neki jednostavan program, po mogucstvu sa vizuelizacijom. Hvala unapred Milos Obrenovic [email protected]
Larry Ng
Level 3:
Top Expert:
  • Compaq Master 14,606 Answers
  • Posted on Jun 29, 2017
Larry Ng
Compaq Master
Level 3:
Top Expert:
Answers
14606
Questions
0
Helped
3280243
Points
66651
Never put email here ,ever, or get SPAM endless for 100 years. wow.
this is an English forum.,
here I used google translate for you
quoted and commented:
"I have one problem.
Namely, I need to perform an experiment with temperature measurement using thermopar. ?????????
I plugged the heaters into the HP 3497 acquisition cortex.
I connect this HP via IEEE488 connections to PC via ISA card (iee 488 card).
WE DONT USE ISA card today, in USA> and software for this is hard to find in year 2017,
The problem is that I can not intimidate that card to work under XP.
WE DONT USE XP today in USA it's a VIRUS MAGNET>!
Do you have any solution?
And do you know a program by which I can read these measurements? I wrote some programs in qbasic.
I installed Labview, but it seems to me that it's quite complex.
I need some simple program, possibly with visualization.
ITS NOT SIMPLE at all to make 488 work.
Thanks in advance
My guess, is you are trying to use HP-IB (IEEE488) communications, cables ( a parallel 2 way comms)
to some ?instruments.? (ask the instrument maker yet)
My guess they are long ago no longer in business or the products are long long gone now.
why not tell the full information on this instrument./?????
makers name, and model #
that takes working software on the PC side.
(drivers for the ISA, and APPS to run it)
the Maker of the instrument would have APP software to run that.
ask them?
if not, you get to write your own software,
and would need the IEEE488 comms library to do that ,and buy it.
you';d also need the book in the instrument in order to learn
the IEEE488, command sets , and address and data forumats.
or its impossible.
2 Related Answers
Anonymous
  • 198 Answers
  • Posted on Jun 19, 2008
SOURCE: pozz
please re-post the question in english because unfortunately i don't understand exactly the nature of the problem.
From what i get, i think you have a problem with the touchscreen allignment wich seems to be out of phase. This is mostly a hardware problem between the touchscreen controller and the motherboad. Also, a touchscreen has a finite life span and will loose accuracy over time and fail completely in the end. You should try a hard reset for your dell, (this will erase all the data stored on it and replace it with factory defaults). If this doesn't work, most probably the only way to save the device would be to have the touchscreen or lcd-touchscreen unit replaced in a service center.
Hope it helps.
Anonymous
  • 130 Answers
  • Posted on Mar 02, 2011
SOURCE: ne mogu da otvorim eksterni
Jos ako se cuje klik-klik onda je hard drive spreman za put na otpad. Pokusaj ovo: Klikni desnim dugmetom na ikonu My Computer-manage-storage-disc management.Svi hd koje imas trebaju biti tu,Ako nema eksternala-ugasi ga/ili iskljuci iz struje-sacekaj minutu-opet ukljuci,Pogledaj status:Ako jos uvijek zahtijeva formatiranje i samo formatiranje-onda je crko.Jos jedna stvar: Na ovoj stranici glavni jezik je Engleski. Da nisam slucajno naletio da vidim sta se desava,jos bi ti cekao.Sretno i javi sta se desava!
2helpful
Imam hp pavilion dv 7 laptop i u njemu ugradenu kameru hp webcam ali ju nemogu ukljuciti
Sve u svemu, izgleda mi da treba da instaliras nove drajvere. Nasao sam ove sajtove, ali molim te prvo proveri koja verzija windowsa imas (32 bitna ili 64bitna) Mozes da proveris za desni klik na iconu My Computera i selektiranjem Properties. Trazi nesto gde pise 32bit operating system ili 64 bit operating sistem. Ondak skini nove drajvere sa ove linkove
32 bitan - http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=ob-75835-1&lc=en&dlc=fi&cc=fi&lang=fi&os=4062&product=3939026
64 bitan - http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=ob-75835-1&lc=en&dlc=fi&cc=fi&lang=fi&os=4063&product=3939026
skini odgovarajuche i sa srecom :)
Kako da sa samsungaL700 prebacim slike na racunar
1.treba ti drajver za tal tel. 2. treba ti USB konektor za samsung..
Ne mogu da otvorim eksterni hard disk WD1600. Govori mi da treba da ga formatiram.Prije toga je radio i imam dosta podataka na njemu.
Instalirao sam win 7,muzicka kartica ne radi kako treba,kada je pustim na test,cuju se svi zvucnici odlicno (5+1),kada pustim film,crtani,muziku preko bilo kog programa (plejera) cuju se samo 2...
ako ste dr?ali xp sistem pokrenuti u njemu zvu?i kao da win 7 nije uskla?en sa zvu?ne kartice. Win 7 a?uriranje drajvera za tu specifi?nu karticu preuzetu? Ja ne govorim bosinan tako da prelazim na google. Koja je souind karta? google model za nadogradnju 7 ako ve? niste. Nadam se da ?e to malo pomo?i.
Aleksandar
Na google ukucaj "sweex web cam driver download" i dodaj jos konkretan model tvoje kamere. Ako ne kazes tacno koja je ne mogu ti pomoci vise od ovoga.
Pozdrav!
Top Compaq Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
