I have a motherboard that support up to 900MHz, can i use a 1GHz CPU with it?
    President:
  • 778 Answers
I would say no, since 1GHz is greater than 900MHz by 100MHz and you state that *********** Board only supports up to 900MHz.
Posted on Sep 18, 2008
Is there a cpu upgrade for an hp pavilion 6835 with a motherboard 115561 cognac 20000731
The fastest Pentium 3 that will work in your board is a Intel Pentium III 1GHz chip. Here is a link to the specs:
http://www.cpu-world.com/CPUs/Pentium-III/Intel-Pentium%20III%201000%20-%20RB80526PY001256%20%28BX80526F1000256%29.html
You could also get a Intel Celeron 1.1 GHz but it only has half the level 2 cache size so it's actually a bit slower than the Pentium III 1GHz chip.
Here's a link to celeron specs:
http://www.cpu-world.com/CPUs/Celeron/Intel-Celeron%201100%20-%20RB80526RY005128%20%28BX80526F1100128%29.html
May 23, 2012 | Powerleap PL-NEO/T Celeron, 1.4 GHz...
Driver for mainboard sv266a free dounload cpu 900mhz amd
http://driverscollection.com/?H=K7VTA3&By=ECS%20(Elitegroup)
same board sold under another name.
Jan 19, 2011 | AMD KT266A DDRAM (SYNTAX - SV266AD)...
I have bought a PIII 1Ghz CPU to replace my armada 110 Celeron 700MHZ CPU, Sometimes it works well for about an hour then just turn itself off, other times only lasted a few minutes. I've noticed that the...
With out knowing your motherboard it's a guess. However you can look at the link below. Then scroll to the bottom of the page. Your SL52R should be the 4th cpu from the bottom of the list. It doesn't look likely and it definitely runs hotter. http://www.cpu-upgrade.com/CPUs/Intel/Pentium_III/RB80526PY700256.html
May 30, 2017 | Compaq Armada 110 Notebook
Can I upgrade a dell 900mhz p3 processor
Not really [ only possible might be to a faster P3 cpu]. Those motherboards are so old it would be cheaper to just buy a new system as Dell cases & power supplies, etc for that old a computer are all proprietary and would take major modification to upgrade to a new motherboard, ram, cpu and such. Hope this helps.
Jul 17, 2009 | Dell (6d514), 900 MHz Processor
My processor's clock speed is 2.53ghz, when i boot up my computer's processor actually runs at a 2ghz clock speed intel ID utility detected it but after 10mins or so my processor's clock speed drops down...
The reason for this is because you CPU needs to run only at 1Ghz at that particular moment. see the more programs you run, the more processing is needed. No if your computer is on Idle then the or have programs like word or excel running the processing is less. so the CPU automatically reduces the processing speed. this way the CPU is energy efficient. you have nothing to worry. this is a feature that Intel has added to the newer generation of CPU's
May 13, 2009 | Computers & Internet
Installed Upgrade CPU - Computer Will Not Boot
are you sure that the CPU artitucture is correct for the motherboard that your putting the processor into?, just because it fits doesn't always mean it will work,
Mar 12, 2009 | Computers & Internet
Find maximum processor size for aopen ax34-u motherboard
u wont be able to install a cpu much faster than 1ghz without flashing the bios.....
if you do not know how to do this then plz do not attempt it as if it geos wrong or you have a power surge then the mobo will be NFG.......
Feb 24, 2009 | AOpen AX34-U Motherboard
Up-date processor.
Check the manual for jumper settings on the cpu frontsidebus frequency. Also find out your cpus fsb or frontside bus speed and match it with the motherboards jumpers if possible.
How to find out details of the processor?
Pentium III 1ghz - download cpuz www.google.com cpuz download
it will tell you more details of the cpu. If you post here a image of the cpuz screen or all the details it shows you can I tell you the correct fsb speed.
Then you need to find your motherboards manual and the part about those jumpers. and set them correctly.
Feb 15, 2008 | ASUS SiS Chipset CUSI-FX Motherboard
Toshiba 4600 - replace P3 700mhz with P3 1ghz
No you can't pull out as the CPU is surface mounted soldered on the mainboard, only manufacturer or approved repairer can take it out and put the new CPU with only the correct voltage specs.
don't try yourself otherwise you will damage the entire laptop.
Dec 12, 2007 | Dell Inspiron 1100 Notebook
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
