Question about Motorola Mobility RAZR V3
Brand new had it for about 2 weeks.
I was going online after I ended a call and all of the sudden it turned off and on again, showed the motorola logo and then the screen went blue, that's as far as it gets. is this normal? My girlfriend mentioned a reset button or switch. Colls.
  • 4,889 Answers
After the bluescreen appears press: middle button > 1x down > select > 5x down > select > 2x up > select > enter pin (6 zeros if you don't know it) > select > top left key
Follow the exact sequence and it will factory reset your phone. You may have to try this multiple times. Caution:This will delete all the contacts, msgs etc on your phone. So make sure you connect it to a comp and back up your data first!
Good Luck!
Posted on Sep 18, 2008
Electrolux ac e6 error code Showing error code and then suddenly ac stops working Previouslt it showed e4 code similiarly but technician came and fixed it pls help Ac's brand new only 2 week old
When the technician already had to clear one error and within 2 weeks you should call again for another error, I would ask for a new one. It is supposed in warranty but still twice in 2 weeks is too much.
Don't try to solve it yourself. call the shop where you bought it.
May 05, 2015 | Miscellaneous
My moto ROKR E6 dont take charge from charger or USB....i bought this phone 2 weeks back...brand new
You can try a reset and recharge it again, if that does not resolve the problem contact manufacturer for repair options.
1. For soft reset type *#7780#
2. Try to recharge the unit again
3. If issue persist contact manufacturer or vendor for repair options
Jul 11, 2011 | Motorola Mobility ROKR E6 Smartphone
Brand new Dell Vostro 430, in troublefree use for two weeks, sudden does not start up any more. After turning the Vostro on: - it shows the startup screen with the Dell-logo in the center, the intel...
Press DEL on startup and select "last best known config that worked" If that doesn't work you have probably corrupted the Win registry.Will need to take back to store, beware that if its a software fault you will have to pay and may lose all your data n the HDD!!!
Oct 16, 2010 | Computers & Internet
Iphone will not turn on
Here are the steps to reset the iPhone. You probably performed the first reset, try the other resets.:
If iPhone won't turn on, or the display freezes or doesn't respond
  1. Press and hold the Home button for at least six seconds, until the application you were using quits.
  2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for a few seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  3. If that doesn't work, reset iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears
More resets:
Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jun 30, 2009 | Apple iPhone Cell Phones
W490 Motorola inital screen comes on, then goes black.
There is usualy no certain way to tell whats to blame on a bad phone without testing, but in your case I think that it is your phone that is malfunctioning. A low/bad battery either doesn't turn on or if it does it will at leat allow the phone to go on and then displays low battery before shutting off.
If you are out of warranty period, then you can easily flash this phone fo much cheaper than purchasing a new one. I would ecoment that you first take it o a repair place to be examined.
Mar 11, 2009 | Motorola Mobility W490 Cellular Phone
Blank or White screen on new Motorola Krzr k1 cell phone
Take the phone to a mobile service center and have the flexcable replaced on the phone.
Dec 04, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
I have a Motorola W490, and about a week and a half ago, and the phone is brand new, like a month old, and the problem started with the screen freezing a lot, and when I tried to close it, it still had th...
i'm so pissed i am in the exact same situation. i've only had my phone since late may, and haven't had too many problems with it. then last week it all began. i would set the phone down for a while, and whenever i would go to flip it open the screen would be either black or white. i then have to press a bunch of numbers or turn my phone off entirely to get it going again. yeah it's a piece of ****. ii've heard a lot of motorola phones have this problem. i'm going to take mine in and see if i can get a replacement. i also heard this just happens with a lot of flip phones, but i don't want to spend the $200 or so on a sidekick. blah. sorry i'm not much help, but i just wanted to let you know you're not alone.
Aug 03, 2008 | Cell Phones
Nokia 3230 start-up failed
Hi, Format the Mobile set, using 4 Keys combination : Press(1) *, (2)Dial Key, (3) 3 & hold it & press (4) power on switch.] bye
Sep 11, 2007 | Nokia 3230 Cellular Phone
Motorola Mobility RAZR V3 Logo
41 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
