Question about Microsoft Windows Vista Ultimate Edition
Command prompt There is no working of maximization.
    Guru:
  • 1,049 Answers
Vista will not allow you to full screen a command prompt without some tweaking. Instructions are provided here.
Posted on Sep 18, 2008
Remove virus
Insert your USB drive in the appropriate USB slot in your computer.
If the Autoplay dialog box appears, select "Take No Action" and click the "OK" button.
Launch your anti-virus program, such as AVG Antivirus or Anti Malware.
Select the USB drive for the program to scan.
Click the "Start Scan" button or option.
Open the scan history for the USB drive when the scan is complete to see a list of viruses and warnings identified by the antivirus software.
If desired, select the options to "Heal All Infected Files" or "Move the Infected Files to the Virus Vault" to ensure these files are quarantined from your system.
Highlight each infected file in the scan history.
Write down the file name of each infected file identified on the USB drive.
Minimize the application's window.
Select "Run" from the Windows "Start" menu. In the Run window, type "e:/" at the command prompt to switch to your USB drive (or type the drive letter for your USB drive).
Press the Enter key.
Type "attrib -s -h -r -a *.*" at the command prompt to remove the system, hidden, read-only and archive file attributes.
Type "del ####.+++" where "####" is the file name of the infected file and "+++" is the file extension, at the command prompt line.
For example, "del terriblevirus.exe" will specifically delete the Terrible Virus executable file. Repeat for each infected file on your list identified in Step 4.
Close the command prompt window; that is, exit the Run utility.
Maximize the window for your anti-virus program (which is still open) and repeat Steps 2 to 7 until no virus is detected on your USB drive.
Exit the anti-virus application.
or Click start click on my computer you should see your usb drive right click then select format.
another way is to control panel administrative tools computer management disk management Right Click on your drive select format
Oct 22, 2013 | Toshiba Computers & Internet
Tip
How to Install windows 7 by using usb flash drive, pen driver or usb harddisk.
Friends i have seen thousand of laptop cd/dvd rom stops working very soon. then the quesion is how you do intall your os if it was corrupted.
follow my tip and install windows7 or vista in very simple way.
a) first insert your usb flash drive or hdd in usb port
b) then open commandprompt from accessories with rightclick run as administrator
c) you must know what is drive letter of your usb flash drive.
d) type DISKPART in command prompt and press enter
e) then type LISTDISK in command prompt
f) Next type all the below commands one by one. Here I assume that your disk drive no is “Disk 1”.If you have Disk 2 as your USB flash drive then use Disk 2.Refer the above step to confirm it.
So below are the commands you need to type and execute one by one:
SELECT DISK 1
CLEAN
CREATE PARTITION PRIMARY
SELECT PARTITION 1
ACTIVE
FORMAT FS=NTFS
(Format process may take few seconds)
ASSIGN
EXIT
g) Next insert your Windows7/Vista DVD into the optical drive and check the drive letter of the DVD drive. In this guide I will assume that your DVD drive letter is “D” and USB drive letter is “H” (open my computer to know about it).
h) Maximize the minimized Command Prompt in the 4th step.Type the following command now:
D: CD BOOT and hit enter.Where “D” is your DVD drive letter.
CD BOOT and hit enter to see the below message.
i) Type another command given below to update the USB drive with BOOTMGR compatible code.
BOOTSECT.EXE /NT60 H:
J) Copy your Windows 7/Vista DVD contents to the USB flash drive.
Eject the usb drive and select first boot device usb drive or usb hdd in motherboards bios.
enjoy... and please rate this trick.
on May 11, 2010 | Computers & Internet
Tip
INSTALL WINDOWS 7 USING USB PEN DRIVE !!!!!!!!
Requirements:
*USB Flash Drive (Minimum 4GB)
*Windows 7 or Vista installation files.
Follow the below steps to create bootable Windows 7/Vista USB drive using which you can install Windows 7/Vista easily.
1. Plug-in your USB flash drive to USB port and move all the contents from USB drive to a safe location on your system.
2. Open Command Prompt with admin rights. Use any of the below methods to open Command Prompt with admin rights.
*Type cmd in Start menu search box and hit Ctrl+ Shift+ Enter.
Or
*Go to Start menu > All programs > Accessories, right click on Command Prompt and select Run as administrator.
3. You need to know about the USB drive a little bit. Type in the following commands in the command prompt:
First type DISKPART and hit enter
Next type LIST DISK command and note down the Disk number (ex: Disk 1) of your USB flash drive. In the below screenshot my Flash Drive Disk no is Disk 1.
4. Next type all the below commands one by one. Here I assume that your disk drive no is “Disk 1”.If you have Disk 2 as your USB flash drive then use Disk 2.Refer the above step to confirm it.
SELECT DISK 1
CLEAN
SELECT PARTITION 1
ACTIVE
FORMAT FS=NTFS
ASSIGN
EXIT
Don’t close the command prompt as we need to execute one more command at the next step. Just minimize it.
5. Next insert your Windows7/Vista DVD into the optical drive and check the drive letter of the DVD drive. In this guide I will assume that your DVD drive letter is “D” and USB drive letter is “H” (open my computer to know about it).
6. Maximize the minimized Command Prompt in the 4th step.Type the following command now:
7. Type another command given below to update the USB drive with BOOTMGR compatible code.
Where “H” is your USB drive letter. Once you enter the above command you will see the below message.
8. Copy your Windows 7/Vista DVD contents to the USB flash drive.
9. Your USB drive is ready to boot and install Windows 7/Vista. Only thing you need to change the boot priority at the BIOS to USB from the HDD or CD ROM drive. I won’t explain it as it’s just the matter the changing the boot priority or enabling the USB boot option in the BIOS.
Note: If you are not able to boot after following this guide means you haven’t set the BIOS priority to USB. If you got any problem in following this guide feel free to ask questions by leaving comment.
on Apr 02, 2010 | Computers & Internet
Fash drive virus
For example, "del terriblevirus.exe" will specifically delete the Terrible Virus executable file. Repeat for each infected file on your list identified.
Maximize the window for your anti-virus program (which is still open) and repeat Steps until no virus is detected on your USB drive.
Sep 25, 2012 | Kingston 1 GB microSD Card with USB 20...
How to find my router IP addess
>Open command prompt by typing CMD on the search bar on your START menu
>on the command prompt type "ipconfig"
>it will show you the ip address, default gateway etc etc...ü
>comments, suggestions, votes and ratings will be greatly appreciated. Enjoy!
Sep 17, 2010 | Computers & Internet
A fake trojan antivirus wiped out my ability to access the internet using both i.e. and firefox. The fake program has been removed and now I want to reestablish the connection to the internet using...
if there is any other software (that your system came with) that was wiped use your recovery disk...now go to start/all programs/accessories/system tools/system restore...you will pick a date (approx 1-2 month ago) restore to earlier date...pick a date click ok...the system will shut / reboot up again and prompt you do wish to continue you must click ok (yes) to the restore date..try your ie or ff
Jul 10, 2010 | Dell Computers & Internet
My laptop keeps showing a microsoft windows that states CEEment and EsAdvRemIntegrator has stopped working.
You will need to open a command prompt in administrator mode. You can do that by right clicking the Command Prompt in the list
Start | All Programs | Accessories
Right click on "Command Prompt "then to "Run as Administrator".
Once you have an administrator command prompt open, type in the following:
sfc /scannow (space between "c" and "/") hit <enter>
Dec 17, 2009 | HP Pavilion dv9000z Notebook
Why c does not support vista in full screen mode and how it is use in full mode
Try running from the command line, All programs, Accessories, Command Prompt, and maximize the command prompt window.
Or use a USB key to install the PortableApps suite on it (www.PortableApps.com) This will allow you to carry your apps with you to run on any computer. One such portable application is the DosBox.
Hope it helps.
Sep 19, 2009 | Microsoft Windows Vista Ultimate Edition
Error8007000b
Here's a fix for Windows Vista Update Error 8007000b and it works (I tried it)
1. Open an Administrator command prompt by right clicking on Start -> All
Programs -> Accessories -> Command Prompt and selecting "Run as
Administrator" and clicking "Allow" for the elevation prompt
(or use run->cmd)
2. In the command prompt, type the command below
cd\
3. Then type fsutil resource setautoreset true c:(If your vista installation is in C: drive)
4. It should say it was done successfully
5. Reboot your system
Jan 16, 2009 | HP Photosmart C6180 All-In-One InkJet...
How to Find the Ethernet Adapter's MAC Address
Follow these instructions to find your adapter's Media Access Control address (MAC address). This is not the same as a Macintosh computer, it is a fixed string built in to the hardware, that uniquely identifies a computer device. Windows 2003 1. Click Start > Run. A command prompt window appears. 2. Type cmd. 3. Type ipconfig/all. (no spaces around the /) 4. Copy down the "Physical Address" (aka the MAC address) on a paper where you keep your network configuration settings. 5. You may close the command prompt window. Windows XP 1. Click Start > Run. A command prompt window appears. 2. Type cmd. 3. Type ipconfig/all. 4. Copy down the "Physical Address" (aka the MAC address) on a paper where you keep your network configuration settings. 5. You may close the command prompt window. Windows 2000 1. Click Start > Programs > Accessories > Command Prompt. A command prompt window appears. 2. Type ipconfig /all. 3. Copy down the "Physical Address" (aka the MAC address) on a paper where you keep your network configuration settings. 4. You may close the command prompt window. Windows 95 and Windows 98 1. Click Start > Run. A command prompt window appears. 2. Type winipcfg. 3. Click OK. 4. Copy down the "Adapter Address" (the MAC address) on a paper where you keep your network configuration settings. 5. You may close the command prompt window. Windows NT 1. Click Start > Programs > MS-DOS Prompt. A command prompt window appears. 2. Type ipconfig /all. 3. Copy down the "Physical Address" (aka the MAC address) on a paper where you keep your network configuration settings. 4. You may close the command prompt window. Macintosh OS (10.3.5) These instructions also work for some earlier OS. 1. Click Apple Menu at top left > System Preferences > Network icon. 2. Select Show: Built-in Ethernet in the pull down menu. 3. Click Ethernet. 4. Your adapter's MAC address is the characters in Ethernet ID.
Feb 19, 2006 | NetGear CG814M Wireless Cable Modem...
Microsoft Windows Vista Ultimate Edition Logo
29 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
