Turned on my Westinghouse SK42H330s - no sound. Picture fine - everything else worked - no sound. Checked all my settings - and yes, the vol. was up and not on mute. I finally unplugged it and when it came back on - the audio was fine. Tell me what happened please. What's going on?
  • seraaj Apr 14, 2009
    Except that my Westinghouse SK42H330s simply stopped sounding. It was on and playing fine, then suddenly stopped making any sound. The picture is fine. I unplugged it, waited about a minute, but the audio has not returned. Anyone know how to fix this barring a trip to the repair shop.
davebies
  • 43 Answers
SOURCE: no picture but has sound
If the screen turns bright blue then you may have a bad blue crt(picture tube) I suggest an on site diagnosis by a Sony ASC to verify if it's the crt. Crt's can run up to $150.00 plus installatin and alignments.
Posted on Jan 23, 2008
  • 4 Answers
SOURCE: No picture
Check the heater power supply. you can find it at the CRT cuircuit at the back of the Picture tube. labeled H1 and H2 check the resistor Bias or re-heat CRT socket.
Posted on May 07, 2008
SOURCE: my tv just quit working
DId you Try replacing the bulb?
Posted on Feb 27, 2009
  • 159 Answers
SOURCE: have picture lose picture tv turns off and on
the lamp has a life cicle. if yours is been used a lot. then the lamp has to be changed. when the tv cannot turn on steady and gets off imm. the computer inside the tv tries to turn off the set but the lamp charges again and the micro tends to keep working. the first step to take in this tv is to change the lamp to eliminate this common source of problems
Posted on Apr 08, 2009
ArcAiN6
  • 152 Answers
SOURCE: no picture
If i am to understand this correctly, this is a rear projection television. Inside there may be 1 - 3 " color " control boards that control the picture before going on to the projector. an accumulation of dust / dirt / debris has adverse affects on electronic componants, make sure they are dust free (compressed air cleans them off quite well. If using a home compressor, make sure there is a vapor filter to remove water from the airlines.)
If they are clean, and as you said you recently had the television serviced to replace the projection lamp, take the television back to the repair shop to have them determine the problem.
If you yourself replaced the projection lamp, be sure to check all connections are properly seated if you had to disconnect something, make sure they are in the proper places, and any connections are securely connected.
If all else fails, have a local electronics / television repair person check the unit for faulty componants.
Posted on May 29, 2009
I have a Westinghouse LTV 32 in HDTV. Have had it for about two years. Last night when I turned it on I got no picture. I can play DVD's but still have no picture. Have tried everything I could think of....
I have a Westinghouse LTV32W6HD. Turned it on and there is no video for about 10 to 20 minutes. When the video comes on there is no sound until I go into the menu and select stereo and internal speaker. Don't know if this helps, but it works for me though my wife doesn't like it.
Sep 15, 2010 | Westinghouse LTV32W6HD 32 in. LCD...
My Westinghouse 36 inch TV has picture and sound when I turn it on but when I change channels, the picture disappears and I have only sound. The picture comes back if you turn the TV off and back on but...
Hello, it sounds like your inverter board is goin out on the set, when you change channels if you notice on almost any TV the screen goes dark and the new channel appears, it sounds like you are not getting enough power out of the inverter board to power up the backlight enough to come on. This is why the sound remains because everything else works fine and the sound is connected to the main board.
Nov 22, 2009 | Westinghouse LTV-27w6 27 in. LCD HDTV
There is no audio on my tv. Picture is fine just
The only quick fix that comes to mind is to go to the "audio settings" in the menu and verify it is set for "internal" and if it is not retrun it to internal. Often this gets switched accidentally to external and there will be no sound without an external amp/speaker system. If you have already checked this, I apoligize for stating the obvious.
Nov 19, 2009 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Wont put out a picture or make sound when turned
turn off your xbox and switch the switch on the video/ audio chord and turn it back on. or just get a new audio/video cord
Nov 04, 2009 | Microsoft Xbox 360 Console
Samsung LCD TV, no picture only sound
is the picture clear when on? if yes, does the screen go black after a few seconds. if yes, sounds like you need a back light inverter!
Sep 13, 2008 | Westinghouse LTV-30W2 Television
LTV-30w2 Backlight problem...goes black
turn light in room off, take a strong flashlight and shine at an angle and see if you can see picture.If you see picture then it is inverter problem.part number 4900506280,I think.
No Picture
Connect the TV thru a Cable Converter that have a Y Pb Pr Connection.
Jun 10, 2007 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Westinghouse ltv 32w4 hdc 32.02 in. hdtv lcd tv / dvd combo
My 42" Westinghouse HDMI inputs just stopped working. I thought it was the TW Explorer 4250HDC issue so I got a new one from TW. Still said no signal from HDMI. So, I shut the TV down and pulled the power cord out of the back. I waited a few seconds and reconnected the pwr cord. The TV "re-booted" so to say and now the HDMI inputs work. I think TVTEK has the right idea that it is firmware/software related. In the mean time, you might want to give that a try.
May 25, 2007 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
