I have an APAC ducted reverse cycle air conditioner Sundowner 11 which keeps shuddering intermitently at the outside unit. I have had a service technician look at it and he has replaced three contacters in the unit and checked the thermostat. He does not what the fault is. He has also by passed the pressure switches to see if this sorts out the problem. But this did not work. he has also checked the board in the unit as well.
  • knottgordon Sep 18, 2008
    The technician has said that the unit is loosing it's signal on an intermittent basis but he can't determine what the cause of the signal dropout is. In answer to your question the shuddering is associated with the fan within the outdoor unit and occurs quite frequently. I can't say that I have heard any clicking noises when the shuddering happens. He has replaced all three contactors in the unit but this has not solved the problem. The pressure switches he bypassed were the heating and cooling pressure switches. He tried to determine if these switches were the problem, he said these switches were ok and took the bypass wires out after the test.
  • TexNOz May 11, 2010
    ACK!! The pressure switches he's "bypassed" are safety switches and should never be left bypassed.
    Can you please describe in great detail what the shuddering sounds and or feels like? Are there any associated noises that occur when it does this, such as a clicking noise?
    Problem Solver:
  • 15 Answers
Listen to see if the contactors make a clicking noise when the fan starts to studder. If not, then it's not the signal to the contactors. If a clicking sound of the contactors can be heard, then the problem is the contactor coil dropping in and out. This could be a lose wire coming from the processor board, or a problem with the board itself. If no clicking is heard and the contactor is definitely not making and breaking the connection, then the problem could be a lose wire feeding power to the motor. This can be traced all the way back to where the power comes into the unit.
Posted on Sep 19, 2008
Model 3812-972 MPPD-14HRN1-BH9
air conditioners are in effect heat pumps
that is they pump the hot air in the room via a gas to the outside area
when that outside are is still inside the room then that hot air is just recirculated
so if you want to heat your room the system is reversed so that you need the hot air outside pumped back into the room
the hot air is provided by the condenser which is now the evaporator in the room as the roles have been reversed so you will have to put the unit in a door way or use the ducting hoses to go out a window
Nov 03, 2015 | Heating & Cooling
How to put my tcl air conditioner on heat
Make sure the unit is a reverse cycle first... It may be a cooling only modle. If its a heat ( reverse cycle ) unit, there will be a symbol which looks like a star, the machine will generally sit with the outside unit running for up to 5 mins before the indoor unit starts. ( Preheat mode) If the unit doesnt start, possibly a failed air or pipe sensor. If it starts but wont heat, possibly a faulty reversing valve coil. Cheers.
Jun 05, 2011 | Heating & Cooling
Our reverse cycle airconditioner is not cooling in two of our bedrooms, but the rest of the house seems to be cooling alright, but I am sorry the airconditioner is approximately 6-7 years old and we have...
Hi, I assume it is ducted, it could be either a flapper door is closed to shut off an area from receiving air, or there is a blockage in the duct (less likely). Also if there is more than one duct attached to the air conditioner then you'll have to check if air is entering all ducts (you may have a problem with the unit).
Nov 16, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
I have a heat pump and it freeze up
If you are referring to the outside unit freezing up, the issue is in the defrost cycle. The defrost cycle works something like this: The unit reverses the flow of freon causing the inside coil to blow cold air into the conditioned space and the outside coil is now working like an a/c unit, it gets warm to melt the frost/ice. The inside unit electric heat strips come on so you do not notice the cold air being blown in. The fan on the outside unit stops running to allow the coil to get good and warm.
Now the unit should go into the defrost cycle every 90 minutes or so. It should not terminate the cycle untill the coil is clear of frost. There is an "Klixon" type termostat that measures the temperature of the outside coil. This is most likely the problem. It is prematurely terminating the defrost cycle. I'd start there first.
Hope this helps, Let me know if I can be of any further help.
Dec 29, 2009 | Intertherm P3RC-030K Air Conditioner
No Instruction manual
This is for APAC
corp.carrier.com.au/content.cfm?content=111 -
This is for; Hotpoint
://www.geappliances.com/service_and_support/literature/
May 28, 2009 | Heating & Cooling
Spoke with independent contractor - he told me how to set the timer
Done thru mate at no charge
Cheers
John
May 28, 2009 | Carrier Heating & Cooling
Looking for instruction manual on APAC sundowner s0180hr9ak
Go to www.diplodocs.com they will have it as a PDF file there. Please don't forget to give me a Fixya rating.
Feb 23, 2009 | Carrier Heating & Cooling
No cold air blowing from vents
faulty indoor fan motor, check for blown fuses first in the indoor fan unit first before replacing motor. i live in s.a to i feel your pain.
Jan 29, 2009 | Heating & Cooling
Hitachi model number unknown !! (faded 0ff unit)
dirty unit and need for cleaning
clogged up expansion valve
defective fan motor
deffective air sensor
May 22, 2008 | Hitachi RAS-09UH Air Conditioner
Heating & Cooling Logo
506 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
