Question about HP LaserJet 5550 Printer
Network Printer Problem
My hp color laserjet 5550 printer gives error unable to store job at printer we are having our printer at network some time when i gives the print it produce one copy more given error unable to store job at printer reason insufficient disk space solution delete some files from the disk before resending this job please help me how can resolve this problem we don't hv any server.
  • adnan anwar Nov 03, 2008
    I get Unable to store job at Printer
    Reason: Insufficient disk space for this job
    Solution: Delete some files from the disk before resending this job.
    Please advice.
In the later HP LaserJet printers the printer has a "Mopier mode" that will provide better print performance on multiple copies. However, if you have "Mopier mode" enabled and you don't have an EIO hard disk installed, you'll get the above message.
Right click on the printer, select "Properties". There should be a "Device Settings" tab. Under that tab, make sure that "Mopier mode" is Disabled at the bottom.
The unit will still print multiple collated copies with that disabled.
Posted on Jan 21, 2009
Does your printer have a hard disk installed? If no it may be trying to store the print job to Ram disk. Try turning off ramdisk on the printer and also disabled mopier in the driver, (device settings?)
Posted on Sep 26, 2008
My printer hp color laserjet displays a printer error 57.07 i need to a process to clear the code
Try looking up that specific error code and it should tell you what you need to do.
Dec 28, 2014 | HP Color Laserjet 5550 5550n 5550dn...
Error code 40.0
A connection with the card in EIO
slot X has been abnormally broken.
1. Press to resume printing.
NOTE
A loss of data will occur.
2. Check that all cables are
connected to the EIO ports
and that the EIO board is
seated properly.
3. If possible, print to another
network printer to verify the
network is working properly
Jul 24, 2012 | HP Color LaserJet 5550 Printer
I am getting an error of: 49.4Co2 on my HP color laserJet 5550hdn. Have tied turning it off; unplugging butno luck. the error message continues to appear
1. Press CANCEL JOB to clear the print job from the printer memory.
2. Turn the printer off and then back on.
3. Try printing a job from a different software application.
If the job prints, go back to the first application and try printing a different file. If the message appears only with a certain software application or print job, contact the software vendor for assistance.
4. If the message persists with different software applications and print jobs, disconnect all
cables to the printer that connect it to the network or PC.
5. Turn the printer off.
6. Remove all memory DIMMs or third-party DIMMs from the printer. (Do not remove the firmware DIMM in slot J1.)
7. Remove all EIO devices from the printer.
8. Turn the printer on.
9. If the error no longer exists, install each DIMM and EIO device one at a time, making sure to turn the printer off and back on as you install each device.
10. Replace a DIMM or EIO device if you determine that it causes the error.
11. Remember to reconnect all cables that connect the printer to the network or computer.
12. If the error persists, replace the firmware DIMM.
13. Replace the formatter and calibrate the printer.
Aug 29, 2011 | HP Color LaserJet 5550hdn Printer
Trying to print a document error 49.4CO2 comes up. What does this mean?
Hi as you will see I have cut this from the manual its not very specific
I hope this is of some help
Ian
Description Recommended action
49.XXXX
PRINTER ERROR
To continue
turn off then on
None A critical firmware error has
occurred that caused the
processor on the formatter to
abort operation. This type of error
can be caused by invalid print
commands, corrupt data, or invalid
operations. In some cases,
electrical noise in the cable can
corrupt data during transmission
to the printer. Other causes
include poor quality parallel
cables, poor connections, or homegrown
applications. On rare
occasions, the formatter is at fault,
which is usually indicated by a
79 Service Error.
memory.
back on.
PC.
the printer.
device.
causes the error.
computer.
the firmware DIMM.
calibrate the printer. See
Calibrate now (HP Color
LaserJet 5500 models only).
Mar 17, 2011 | HP LaserJet 5550 Printer
Hi!i have a problem with printer!!And on control panel writing service error 4C02!!i\m 3 times restarting,it's help for times!
Open printer queue and delete all jobs in queue.
Power machine off, disconnect network cable.
Power machine on and let it boot completely.
Plug in network cable.
UPGRADE FIRMWARE (This is a must)
Jan 27, 2011 | HP LaserJet 5550 Printer
I have a error code 59.30 on HP laserjet 5550
here is the solution for your hp color laser jet 5550 printer
fbd1ddf.jpgThis will help. Thanks please keep updated. please do rate the solution positively .Thank you for using Fixya
Regards
manish
Mar 23, 2010 | HP Color LaserJet 5550hdn Printer
Unable to find on network
is the printer connected through a network cable,if yes print a config page through the printer and check the ip/tcp settings from the printer and check it against the workstations
Jun 25, 2009 | HP Color LaserJet 2600n Printer
HP Laserjet 2200dn print spooler unable to connect
Have you tried a different driver eg. rpcs or another version of pcl?Have you checked your workstations services app to check if your print spooler is running?Also when you print a config page from the hp it will give you your network details.To eliminate your network grap a crossover cable and connect directly to the printer and test.Let me know.
May 22, 2009 | HP LaserJet 2200dn Printer
First time using my hp color laserjet 5550
We need to start with turning the machine on not connected to the computer.
Disconnect machine from computer.
turn machine on
if locks on memory count 128mb turn off.
If machine has a jetdirect card (network card I/O) installed remove it.
Turn machine on.
If it comes READY you found the problem.
If you are not using on network reconnect to computer and try again.
If there is no network card let me know.
hope this helps
Aug 28, 2008 | HP LaserJet 5550 Printer
HP Color Laserjet 5550 not printing duplex
Hi, Check that the printer driver has duplex (double sided) turned on.
That's if u hav not already solved it :-)
Jun 17, 2008 | HP LaserJet 5550 Printer
HP LaserJet 5550 Printer Logo
4,277 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
