With a frozen radiator the things that most likely will occur--- split radiator cores ---frozen ,split block---cracked head/s--- broken water pump-- split heater core--burst hoses
Mine does this from time to time. I pull the SD map card, power it off, and hit the reset button while the unit is unplugged. These units are notorious for this. But then again, they're inexpensive. No receipt ... well, you're pretty much stuck with it. No receipt, no return or repair.
Hi friend, I think first you should check whether the phone or the screen frozen, or both of them are frozen, if the phone is frozen,you may try to turn it off for about ten minutes then turn it on, if it still cannot work, you may try to pull the battery out and then restore factory setting if it needs.If the screen is frozen,it may because.....you can visit our website: www.1010store.com. Hope this can help you! Good luck!
This is normal for these particular items. They don't "seem" to be frozen but they are fine. If everything else is frozen that should be, like, ice cream, ice cubes, frozen vegetables, then you don't have a problem. Do make sure your freezer is not building up ice anywhere and that the door is completely shut when you close it.
