Question about Intel Asus P5GL-MX 800MHz FSB 915GL Chipset Dual Channel DDR 400 Socket 775/T ATX Motherboard with L... (MB77ASP5GLMX)
Ram support Sir, My computer has four ram slot of ddr.If I insert RAM in all four slots will they support or not and if not why? Please give detailed discription of my problem and how can i overcome this problem.
  • 37 Answers
Yes if your going to put 1 gig on each slot it will work because the maximum RAM that your motherboard can handle is only 4 GB and make sure that all four are of the same speed but just incase that you bought a higher speed RAM it will work still but the speeed would be the speed of your lower speed RAM, hope this help
Posted on Sep 18, 2008
My mboard have 4 slot of RAM DDR, but i can't put all my RAM on all (4) slot, only 3 slot my comp can read (my RAM is DDR 512 MB pc3200 x 4) soo.. i have 1 Free DDR 512 and 1 slot.. please..please guide...
Looks like you have the right kind...they have to match you know...you could try 2/1g sticks instead...
Your compatible memory is here: http://www.crucial.com/usa/en/compatible-upgrade-for/ASUS/p5gpl-x
Jul 22, 2017 | ASUS P5GPL-X SE Motherboard
How do I install new ram memory on my dell demension 3000 computer
The RAM modules fit into slots on the motherboard and held in place with clips at the ends of the RAM module.
To remove the RAM module, push these clips to down and the RAM will pop up out of the memory slot.
When you insert the new RAM module/s, place the module in the memory slot, it will only fit in one direction, the RAM module have a notch on the edge where if fits into the memory slot.
Press the RAM module firmly into the slot until the clips pop up and locks the RAM module in place then check the clips are firmly in place.
I recommend you install DDR RAM PC3200 in pairs as per the manual.
If you don't have the manual Please click on this link :-
http://support.dell.com/support/edocs/systems/dim3000/en/OM/j6758A04.pdf
Sep 21, 2010 | Computers & Internet
Have hp dc 5000 microtower, has ddr 166 ram, what's the most i can put in it?
HP DC 5000 series of business desktop computers;
(All models),
Uses DDR Sdram that operates at a frequency rate of 333MegaHertz. (333MHz)
Also stated as PC2700.
Total Maximum Amount of Ram Memory is 4GB.
EACH ram memory slot's Maximum Amount is 1GB.
There are Four ram memory slots.
(DDR is double pumped ram memory. Has a basic clock rate of 166Mhz, which is double pumped to show up as 332. This is rounded off to 333.
http://www.crucial.com/store/listparts.aspx?model=dc5000%20Series%20All%20Form%20Factors
Mar 02, 2010 | HP Compaq dc5000 PC Desktop
Can i use the ddr2 ram in this motherboard?
your motherboard model supports only DDR type of RAM memory modules.
The details are:
Memory Type: DDR - 400 and 333 MHz; dual
Max Memory:
channel support
Memory Slots: Up to 4 GB
Four slots
I hope this solution is helpful to you
Jan 04, 2010 | Intel D915GVWB Motherboard
I can't recognize what specific RAM this motherboard accepts..
Dear sir,
In reply to your post- Generally now a days we use DDR400 RAM(DDR 1) for this type of motherboard.So DDR 400 RAM is More compatible then other RAM,you can use this RAM for your motherboard to obtain good performance.
good luck
chandrashekhar
Aug 04, 2009 | ASUS P4S533-VM (P4S533-VM/L) Motherboard
Need to know jumpers for adding 2gb ddr ram if there are any
You have inserted RAM in the worng slots. Insert it in alternate slots and not in adjacent slots.
Mar 24, 2009 | EliteGroup P4VXASD2 Motherboard
Upgrade of RAM
184 pin DDR DIMM is the correct information :) The bus speed of the ram would range from PC 2100 - PC 3200. I assume the Max amount of ram will probably be 2gb though unless your motherboard specifies a higher amount.
Mar 22, 2009 | Computers & Internet
Ram problem
You may have inserted the RAM wrongly, or the two modules are incompatible. The 3 beeps you hear indicates that RAM is not functioning properly.
Remove the RAM module that was recently inserted. Most likely the RAM slot is unusable now, as there was a short circuit at the slot.
Try using the RAM module on a different slot. Also make sure that that you have purchased the recommended type of RAM, ie DDR/DDR2, etc. for the slot.
It is always better to use a single RAM module, rather than 2 different modules from different companies..
Jun 08, 2008 | Biostar P4M80-M4 Motherboard
Pentium 4 comptability with SD Ram
If you know what mother board you have you could check what RAM it can use.
All RAM is installed in the same way, but different types of RAM are keyed differently. That basically means that one type of RAM (for example SD RAM) will simply not fit into another type of RAM slot (for example a DDR RAM slot).
To install ram on a PC
Please note - do NOT touch the connector side of the RAM, handle it only by holding the side or top edge
1. check that you have the right type of RAM. do this by lining up the RAM above the RAM slot and making sure that the RAM is the same length as the RAM slot AND ALSO that the RAM's key (the little hole or notch in the RAM) lines up with the key in the RAM slot. Note there might be more than one key
2. open both clips of the RAM slot by pushing them down and out from the center of the RAM slot
3. gently insert the RAM into the RAM slot
4. check again that the RAM and the RAM slot's key's line up, if they do, firmly press down on the RAM on both corners until both clips automatically click shut on the RAM
That's it! :-)
-Magnon
May 13, 2008 | Intel (P42000400512SK478) Pentium 4, 2 GHz...
My msi vis p4m800 motherboard don't support two ram
Hi, does your board have 2 diferent color RAM slots?
if it does you must install the RAM in the same color slots.
If not then you have the option of buying a 512 stick of RAM and installing that as a quick fix. The other alternative is to have your board tested by a technician.
Regards mistyman
Oct 15, 2007 | MSI KT4V (MS-6712) Motherboard
Computers & Internet Logo
71 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
