Question about Microwave Ovens
Microwave oven control board
Have you received my control board? I would appreciate some communication from you on its status. The USPS tracking says it was delivered to you on Sept. 11th.
NYBob
I need part number WB27X5399, a control board.
Thanks,
Jay
Jaygrabowski1@aol.com
Posted on Nov 19, 2008
The touchpad on my Westinghouse Microwave stop working
You must replace the whole keypad control board in order to get everything back on track.
Apr 20, 2012 | Westinghouse WST3504 Microwave Oven
I have a that microwave gh7208xrs that shows a error code F7 HVSMPS feedback
The controller is not getting the high voltage switched-mode power supply feedback signal.
Sometimes this is due to a defect on the HVSMPS (inverter) or a bad connection from the HVSMPS to the controller.
Due to the voltages involved, I do not recommend that an inexperienced person attempt to troubleshoot an inverter.
In the event that you or someone you know wants to look into it, see these safety warnings first.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
It tells you this:
F7 Power to magnetron interrupted
1. Unplug microwave oven or disconnect power.
2. After 40 seconds, check to see whether this solves the problem.
3. Unplug microwave oven or disconnect power.
4. Check cooling fan operation
5. Check the magnetron.
6. Check P65 connection on the relay control board.
7. Check the P56/P66 connection between relay board and relay control
board.
8. Check wiring to the 1200W inverter and control system. See "Checking
Inverters."
9. Check operation of all interlock switches.
10. Replace all parts and panels before operating.
11. Plug in microwave oven or reconnect power.
12. Check voltage at 4903-1 on relay board. If it is 120, unplug microwave
13. Replace inverter.
14. Replace all parts and panels before operating.
15. Plug in microwave oven or reconnect power.
16. If problem persists, unplug microwave oven or disconnect power.
17. Replace relay control board.
18. Replace all parts and panels before operating.
19. Plug in microwave oven or reconnect power.
20. If problem persists, unplug microwave oven or disconnect power.
21. Check for reversed plug connection on controls or loose wiring.
22. Replace all parts and panels before operating.
23. Plug in microwave oven or reconnect power.
I'd suspect 6 through 8 first.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Jul 08, 2011 | Whirlpool GH7208XRS Stainless Steel 1200...
The cooktop lamps on my Whirlpool MH6130XEQ-1 microwave do not work. Their receptacles receive 70 V AC, no matter whether and how many times the soft switch is pushed.
I just saw this inquiry today, and while you may have already dealt with this, here is my answer, in case it might help you or others:
We see and repair this on a regular basis with our $39.95 service. Details are here.
It's a problem caused when the cooktop lights fail or are removed or inserted with the power still on.
They short internally, and the resulting surge damages the control circuit board.
It can affect fan and oven light operation, keeping them from working or leaving them stuck on.
If you prefer to replace your control circuit board, you can order it (part number 8172054, formerly 4359661) for $168.39 plus
shipping from the Pros here.
moz-screenshot.pngmh6130xeq-1_panel_smaller.jpg?filename=mh6130xeq-1_panel_smaller.jpg&q=786obatqb1684s0931&o=4337&contentlength=75762&downloadid=ebf28cd0ae6c0b1566d991c489678ab1
Nov 14, 2010 | Whirlpool MH6141XK Microwave Oven
I have a TE Error on my Kenmore Elite Microwave... what does it mean? It won't do anything... I've unplugged it to see if it will clear... nothing...
The cause of the TE error for us was grease/gunk on some exposed pins and flex connectors (communication bus between controller and keypad) that was interfering with communication with the keypad. Resolution to TE error: Remove the keypad / control board from the microwave. There are three screws on the bottom at the front to remove. Once those are removed, the keypad is held on by clips. Slide the entire keypad to the left and it will come loose. After it is loose, carefully remove all the wired connectors to the microwave. Lay the keypad face down on the counter and look at the control board. The control board is actually seperate from the keypad and connected via two thin flex strips with many small contacts (like a nintendo game connector) . Our flex strips were covered in grease from the hood fan operation. Carefully clean the strip and the connector (with a felt pen if you have one) and resassemble. This resolved the issue for us.
Nov 12, 2010 | Kenmore 80809 Microwave Oven
Error message
The F6 error code on your microwave oven is a relay failure.
Check wiring to relay 4903 for short circuits. If wiring is OK - replace the control board.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Oct 14, 2009 | Kenmore 61701 Microwave Oven
Code F6, E0, "Communication Error"
Hi. this code represents a key pad or control board malfunction. you will have to make sure the key pad or control panel connectors are connected tightly and securely. If the wires and connectors are secure, the actual control board may be faulty and you will need to replace it at this point.
Mar 01, 2009 | KitchenAid Microwave Convection Oven
Whirlpool microwave oven
There should also be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
It says:
7. Check the P56/P66 connection between relay board and relay control board.
8. Check wiring to the 1200W inverter and control system. See “Checking Inverters.”
12. Check voltage at 4903-1 on relay board. If it is 120, unplug microwave oven or disconnect power.
If for some reason your tech sheet is not there, you can download it here.
We regularly repair control units for customers nationwide by mail for $39.95 postpaid in about a week with a one-year guarantee.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Nov 30, 2008 | Whirlpool GH4155XP Microwave Oven
Magnetron tube
Short of buying the service manual, you can find helpful exploded view diagrams by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Replacing the magnetron will require the removal of a lot of screws. Keep track of where they all go.
We have critical safety information at our site, and our link is at our listing here on FixYa.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 27, 2008 | GE JVM1440 Microwave Oven
F9 error
Your Microwave uses "UltraWave technology"
I'll explain a few things about this wonderful technology...
The control board (accepts the pushbutton commands) has to talk to the inverter board to tell it how much power should be applied to the magnetron. The inverter board will then power the magnetron and inform the control board if the magnetron is working OK.
If there is something wrong with the magnetron or inverter board or a there is a communication breakdown between the control board and the inverter board...WA-LA-----F9----
A pretty reliable test for the Magnetron is to operate the oven and listen for a ticking sound 5-6 times about a second apart. If you can hear the ticking....The magnetron has failed..if no ticking, the control or inverter board failed.
The Magnetron sells for about $78.00 and is simple to replace. Check your owners manual for limited warranty on the MAG and electronic parts.
Jun 10, 2008 | Kenmore 62622 Microwave Oven
Kitchenaid double convection microwave / oven combo model #kems308sss00. Error code: f6 eo, lost communication. What do I do?
I'm guessing the model number would be KEMS308GSS0.
In some cases, this is a glitch that can be cured by unplugging it for 1 minutes, then resetting the clock.
In other case, it may be a bad keypad (membrane switch) or control board.
Please feel free to contact me directly if you need more help.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
Jun 03, 2008 | KitchenAid Microwave Ovens
Microwave Ovens Logo
82 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Gerry Harvey
Gerry Harvey
Are you a Microwave Oven Expert? Answer questions, earn points and help others
