Question about Goodman Heating & Cooling
Support on changing out the heat exchanger on gmnt 080
  • TexNOz May 11, 2010
    What is a gmnt 080?
  • 1,420 Answers
1st, take a picture of where each wire goes to. Look in the owners manual for an exploded view of how it goes together. The heat exchanger most likely comes out from the front of the furnace. You will have to remove and reinstall every componant inside the furnace to get it out. Suggestion, replace the whole furnace. It will be cheaper.
Posted on Sep 19, 2008
Leaking heat exchanger
balance chemicals in pool and replace heat exchange
Jan 08, 2013 | Teledyne Laars HEAT EXCHANGER ASSEMBLY,...
My Goodman GMNT 120-5 furnace is not coming on.
First I believe you will need to begin by reading this=>
Goodman GMNT120-5 Service Instructions
You will need Adobe Acrobat Reader to view these documents. The Adobe Acrobat Reader is available as a free download.
If you have questions please let me know, Sea Breeze
Nov 03, 2012 | Heating & Cooling
We need to change the heat exchanger for my Goodman Heat Furnace model no.-GMP 075-3
Not an easy task! Take many pictures as well as draw out and mark which wire went where. You will have to remove everything from inside the cabinet to get to the heat exchanger. It may be easier to replace the furnace. If you are paying a professional to do the exchange, figure three hours if they have done it before, if not figure 5 to 6.
Apr 02, 2011 | Goodman Heating & Cooling
Need step by step instructions to set-up memory lens function for PT AE3000 projector so as to be able to switch between 16.9 and 2.35:1 formats
LENS MEMORY means that
You can save and name the adjusted ZOOM/FOCUS,
H-AREA POSITION and V-AREA POSITION there is just 4 adjustment settings in
memory excluding ASPECT RATIO the aspect ratio depend on signal but you can change manually when needed.
possible ASPECT RATIO and SIGNALS
If VIDEO or S-VIDEO then
ASPECT RATIO
4:3 \ 16:9 \ 14:9 \ ZOOM1 \
ZOOM2 \ JUST
AUTO
\ 4:3 \ 16:9 \ JUST \ ZOOM
you can switch in between
If COMPUTER then
4:3 \ 16:9
4:3 \ 16:9
VGA or SVGA signals
Not switchable with
WIDE480/600/720/768/768-2/800/900 signals
If HDMI then
4:3 \ 16:9
16:9 \ H - FIT \ V - FIT \ ZOOM
1 125 (1 080)/50i, 1 125 (1 080)/60i,
1 125 (1 080)/50p, 1 125 (1 080)/60p,
1 125 (1 080)/24p, 750 (720)/50p and
750 (720)/60p signals
525p (480p) and 625p (576p) signals
If COMPONENT(YPBPR) then
4:3 \ 16:9 \ 14:9 \ JUST \ ZOOM1
\ ZOOM2
625i (576i), 625p (576p)
AUTO \ 4:3 \ 16:9 \ JUST \ ZOOM
525i (480i), 525p (480p)
1 125 (1 080)/24p, 750 (720)/50p,
these are all type of signals and there possible aspect ratios
Feb 06, 2011 | Panasonic PT-AE3000U LCD Projector
Gas backup wont light. repairman said need new heat exchanger. approx 60 days ago replaced all burners and it woked ok they got it running for 1 night now it is out again. if the xchanger is bad why did...
I would only assume that now you have taken out an over heating sensor. When a heat exchanger goes bad it is a very dangerous situation because now you are pumping carbon monoxide in your house along with your heat. A heat exchanger is a baffle that hot gases pass thru, heating up the exchanger along the way and expelling carbon monoxide out the exhaust/chimney. Bad exchangers crack along seams or burn holes thru allowing the exhaust to mix with the blower air and in time this could cause carbon monoxide build up in your house. This cracking also lets hot exhaust in to the furnace and can burn up over heat protection, wiring and possibly cause a house fire. Please change out the heat exchanger or entire furnace, there is no price to replace a human life.
Dec 20, 2010 | Heating & Cooling
014 code
A 14 code means the thermal fuse (white wire which wraps around the heat exchanger) has snapped. This occurs if the heat exchanger reaches a dangerously high temperature. To correct this error code you need to replace the thermal fuse and keep the heat exchanger from over heating. Typical reasons the heat exchanger over heats are:
1) scaling in the heat exchanger
2) combustion chamber dirty and burning hot
Oct 07, 2010 | Noritz N-069M-DV, N-084M, and N-084M-DV...
I have a goodman gmnt 100 b furnace 2 stage when the gave valve turns on and floods the heat exchanger with flame then the squirl cage fan turns on and i loose the the flame
If you are getting flame distortion when the blower comes on it usually means a cracked heat exchanger which can lead to carbon monoxide, get your furnace checked by a qualified tech..
Jan 31, 2010 | Goodman Furnace Draft Inducer Blower ...
Aderss of acer service center in banglore
2A, Aisa Glenridge 32, Langford Road
Museum Road, Bangalore, Karnataka 560025
080 41526018
#2A, Aisa Glenridge 32, Langford Road
080 41526018080 41526019080 41526020080 22296068 - Fax
Mar 20, 2009 | Acer Extensa 5420-5687 Notebook
Furnace start buts shuts off
It sounds like you have an obstruction in the exhaust vent. Thats why when you bybass the pressure switch it runs ok. Steve
Dec 15, 2008 | Goodman GMS90703BXA Heater
I have a Coleman/Evcon Presidential ser# 074878. The plumber says the Heat exchanger is cracked. Is this something I can fix myself or is it less expenxive to buy a new furnace?
The heat exchanger is a bear to change. depending on the age of the unit it might be more practical to replace the unit. However unless you trust this service tech I'd get a second opinion, because it is rare that a heat exchanger will crack, plus by law he or she should have shut the furnace down do to carbonminoxde. Especially rare in Coleman Evcon series units.
Oct 21, 2008 | Heating & Cooling
Heating & Cooling Logo
114 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
paulcarew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
