Question about HP Serial adapter (17302A)
HP1730 TFT monitor not powering on
I have HP1730 TFT monitor. Not not powering on.
Any one can help me to solve the problem?
  • raj16 Sep 18, 2008
    I checked power cable & fuse its good. but there is no power in the monitor.
  • 105 Answers
There are multiple circuits for this model. I suspect your model is PE1237. If so this model frequently has bad solder connections at the AC socket. Also capacitor 2119 or capacitors 2041 & 2031 can cause no power up. They normally are bulging if bad.
If your model is PE1238 (BenQ), you may see bulging capacitors in the power supply.(1000uf/25v)
Monitor Mike
Posted on May 09, 2009
Monitor not powering
Posted on Jan 20, 2009
  • 320 Answers
Hi check socket if there is current, or try connect another power cable to your monitor, (check fuse) if nothing happend your monitor is damage.
Posted on Sep 18, 2008
Sound is not working
Posted on Jan 29, 2009
Neither picture is displaying on moniter nor sound is coming (DELL TFT moniter)
Which is a dell tft or compaq crt monitor ?
The Dell 1504FP is a flat panel LCD monitor that has a viewable area of 15 inches.
The monitor, which uses TFT technology, is designed to be used in a home or office and displays video at a resolution of 1024 x 768 pixels.
Over time, you may encounter problems using your Dell 1504FP monitor or it may cease functioning altogether.
Fortunately, there are variety of ways that you can repair the monitor to get it back up and running.
Shut down your computer and press and hold the power button on the side of your Dell 1504FP monitor if your monitor has a blank screen.
Unscrew the VGA video cable that connects the monitor to the computer.
Power the Dell 1504FP monitor back on and wait as it launches into the Self-test Feature Check.
During this period of time your monitor will make settings changes to ensure that it functions properly with your computer.
Firmly screw the VGA cable back into the rear of the monitor to ensure optimal video quality. Power both the monitor and computer back on and wait for your computer's desktop to appear.
Power off your Dell 1504FP monitor if the screen is dirty.
Wipe down the monitor using a dry microfiber cloth to remove any dust particles or smudges that have accumulated on the screen over time.
Power the monitor back on when you are complete and resume using it.
Press the "Auto Adjust" button on the right side of your Dell 1504FP monitor if the display is blurry and images appear out of focus.
Unplug the monitor's power cord for thirty seconds if the problem persists.
Plug the monitors power cord back into the rear of the device and power it back on.
This will reset the monitor and your display should now be focused properly.
http://support.dell.com/support/edocs/monitors/1504fpis/en/trouble.htm
Troubleshoot a TFT Monitor
TFT monitors can suffer from many potential problems, ranging from simple screen brightness issues to disconnected inverter or LCD cables.
These can cause video- and backlight-related failures on your TFT monitor.
Fortunately, you can attempt to repair these problems, even if you have no experience fixing a TFT monitor.
The only tool you will need is a Phillips screwdriver, although opening your TFT monitor will likely void its warranty.
Check the brightness settings on the TFT monitor.
There are dedicated adjustment keys on the bottom face of the TFT monitor.
If it is a screen incorporated into the design of a laptop, you'll find monitor adjustment keys on the top row of the laptop's keyboard.
A TFT monitor that has its brightness turned all the way down will appear to be almost completely dark.
Ensure the TFT monitor's power cable is still plugged in, if it is an external monitor. In the case of a laptop, make sure that the power cable is plugged in or that the battery is properly charged.
Disconnect the TFT monitor from the power source. If the TFT monitor is an external model connected to a computer tower, disconnect the video cable as well.
Remove the battery from your computer if you are using a laptop.
This is an important safety measure.
Turn the laptop over and slide the battery release mechanism over.
This mechanism is just below the horizontal outline of the battery on the underside of the laptop.
Remove the screws on the bezel of the TFT monitor.
The bezel is the plastic piece surrounding the TFT screen.
The screws will likely be covered with plastic seals for aesthetic purposes, so pop these seals off with your fingers and remove the screws using a Phillips screwdriver.
Pry up on the bezel gently and remove it.
Start at one corner and work along the bezel's perimeter with your fingers.
There will be small plastic latches between the bezel and the rest of the computer you'll need to disengage.
Check the TFT monitor's inverter cable.
This black cable lies at the bottom center of the monitor and should connect to a socket on the inverter board, which is the green color horizontal strip that lies just below the inverter cable.
If the cable is loose from the board, the TFT monitor's backlight will fail. Pull up on one side of the socket and slide the cable back in, then press firmly down on the socket to lock it down.
Remove the metal brackets on either side of the exposed TFT monitor if the inverter cable fix does not solve your issue.
There will be two to three screws in each bracket that must be removed using your Phillips screwdriver.
Pull the TFT monitor carefully away from the rear casing of the display to reveal the LCD cable. This cable runs from the back of the TFT screen and should be connected to a socket in a similar fashion to the inverter cable. If it is disconnected, lift up on the socket, slide the LCD cable back in, then press down on the LCD socket to lock it back down.
NOW FOR SOUND
if you can get a screen
Click start control panel administration tools computer management device manager scroll to sound video and game controllers you might see a yellow question / exclamation? ! mark or a red X Right click to reinstall drivers
If your computer came with a motherboard disk the drivers could be on it
or you might download slimdrivers.
Rather doing a driver hunt
http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html
Windows XP/Vista/7/8
Note: it will find all of your outdated drivers
This is a free driver solutions
which will automatically search for and find the correct driver
You will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point.
Click no to both of these then continue updating each driver free then restart once all of the drivers have been updated.
It might take some time being free
Aug 09, 2013 | HP COMPAQ 7540 CRT Monitor
V7 - S20PD TFT Monitor - Display goes off after about an hour
Hello, I am sure that you have some software settings problem. go to - DISPLAY PROPERTIES - SCREEN SAVER - MONITOR POWER. There select NEVER TURN OFF monitor. Your problem will be solved. BYE
Oct 10, 2009 | Computers & Internet
No sign of power
have the switching power supply checked or might need a replacement
Aug 10, 2009 | Gateway 19" Flat Panel LCD Monitor
My computer shutdown and im using a emachine e17t6w tft lcd flat
Hi
Dear sir,
Moniter Modale No E700,
E700 modeleprablem, Power splay prablem, but transister, Divaid all componets ok
Becouse power on that puse shout way to andstrading the prablem, please solve prablem
Mar 19, 2009 | Computers & Internet
Dell E173FPc 17" TFT when turned on goes black
Hi Gaz,
First, verify the monitor is functional.
Monitor STFC (Self Test Feature Check)
Turn off the monitor
Plug the monitor power cord directly into the wall socket to remove any surge protectors or APCs from the troubleshooting equation
Unplug the monitor video cable from the back of the computer
Turn on the monitor
The floating dialog box should appear on screen against a black background.
If the issue appears during the STFC, the monitor is defective. What are the results please?
Jan 22, 2009 | Dell E173FPc 17" TFT LCD Flat Panel...
TFT monitor went dead
Hi
How old is your TFT Monitor?
It looks like the Monitor has got some problem.
First, make sure the cables are connected correctly.
Try Changing the connecting cable (between monitor and pc) with another one.
Try using another monitor with your pc & using same cables.
If the problem persits, pls try your monitor on another Computer.
This is all what you can do, if the problem wasn't solved, then maybe the problem is in the monitor that you need to take it to a specialit to repair it for you.
I hope my steps were helpful.
Nov 06, 2008 | Computers & Internet
Blurred "No Signal" in the TFT when only power cable is connected.
in display settings try to reset the screen resolution
Oct 16, 2008 | Acer AL2216W LCD Monitor
Powering up problem on UPS
about your first problem it is not normal.you should check it out with a qualified professional.
after repairing it will work nicely
Apr 02, 2008 | SAMTRON 55V 15" CRT Monitor
HP Serial adapter (17302A) Logo
597 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
