Question about Archos 504 500870 Digital Media Player
No power i was using my archos 504 yesterday, after browsing, i turned it off. after few hours i turned it on again. it wont power up. so i changed batteries, same thing. the unit wont turn on. so i decided to place it onto the docking station. it should start charging, right, the 3 leds should light up...but nothing happend. what gives? can anyone help me??? thanks!
  • 4 more comments
  • cojay725 Sep 18, 2008
    tried what GUEST suggested! you are right on the money!!! it worked! thanks a bunch. press the small gold bump on the pcb for 10 secs, no memory loss. thanks again!!!!
  • nickyj44 Dec 05, 2008
    My Archos wouldn't power on either, despite the battery being fine, and I too pressed the gold button for 10 seconds and now it works absolutely fine - chuffed to bits!!!
  • rrulo Jan 06, 2009
    Same issue with me. No sign of life conected different times. Tryed to get customer help but cant register because I can't check the info inside.
    Where's the gold button? I read in the manual pressing one of the external buttons for 10 secs is reset. but I can't find a gold one. I can't find the solution posted.
  • Anonymous Feb 06, 2009
    Same problem here, no power. I'm over the moon, back working after pressing the gold button for 10secs.
  • Anonymous Feb 20, 2009
    Wow!!! that's crazy totally wouldn't have even seen that button. I went out and bought a battery (because the original battery had one of the corners break off) thinking maybe it was somthing with that. Of course I google the issue after I get the battery and it didn't work.... not to smart i know but whatever. BUT does anyone know what this magic golden button does totally worked for me.
  • yonott May 05, 2009
    i cant find the gold button can someone can pls help??/
For the 504, you do not have to remove the hard drive. The gold disc/button is visible by just removing the battery/back. Thanks very much.
Posted on Feb 21, 2009
Don't be afraid! (I was) I was only getting the Green power light on and no further reaction. Wouldn't switch on and I was convinced it was the battery or the usb cable but I read the comments on this site and decided to have a go.
I opened the back and was daunted when I saw the security seal. Was out of warranty anyhow so I thought what the hell! I removed the 2 small screws at the bases of the hard drive and lifted the unit forward. There on the pcb Was the small oval gold disc/button and I push it in with my small screw driver for about 10/20 seconds then put every thing back in place - and Hey Presto - powered up and worked a treat! Thanks to this site and its users from an 'absolute novice' with a little common sense!
(important advise from my friend - discharge the static from your hands by tuching another metal object before opening the back of any PC or simular device) Barrie UK!
Posted on Jan 07, 2009
I had the same problem, the manual and the Archos website are hopeless. Mty Archos died on me while on holiday and was baffled but the comments on this site solved my problem straight away. Many many thanks
Posted on Sep 22, 2008
Unit crashes then will not restart after being unresponsive.
After removing the battery, I discovered a small brass reset button, about 3 mm in diameter, near the battery connection terminal. This was gently pressed with a pen for 15 seconds. After refitting the battery, the unit was fully functional again. This reset results in needing to set the clock again. No other settings are affected.
Jan 08, 2010 | Archos 504 500870 Digital Media Player
Archos 504 wont turn on
Disconnect the battery for few seconds and replace back again, then turn on. I had the same problem and that was what I did.
Sep 17, 2009 | Archos 504 500870 Digital Media Player
No power whatsoever to my Archos 504
There is little documentation regarding the reset. However there is one in the Archos 504. If you take the battery off and look at the connecting Pins of the battery of the main unit. You will see a small Gold Button (looks like the circuit). This is the main reset button. If you Press it all will be good. You will not loose anything unless you have a Main File corrept but at least you will get function back so you can fix the firm ware.
I hope this helps you.
Ed
Feb 21, 2009 | Archos AV 500 400-Hours Video Recorder
My archos 5 wont switch on to the home page
You should perform this when it is on
problem solve #1
* Press the reset button on the buttom of the device using a papr clip. It should shut it off. then try to turn it on again.
try the next if the problem still exist.
Problem solve 2
* Download the latest frimware from Archos.com on to the desktop on your computer ( i recommend desktop because it will be easy to find) Then plug the device to a pc Using USB cable. turn the archos on by holding power switch and TV/LCD buttons at the same time until a white screen comes up. it should ask for Usb. if it does pick the ubs. if it does not give you a USB option but these "NO", "REPAIRE", "FORMAT" move the curser to repaire. do not pick the format which will delete all the contents and plugins you have on your device.
after repaire completes it should say done. do not press the done wait until you see the archos connection under My computer. it should normaly come up with name 504 or you will be able to see the archos icon. place the firmware in to the main drirector not under any folder. then press the ok button to confirm the "done" device will power off and start with a white screen again but this time it will update the firmware and restart do not unplug the Usb cable until the update completes. It should restart again and load the normal user interface. Your device should be fine and back to normal.
Jan 03, 2009 | Archos 504 500870 Digital Media Player
504 recovery screen
hold the tv button slightly earlier than holding the power button, first tv then power (while still pressing the tv button). it should first boot up to a normal green ARCHOS screen, then it will enter the recovery mode.
Sep 08, 2008 | Archos 504 500870 Digital Media Player
Archos 504 RESET button
Please open Battery cover and PRess Small Golden button just near the HDD , it will restart the Devie
Jul 21, 2008 | Archos 504 500870 Digital Media Player
I own an Archos 504, i purhcased today a DVR Station GEN 5, the box states compatibility with the 405 and 605, is it compatibble with the 504 too? could you confirm this please before i open the box many...
yes it is compatible but the remote wont work for Archos 504. also, u'll require saddle for 504(usually comes as part of package). dont try to put your archos on the dock without a saddle.
Mar 18, 2008 | Archos 504 500870 Digital Media Player
Bless you guys...!
I thook the chance n press the reset button....Nuthing has been erased from my hard drive!!! :D :D :D
Nov 16, 2007 | Archos 504 500870 Digital Media Player
Recovery code 4 on archos 504
I had the same problem and manage to solve it. You need to do the following
a. go to Archos website and download latest firmware and save on your pc
b. turn on 504 and select repair - unit not connected to pc
c. connect 504 to pc and wait until pc recognise it
d. copy firmware from pc and past to 504 root directory.
e. press done on 504. that should work. I've spent the best part of 10 hours looking for a solution to the dreaded recovery code 4. The problem is a corrupt os. I hope you're as lucky as me.
I still have a problem with mine though...a screen that blink constantly.
Nov 01, 2007 | Archos 504 500870 Digital Media Player
Archos 504
I had a similar problem remove the battery and push the gold coloured reset button. It worked on mine, You don't lose any info doing this. I got the advice from the Archos support phone number CC
Aug 19, 2007 | Archos 504 500870 Digital Media Player
Archos 504 500870 Digital Media Player Logo
184 people viewed this question
Top Archos Audio Players & Recorders Experts
kaiserh1
 Grubhead
Grubhead
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
