D-Link DI-624 Air Plus XtremeG Wireless 108G Router (790069250842) Logo
Posted on Sep 23, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Open port 80 in dlinkdi624 - D-Link DI-624 Air Plus XtremeG Wireless 108G Router (790069250842)
Anonymous
Level 2:
Sergeant:
  • Expert 113 Answers
  • Posted on Sep 23, 2011
Anonymous
Expert
Level 2:
Sergeant:
Answers
113
Questions
0
Helped
27869
Points
558
Http://www.manualowl.com/m/D-Link/DI-624S/Manual/156171
read this carefully hope your problem after read this article thats a manual dlink 624
2answers
HOW DO i BLOCK PORT 80
Port 80 is the web port. Whenever you look at a web page you are going to port 80 on the server. If you block port 80 then you won't see web pages. I am assuming it's outgoing traffic to web servers you wish to block. A standard router will have incoming port 80 blocked by default. You would OPEN port 80 if you had a web server at home.
Help: Huawei EchoLife HG8245: Port 80 Not Open
Well there is NO need to go live. this is a simple matter your ISP is Blocking Port 80 for whatever reason and there is probally nothing that can be done besides get a new ISP one that does not block port 80..
You can try giving them a call or check their website and see if the Block port 80 as ALL the other Ports you Forwarded are Open.. I am Highly leaning to your ISP as the culprit..
Port 80
You need to login to the router, and enable "port-forwarding" so that incoming traffic (80/TCP) is redirected to the ONE computer on your private network that is running a web-server that is "listening" on 80/TCP.
I am trying to open the router ports to allow a ps3 to connect. when i try to play call of duty:modern warfare 2, i keep losing the connection. can you help me open the ports and configure the settings?
Some times you will need to open the Logical Ports on the router.
These are the logical ports.
For this you will need to open the set up interface of the router.
Once you open the set up interface of the router, you will be able to find the settings on the router where you can open the ports for the particular program.
If you are opening the ports for a special device in your network, then you must know the IP address of that device.
For example, wireless camera, DVR, X-box, Play station ...
You can choose the option PORT FORWARDING for a special device application.
If you just want to open the ports for all the network, then you can choose PORT TRIGGERING
For example ,
You have a Linksys wireless router and you want to open the ports for the X-box.
You have opened the set up interface of the router. You will see Application and Gaming TAB at the top.
If you click on that tab you will find different Sub tabs.
Click on Port Triggering => Here you can open the port numbers for the network.
Click On Port forwarding if you want to open the ports for a special device in the network.
Click Save settings once you open the ports on the router.
Some of the recommended port numbers for different applications :
IMAP ==> 143 SMTP : 25
HTTPS ==> 443 HTTP : 80
DNS ==> 53 FTP : 21
SNMP ==> 161 TELNET : 23
XBOX ==> 53, 80-88, 3074
PS3 ==> 80, 443-447 ,5223, 3478-3479, 3658, 10070-10080.
WII ==> 28910, 29900, 29901, 29920, 80, 443
VPN ==> 1723, 500, 443-447, 10000-20000
World of Wars ==> 3724, 6112, 6881 - 6999
Click Here for more info
HOW TO DO THE PORTFORWARD
For example ,
DNS ==> 53 FTP : 21
Open port 80
To open a port on a router involves several steps.
1) Log into your router from your browser, this is generally at address 192.168.1.1
2) Type in your username and password (this varies from vendor to vendor)
3) Once logged in, go to the Advanced Tab, and then click on Gaming on the side menu.
4) Under the Add Game Rule, put the name, IP address can be left blank, and then set ports to open to 80.
5) Save changes.
Port Forwarding on NB7Plus4W router
For example ,
DNS ==> 53 FTP : 21
Enabling port 80 access
You will have to go into the main page of your router, type 192.168.0.1 or 192.168.1.1 in your address bar of your web browser.
When you log in look for an option that says "Port Forwarding". In this page you will have to enter the port you want to open (80) and then type the IP address of the computer you want to receive the port 80 requests.
****PLEASE NOTE: If you are trying to open port 80 on a residential account, CALL YOUR ISP first and verify this is possible!
Why?
Port 80 is an internet port. People who use this port generally do stuff such as hosting a website. Most ISP's block port 80 for residential customers because they do not want them having that kind of traffic coming in. If that is the case, there will be no way for you to open the port. You will either have to use a different port, or upgrade to a business account. Just an FYI so you don't go crazy!
1helpful
Open port 80 on Netgear GG843
By default port 80 on the router is already open.
I cant open youtube
Go to Start > Control Panel > Windows Firewall> Exceptions> Click on add port.
Call it port 80.
In port number type in 80.
Then click on OK.
Then close all the windows.
Basically on the computer that is running apache (Server), YouTube is unblocking the port called 80. On some systems mainly XP home we found that port 80 was always blocked. Even though localhost worked, computers connecting to it would get an connection error. Also, if you have a 3rd party firewall, you have to unblock YouTube. If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Top D-Link Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
