Insignia NS-32lcd wont turn on?
I have read all of the other posts for this model and here is what I have done. I replaced the power supply which didnt fix the blue/red pattern light problem. So I disconnected everything but the pc board and I still am getting the red/blue light. Does this mean the pc board is bad?
  • 9 more comments
  • robsim15 Sep 21, 2008
    I replaced the pc board and now the light will stay blue. I can use the on/off button to make the light go either blue or amberish. However I get no picture or sound
    I have checked and rechecked all of the wires.
    all of the cables are in good shape. I checked the 3 fuses on the board and the large glass fuse is fine. But I dont know howto check the smaller pico fuses.
    what are you talkin about
    please help
    I dont have another monitor to check the PS
    No its not under warranty
    Still isnt working
    There are no drivers to reinstall.
    Im interested in getting help fixing the tv not hearing opinions on how bad it is. I appreciate your comment but it does not help me
    there is a built in tv tuner
  • 4,472 Answers
Unfortunately a brand tv like this is known as a "throw away" tv. Customer support is not good. Getting service information is not good. For all the money and time you are spending it is much more worth it to invest in a quality tv that will over quality customer service. Also this is why I recommend extended service warranties then issues like this can be easily covered for 4 years. You can contact Insignia support call 1-877-467-4289 for 24 x 7 x 365
Hope this helps and if you have a moment to accept and rate accordingly it would be greatly appreciated.
Thanks,
Lee
Posted on Sep 21, 2008
  • Lee A.
    Lee A. Sep 21, 2008
    Good luck on finding a solution that suits you.
  • 43 Answers
U still got warenty if do a refund is always option
  • 1,800 Answers
No no
just check the power led and HDD LED and other connection there is a shema in the mother broad shown where the switch and the reset buton and light must connect to.
plez do rate this post
    Sergeant:
  • 399 Answers
Check whether all the wires are connected at proper place and firmly.loose connection also gives this problem after new board is attached.
thanks.
  • 2 more comments
  • masterexpert Sep 21, 2008
    also change the cables if too old or cracked in between or worn out.faulty cables also give this problem.
    check the same ps with other monitor.as it could be the problem of EST card in the monitor.or the new board is not supporting your monitor.
    reply.
    please reinstal the display drivers .
    reply.
    is there in built display or you have connected the seprate display card to the board.
    reply.
I have a insignia ns-32lcd and all I get is thin lines going up and down the screen. What is the problem?
For those capable of board level repair, on my 32LCD the T-con board had a defective voltage regulator. This is the board under the shield connects to the two ribbon cables to the screen. This parts is located on the left side looking from the bottom of the set. It is marked 1117-2.5s it is a 2.5 volt regulator.
On my set it was supplying 1.0 volts. I replaced it with a series pass transistor
regulator used a MPS2712, set for 2.5 Volts now work perfect
Feb 06, 2011 | Insignia IS-LCDTV32 32 in. Television
I have an insignia NS-32LCD and it will not turn on
Capacitors are probably bulged in the power supply. Need replaced, not expensive.
Oct 10, 2009 | Insignia NS-LCD26-09 26 in. HD-Ready LCD...
Insignia ns-32lcd. picture scrolling and no sound
Hi, I was waiting your response in chat session but didn't get any.
Jun 11, 2009 | Televison & Video
How to remove the back from Insignia NS-32LCD?
I unscrewed all the screws in the back, detached the tv from the base, and was able to get the back off. I ordered a new power supply board and will install it to see if it fixes the problem with the tv (won't turn on, insignia light alternates between red and blue). I didn't notice any problems with "swollen" capacitors, so if the new power board fixes the problem I'll update this website.
Jan 27, 2009 | Insignia IS-LCDTV32 32 in. Television
INSIGNIA 32 IN FLATSCREEN MODEL NS 32LCD
check for capacitors on the power supply that are puffed up. Also the mai board can cause this but the power supply is where i would start.
Jan 08, 2009 | Televison & Video
HI I have a insignia model NS-32LCD tv and it stop working the only thing that would happen is the light on the bottom of the TV would change from blue to red. so I call the TV man and he look at it and...
This happend to me before with my LCD that I bought last year. It worked fine for a while and then, all of a sudden...nothing. The power supply was fine, fuses were fine BUT one of the chips or capacitor went bad on the process board and not being able to get the adiquate amount of power to be distibuted. I had my tv replaced and found out this was a defect rather than you or something done wrong to the tv.
Hope this helps you....
Jan 03, 2009 | Insignia IS-LCDTV32 32 in. Television
Insignia NS-32LCD Backlight or Inverter bad???
If you've done the flash light test, it could be the inverter board became defective but it could also be that the power supply does not provide the +24VDC to the back light inverter board.
If you could do the +24VDC test using a voltmeter then we can say for sure that the back light inverter board is defective.
Let me know if you need further assistance.
Aug 21, 2008 | Insignia IS-LCDTV32 32 in. Television
did you try calling the (877) 467-4289 Insignia help line?  I think they're open 24/7.  They just solved another Insignia problem for me.
May 13, 2008 | Insignia LCDTV26 26 in. Television
Televison & Video Logo
120 people viewed this question
Top Televison & Video Experts
Electro Med Services...
