Question about Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis Can I turn off the beeper? I love the washer and dryer but he beeping is to loud even when set to soft.
  • 126 Answers
THE ONLY OTHER WAY TO TURN OFF THE BUZZER IS TO REMOVE IT UNFORTANETLY.OR COVER THE BUZZER WITH A PIECE OF CLOTH TO DAMPEN THE SOUND.GOODLUCK. MOHAMED
Posted on Sep 18, 2008
My Kenmore Oasis Top Load Washer has started beeping intermittently throughout the washing. I can no longer select loud or soft and when its beeping the light goes back and forth from soft to loud.
This symptom indicates a stuck key on the user interface control board.
Replacing this control board would most likely fix this type of problem.
The part number for the user interface for this model is 8564374.
You can order this part from www.SEARSPARTSDIRECT.com
The procedure for replacing this control board is shown in the images below.
NOTE: You should only attempt this procedure if you are completely confident in your technical ability to safely execute the process.
Follow electrical safety guidelines. Unplug the washer before accessing internal components.
Before buying any parts I suggest you access the interface ribbon and disconnect it and then connect it back and see if there is any improvement.
You might also remove the interface from the console and check the console for any stuck buttons.
Remember to unplug the washer first.
http://media.fotki.com/1_p,wkgbsdrbswtkdqwxgtqsskgwtqkq,vi/ksgtwdgrtxkrrffsdss/1/1303472/5961857/image29464img-or.jpg
http://media.fotki.com/1_p,sqrbbsbrrbwrbdtxgtqsskgwtqkq,vi/kbqtdwdswxkbswddwbg/1/1303472/5961857/image23056img-or.gif
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.*&^%$
Jun 16, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Cycle Signal keeps beeping loud-soft every 15 seconds while dryin
Hi Celine, I just experienced the same exact problem. I came here looking for a solution. I got mine to stop by holding down the cycle signal button for 3 seconds, releasing it for three seconds, and repeating until both lights (loud and soft) went off. Hope it helps.
peter
Apr 21, 2010 | Kenmore Elite Oasis 6808 Electric Dryer
Beeping noise all the time
OASIS...oh no. Known for electrical problems. In this case there's a short in the user interface board and must be replaced.
Mar 09, 2009 | Kenmore 24032\24036 Top Load Washer
Cycle Signal Volume beeps from loud to soft
This is a common and very well known problem with the Oasis. You will need to replace the operator interface board inside the control panel to resolve this issue. The board is located directly behind the control knob. If you post back with your model number, I can research a part number for you, give you info on where you can order a replacement, and give you guidance on how to replace the board yourself.
Feb 12, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Beeping dryer & broken hinge on the washer
1 Beep/E10--Error: Water doesn't enter Cause: Water supply problem, Check kinks and faucets
1 Beep/E10--Error: Water leaks Cause: Water connections loose,household drain clog,oversudsing. Correct problems.
1 Beep/E10--Error: Dispenser drawer is open Cause: Washer will not operate if drawer is open.
2 Beeps/E20--Error: Water dosen't drain. Cause: Drain is kinked or household clog. Correct.
3 Beeps/E30--Error: Drum overfilled. Cause: Inlet valve,pressure switch or control board failure.Select drain/spin to remove water. Restart.
4 Beeps/E40--Error: Door is open. Cause: Washer will not operate if door is open. Close door.
5 Beeps/E50--Error: Motor is overheated. Cause: Wait 30 minutes to cool down. Restart.
7 Beeps/E70--Error: Cold water doesn't enter. Cause: Hoses crossed,faucet problem.
15 Beeps/EF0--Error: Oversudsing. Cause: Too much detergent,or improper detergent for machine.
15 Beeps/EF0--Error: Hot water doesn't enter. Cause: Hoses crossed,faucet problem.
Jan 20, 2009 | Kenmore 24032\24036 Top Load Washer
Beeping
stuck key or bad control
Nov 09, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Disabling the beep on a Kenmore microwave
I have Kenmore microwave model 721.61820100.
It has an "Option" button. Press it. The display say "NUMBER"
Then press "1". The display should say "SOUND" and then "OFF".
Press "Start" and that beast turns silent, well not really, but the beeps are goooone.
If for some reason you don't like it this way repeat the sequence and the sound this time will turn "ON".
Jun 05, 2008 | Kenmore 80809 Microwave Oven
Loud/Soft signal
all i can figure is it is a strange method by kenmore to alert the user to throw in an antistatic cloth that gives softer clothes (clothes softener sheets)
May 25, 2007 | Kenmore 67052 Dryer
Kenmore Oasis HE 27082 Top Load Washer Logo
114 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
