Question about Kenmore Washing Machines
Washer starts fills w/water tumbles clothes for a few min. then stops and flashes f28.
I took the top and bottom panels off the washer, followed the wiring and vacume lines, and found a small hole in the vacume line. I replaced the vacume hose and started washing. Everything is working great.
Posted on Sep 19, 2008
Can you tell me what nf means
No fill error. The washer thinks it's taking too long to fill up with water
Dec 14, 2014 | Kenmore Elite 45986 Front Load Washer
It starts and then stops and then F28 flashes
http://www.ukwhitegoods.co.uk/help/fault-codes/laundry-fault-codes/3708-whirlpool-washing-machine-fault-codes.html
Not good! Probably motor control board or motor or wiring harness from control board to motor.
This leads to a Kenmore Video
Whirlpool, Maytag, Kenmore. Same machine different name different trim.
Whirlpool Duet f28 YouTube
Sep 21, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool WFW9050XW Washer Front Load
Disconnect your mains from the wall and clean out your filter.
Pl click if helped.
Apr 28, 2013 | Whirlpool Washing Machines
My washer is tumbling damped clothes but seems not to be acutally washing my clothes. whats going on? Just a bit water comes out for about 2 sec then stops but no water is actually in the drum just...
This is symptomatic of a malfunctioning water control valve- the hot water one, if the washer is hot and cold fill, and the cold one if it is just cold fill!
Sorry but it needs replacing and a service call to confirm that it is not something else ;-0(
Good luck,
John C
Apr 09, 2011 | Kenmore Front Load Washer
F28 error / water starts to fill then quits in 15 sec's
F28 is a communication error which usually means there is a connection that has come loose.Check the wires on the control board.
Nov 22, 2010 | Maytag EPIC MFW9700S Front Load Washer
Same problem
Power it off at the mains for 60 mins and then rety. If it still does the same then call in a repair man as it is most likely thatthe main controller board is faulty and needs replacing.
Sep 11, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Will not spin during any cycle w/ or w/out clothing inside
that sounds like something else, I had a similar problem yesterday, the washer would stop after a few mins, I traced the fault to the water hoses, it was plummed in with a hot water feed that can get dirty over time. this had blocked the inline fiter stopping water getting into the machine, if it does not fill within three minutes it can cancel, I cleaned the filter and was out in 10 minutes.
Apr 13, 2009 | Washing Machines
My washer doesn't get enough water in it to wash properally.There isn't a water level knob on the washer.Its a frontloading whirlpool.
There is most likely nothing wrong with the washer. Front load washers will only fill about 2 inches of water in the tub. As the load starts to tumble, water is absorbed into the clothes, causing the water level to drop. The machine senses this and adds more water. The process continues until the water level stabilizes. (thus no need for a water level switch) Your clothes should get wet, but you will little if any water. If you use a gentle cycle you will get slightly more water, as the washers tumble at the same speed for all cycles, but give a more gentile wash if there is more water in the drum.
Also,..... remember because you have so little water in a front load washer (compared to most all top loader models) you want to use only 1 to 2 (max) tablespoons of HE detergent per load!
Aug 27, 2008 | Washing Machines
We just had a flood in our basement and our Whirlpool Duet Sport HE front load washer is displaying F28 which I know means something electrical. Is there any way I can disengage the electronics to get the...
Unplug the machine. Remove the bottom access panel (three torx screws along the bottom). Reach up under the area where the door lock is and feel for a round door release mechanism. Pull down and the door will unlock
Jun 08, 2008 | Whirlpool Washing Machines
5E Washer - Won't Fill / F28 Error
check if hoses are reverse when installed
May 12, 2007 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
203 people viewed this question
Sal De GO PATS
fordexpert
Ed Mac
