Question about HP Office Equipment & Supplies
The message on the Hp Photosmart C5180 all in one. is "cannot print" replace the follloowing empty ink cartridge to resume printing (black triangel) I replaced the cartridge and the flashing light is flashing and will not reset or print. the message still remains.
    Sergeant:
  • 399 Answers
Try cleaning the brown dotted circuit of the printer where you fit your cartridge .clean it gently and slowly with moist tissue and wait for a moment till the moistness get completely dried.and also check whether you are changing the proper cartridge which the message is indicating.check the proper number on the cartridge which you replaced. also try changing the both the cartridges sometimes this helps.also check whether the cartridge is inserted properly in the printer sometimes it is fitted loose in the printer so this happens.
thanks.
Posted on Sep 18, 2008
HP 8250 Cannot Print - Printer Senses New Ink Cartridge as EMPTY
you need to have authentic hp cartridges,if you bought cheaper,it will not work.
Apr 23, 2017 | HP Photosmart 8250 InkJet Printer
My HP C5180 All-In-One printer says full ink cartridge is empty
Hi!
There are two ways to make your cartridge work again.
The first one will be basic....turn on the printer...remove the black cartridge from the printer.. using a moisten cloth, clean gently the contact terminal of the cartridge..after letting it air dry for a couple of seconds return the cartridge.. then try printing again..
The second one is to reset the ink cartridge.. how?
1. While your printer is on.. disconnect the usb cable from the back of your printer.
2. Remove the cartridges.
3. Wait until the message "Insert Cartridge" display on the control panel.
4. Disconnect the power cord from the back of the printer.
5. Wait for 60 seconds.
6. Plug the power cord at the back of the printer...If printer does not automatically on..press the "Power" button.
7. Reinsert the cartridge and close any open doors of the printer.
8. If prompted to Calibrate, do so..
9. Reconnect the usb at back of the printer...and try printing again..
After that you can print easily.
If you find this information helpful....Please rate this solution and vote on this on the YES below..thanks..
Jun 02, 2010 | HP Photosmart C5180 All-In-One InkJet...
My HP Photosmart C5180 printer keeps coming up with an error message 'Ink System Failure. Does anybody know what is needed to solve the problem.
The "Ink System Failure" error is causes by air in the ink feed tubes. We have a step by step guide purging the air from the feed tubes posted on our web site. Go to our site at: www.ccl-la.com, click on the printer repair link and then the HP link. Follow the steps and you should be back printing in no time at all.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Nov 01, 2009 | HP Photosmart C5180 All-In-One InkJet...
I have a printer HP c5180 all in one, only have black ink , not color, i dont want print in color . can I use the printer black and white (not color) only?
You can go into the print properties and set it to print black only, however if any of the color cartridges are empty the printer may not print until you replace whichever cartridge is empty.
Aug 22, 2009 | HP Photosmart C5180 All-In-One InkJet...
How can I print black only color cartridges are empty black is full . this is for HP photosmart C5180 all in one printer
sir when you chose the print option please select the settings button there in the color tab you can find this option that print with only black ink
alternative solution is that before you print please open the flap of the printer where the heads are and remove the color cartridge.. then print it will give you a warning saying that printing in reserve mode but ignore this warnings
Thnx and i hope this solves your problem
Jul 16, 2009 | HP Photosmart C5180 All-In-One InkJet...
How can I print Black only?
Hi
HP Inkjet printers work only if both the cartridges have ink unlike HP Laserjet printers.
If you want the printer to print only in black, Follow the steps
Start --->Control panel -- >Printers and faxes ---->Right click on the printer icon (HP c5100) select printing preferences.
Under printing prefences there u will see an option to print with black or print in gray scale.
Note:HP Inkjet printers like Photosmart C5180 will work only both the cartridges have ink.
Thanks
Riz
Jul 26, 2008 | HP Photosmart C5180 All-In-One InkJet...
How to continue printing is one color runs out?
Seriously...I've read all these reviews saying how the c5180 is so great, but I've had nothing but problems with it from day one, and have shelled out so much money fixing it.  Now I'm getting an 'ink expiration near' error, which is completely preventing me from doing anything.  I have a paper due tomorrow, and apparently I can't print it out now, a %$#@ing black and white document...bc MAGENTA is almost expired.  Can someone please tell me a way to override this so I can print my paper? >.>
Apr 09, 2008 | HP Photosmart C5180 All-In-One InkJet...
How do I reset the ink levels?
We have an issue of missing or replace yellow cartridge. Please feel free to contact the HP support for replacement of the printer, if the printer is in warranty status. HP would replace the printer.
Dec 29, 2007 | HP Photosmart C5180 All-In-One InkJet...
245 people viewed this question
Ben Johnson
