To Descale your Iron, use Scale Away, CDR, you can buy at the hardware. It will remove the deposits. After you get it descaled you need to use Distilled water that you buy at the grocery store in it. This will avoid it scaling again. Also, Vinegar and water, Citric Acid crystals, Usual dose 1 teaspoon per 200ml water works Pour it in just like the water and let it steam out, then repeat with water, steaming out over a rag, sheet or something.
you have to buy descaling detrgent and go to MENU in machine ,then to descaling -press enter and open the hot water knob.When the detergent in the water tank finish close the knob,fill the water tank with fresh water and prime all water htrouht hot water .
You can buy a descaling kit from your Coffee pod supplier, but I simply use a mix of half water and half white vinegar - run this through your machine and it will descale perfectly.
Depends on how many times you have used it, before descale light comes on. Might not be able to manual descale, read instructions. You can buy Descaler Solution from all Supermarkets, but if unit working OK, leave it for a few Months, and see what happens..
Hello, you can buy descaling tablets at your local Starbucks. There is also a liquid descaling solution (small bottles) you can buy anywhere.
At the moment I'm using Jura brand descaling tablets I purchased at Starbucks. For instructions on how to descale (quite simple really), see here on p-17 at:
I used to run vinigar and water thru my coffee maker to remove the **** vinigar is slightly acidic. make sure run just straight water thru it afterward to get rid of the taste.
You have to buy descaling tablets from miele. You turn the knob to program mode and keep pushing the enter button until you get to descaling. You put two descaling tablets into your water reservoir and replace into unit. Put containers under the steam valve and the hot water wand. Press enter. Turn steam valve al the way on. Keep an eye on the containers. The process takes about 30 to 40 minutes. The message will appear 'Descaling finished." Turn steam selector to O and press enter. Display will read "rinse machine, fill watertank. Fill tank and return to machine. Place empty containers beneath hot water dispenser and steam nozzle again and turn steam selector fully on. Allow water to run through system completely. When process is finished, display will read "Rinsing Finished." Turn steam selector to O and press enter Program selector is on Program Mode and display will read Descaling, Timrt, unit is no descaled and ready to use. Turn program selector to on.
