Question about Pentax Optio A10 Digital Camera
Cannot imprint date
I have camera Pentax Optio A10, but cannot imprint date on photo. How to solve the problem
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Pentax Master
  • 102,366 Answers
The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
Posted on Aug 25, 2012
  • kakima Aug 25, 2012
SOURCE: Pentax Optio A10 lcd replacement
I bought my parts from Pentax Imaging Co. for 59.73 + tax + shipping: Part Number 76650-0500 Tel 1 800 877 0155. I am willing to sell this lcd for 55+ ~ ($7 shipping in USA only) because I now have other problems with the camera. LCD is like new condition. (contact: magee.silas@gmail.com)
I pulled on the power wires to disconnect the LCD power supply and broke the black one at the connector. I was able to pull the old wire out of the connector and press the remaining section of wire into the connector securely and fix the mistake (use tweasers to prevent this).
As for the LCD information connector strip: Take all of the tape covering this connector off before proceeding because then you will be able to see and use the connector "gate". the gate pivots upward to allows you to place the connector strip in place then you can gently push the gate down to lock the connector strip in place. I tried sliding the connector in and it did not work. Instead it gave me a red screen. I did install my LCD, turned the camera on and it worked, Then...
After dissasembling the camera more that nessesary to be able to insert the menu board's connector strip back into place the camera failed to turn on. I have not found and dissconnected wires and suspect Electrical Shock Discharge for the failure.
If you try this procedure wear a grounding ******** your wrist, or take off the minimum nessessary to preform the work( backplate, sideplate near lense only). You do not need to remove the menu display panel to connect the lcd panel information strip, just remove the tape covering the connector.
Posted on Apr 20, 2008
  • 102366 Answers
SOURCE: what is the maximum size sd card for a Pentax
The A10 accepts SD cards, which max out at 2Gb. The 4Gb card is actually an SDHC (Secure Digital High Capacity) card, not an SD card, and thus will not work in devices designed for SD cards. Compatibility goes only one way--SD cards will work in SDHC devices but not the other way around.
Posted on Jan 07, 2010
  • 146 Answers
SOURCE: No date print on photo
This is how to print the photo with the date on.
Go to the playback mode and choose the photo to print.
Press the down arrow on controller.
The mode palette appears.
Use the controller to select DPOF.
Press the OK button.
Use the up/down arrows to select number of copies.
USE THE GREEN BUTTON TO SELECT DATE PRINT ON OR OFF!
Press the OK button to print.
Hope this helps, it is well hidden!
Posted on Feb 04, 2010
  • 25 Answers
SOURCE: Pentax Optio a10 turns off automatically after I turn it on
It sounds like you may have a bad lens assembly. If it is sticking, it will buzz. If it fails to open all the way, it will turn itself back off. This is what it sounds like you are saying. I can fix this for $40, or you can send it to Pentax in Arizona. I don't know what they charge for a lens assembly, but the minimum charge for this camera seems to be about $90. If you just want to get rid of this camera, I also buy all Pentax Option a10, a20, a30, a40 cameras.
Contact me at: mrfixitmark at comcast dot net
Posted on Jun 21, 2010
  • 25 Answers
SOURCE: pentax camera optio a10 won't retract
It sounds like you may have a bad lens assembly, or a bad main board. If it is sticking, it will buzz. If it fails to open or close all the way, it will turn itself back off. This is what it sounds like you are saying. I can fix this for $40, or you can send it to Pentax in Arizona. I don't know what they charge for a lens assembly, but the minimum charge for this camera seems to be about $90. If you just want to get rid of this camera, I also buy all Pentax Option a10, a20, a30, a40 cameras.
Can i take the date imprint off a picture after it has been taken
no you cannot edit the date imprint within the camera once its been clicked. you can just turn that setting off so that the date dosnt show up on the picture or change the date in your camera & click pictures again to your desired date
Apr 21, 2010 | Pentax Optio W80 Digital Camera
Storing my photos
Hello sir ,
U need the vists compatible drivers for it !!
Mar 16, 2008 | Pentax Optio A10 Digital Camera
Can the date be printed on the photos?
Hi, I found this on the Pentax website.
It looks like you cannot print the date directly from the camera but you can do it using other options.
q.gif How can I print the date on my pictures? a.gif You can print the date on your picture using a DPOF compatible printer or at a printing service or by using the provided software ACDSee for PENTAX.
Feb 01, 2010 | Pentax Optio S50 Digital Camera
Jan 07, 2010 | Pentax Optio S6 Digital Camera
Show date on picture
Aug 17, 2009 | Pentax Optio A10 Digital Camera
Pentax optio a10
Mar 24, 2009 | Pentax Optio E10 Digital Camera
Pentax a10
Ok here it is open the camera and re insert the fine lcd ribbon into is holder problem solved. Your camera must have had a sharp knock to dislodge the lcd screen and pulling out the ribbon. Worked for me.
Cheers
Feb 19, 2008 | Pentax Optio A10 Digital Camera
Pentax Optio A10 Digital Camera Logo
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Are you a Pentax Camera Expert? Answer questions, earn points and help others
