Question about Coleman Heating & Cooling
I am replacing the blower motor in my Coleman electric furnace. The original motor is a Westinghouse 230 volt single phase, single speed motor with a black and an orange lead. Both of these leads connect to "line". There is also a green ground lead that goes from the motor frame to ground. The Coleman number on the motor is 3400-313. I replaced the original motor with an AO Smith motor number 1468-120P. It is a two speed motor with four leads, and, of course, the green ground lead. The leads are red, (low speed) orange, (line) and two black leads. One black lead (high speed) goes to "line". My question is, where does the second black lead go? Does it go to ground, or remain un-used like the red low speed lead?When I hook up the orange lead and one of the black leads to each of the "line" inputs like the old single speed motor the new motor does not run. Thank you for any assistance you can provide.
  • RC17 Sep 18, 2008
    The nameplate reads-
    HP - 1/6
    PH - 1
    V - 230
    RPM - 1050
    SPD - 2
    A - 3.0
    CAP - MFD
    HRS - Air Over
    HZ -60
    FR - 42Y
    INS.40C
    VAC -Thermally Protected
    Red - Lo
    Black - Hi
    Orange - Line
    The nameplate also indicates that the red and black leads go to line. This leaves one black lead unaccounted for. The motor does not run when both black leads are hooked to line. This motor is the motor that is listed as the replacement for the original single speed motor.
  • TexNOz May 11, 2010
    Give me the "nameplate" data off the motor please. It almost sounds like you are replacing a shaded pole motor with a PSC motor and two of those lines are for the capacitor.
    Master:
  • 522 Answers
Look at the schematic. I've never seen 2 black line wires. Do not ground it! Schematic tells it all and will be on the motor. An electrician may know, but a HVAC tech is who I would call. By the description I found on line, it states Black wires are High sp., so its probably just 2 different ways to power high speed for different applications. So I would leave 1 black lead disconnected. Check amperage to be safe!
Posted on Mar 10, 2017
    Top Expert:
  • Coleman Master
  • 45,628 Answers
Get in an electrician but rest assured that if you connect the black wire ( neutral )to ground
you will dead short the motor and the house wiring
electricity is not in the providence of DIY legally
  • Coleman Master
  • 16,215 Answers
Take a meter to the line wires and be sure you have voltage. Could be the motor control circuit.
ranger25
  • 72 Answers
SOURCE: wiring diagram
The white wire is nuetral, if you are trying to make a shop fan or something like that then you hook it to the white wire which goes to the wide spade on the outlet. The black one which is the hot and goes to the smaller blade (looking at an outlet in the U.S. on the right hand side) on the plug and should be for one speed operation. The other three should be capped off if you use it this way. If not, then cap off the black on on the motor and run the hot wire on the plug through a three stage switch. To find what speed corresponds to what wire you have to check resistance to the white wire and the lower the resistance, the higher the speed and hook up to switch accordingly. Also, ground the case with a solderless ring connector under a mounting screw attached to the ground prong on plug. Hope this helps.
Posted on Jan 28, 2008
  • 3 Answers
SOURCE: Need connection diagram, AO Smith electric motor FDL 1056
red is low blue med black high
Posted on Feb 19, 2009
  • 96 Answers
SOURCE: Need connection diagram, AO Smith motor FDL 1056
Black is high , Blue is med. , red is low
pierre1811
  • 144 Answers
SOURCE: I have Bryant HRV and the motor has failed.
Wire nut and tape the blue and red wires they are not used.
Posted on Mar 06, 2009
meBNme
  • 334 Answers
SOURCE: I have a Trane XE1200
OK, locate the terminals on the capacitor marked "HERM"(Compressor lead), "FAN", and "COM".(common)
HERM and COM remian as they are.
The wire going to "FAN" (usually brown) will be placed on either terminal of the new capacitor. (This is the ((usually brown)) wire comming off of the fan motor.) An additional wire needs to be run from the other terminal of the new capacitor to the "COM" on the old capacior.
What you are doing is bypassing the fan side of the old capacitor but still using the compressor side of the old Cap.
The fan should have a wiring diagram on it to help identify the wires if there is no brown wire. The other two wires will be identified on the wiring diagram as well, but one typically goes to the contactor and the other to the board.
Posted on Sep 07, 2009
Wiring schematic for MTB217 cooper b line
I would suggest taking a closer look at the motor name plate. I am not familiar with a 120/240 three phase service. When I checked the web it shows: Voltage 115/230 (that is single phase), Max Amps 115 Volts = 19.2 Max Amps 230 Volts = 9.6 , Single Speed, Square Flange, RPM = 3450, Threaded Shaft, Frame = 48Y Used on the following models: Sta-Rite Max-E-Glas, Max-E-Glas II, Dura-Glas, Dura-Glas II, Dyna-Glas, Dyna-Max Pentair Whisperflow, Pinnacle and Anthony AR2 Series. You should also show what voltage you are connected to.
Mar 14, 2014 | A.O. Smith SQ1102 Pool Pump Motor
Electrical diagram for contactor (240 v/1 phase/24 v coil)
How to connect motor 1 phase with mcb , contactor , timer ,switch selector on off on , and lamp indicator
Feb 17, 2012 | Omega Trane Furnace Draft Inducer Blower...
My pool originally had a 2 speed AO Smith pump motor. Several years back it was replaced with an AO Smith single speed motor. I am replacing that motor with a new AO Smith single speed Centurion Switchless...
Is it going to run on 230V then? If so you would normally use red and black. The white wire should be a neutral and the ground wire is obviously ground.
Do you have a meter you can use to confirm the voltage between the wires? If you do you'll want to start with red and white since you seem to think black was not being used before. If the voltage reads 230 and the motor is set up for 230 then attach one wire to L1 and the other to L2...it will not matter which is connected where as long as one is on each terminal. Insulate the black and ground the ground lead to the motor ground screw.
If the voltage is not 230 between those two check between red and black. If that is the 230 then insulate white and put red and black to L1 and L2.
John
May 23, 2011 | AO Smith 2 hp 3450rpm 56C Frame 230 Volts...
Too change rotation of a 5hp 230 volt
HAVE A LOOK INSIDE THE MOTOR CONNECTION BOX. SOMETIMES ON THE LID ARE INSTRUCTIONS OF HOW TO DO THIS. YOU DID NOT SAY IF THIS WAS A CAPACITOR START UNIT OR NOT. IF THERE IS A CAPACITOR ON THERE IT COULD BE NO GOOD WHICH WILL MAKE THE MOTOR GO WHERE IT WANTS. A GOOD CAPACITOR KICKS IT IN THE RIGHT DIRECTION ON SWITCH ON.
Jul 25, 2010 | Air Tools & Compressors
Replaced a one speed 230volt 1 phase electric motor with a two speed 230 volt 1 phase electric motor, now have extra wires which color wires do you use or cap??
Look at the old motor and see what the rated rpm was. Next look at the new motor and see if it gives a speed for each wire. If it doesn't give the speed for each wire then look at the rated motor speed. That will be the Hi speed. Hook up the wire that matches the speed of the old motor and cap the other.
Jun 05, 2010 | Heating & Cooling
Is posible run a single phase electric motor from a source three phase 120/208 wye connection the motor is rated 230 volts AC
It is indeed possible to use ONE Phase to run a motor, You simply use One Phase and Neutral. BUT ONLY if the 3 phase is Double, more or less, the required usage Voltage, EG: 440 3 phase, will be OK, for 220 single phase, . But 220 3 Phase,will not run a 240. single Phase. So in your case is suspect not, it really will do no harm to try though. it just wouldn't work, if not enough "juice", be careful.
http://en.wikipedia.org/wiki/Three-phase_electric_power
Feb 24, 2010 | Heating & Cooling
How can i test the wiring on a single phase motor
Please restate question with more detail, Is it the motor or the generator?
Sep 07, 2009 | Electrical Supplies
I wish to rewire a single phase electric motor with compositor's that is currently setup for 230 VAC to 115 VAC. The motor is a Ingersoll-Rand Air Compressor motor with the following nomenclacher. Single...
The motor itself should have a sticker which describes the wiring for 115. It is a small change involving a single wire moving from one pole to another inside the motor starter cap (the bump on the motor itself).
Aug 26, 2009 | Air Tools & Compressors
Coleman furnace problem
Sometimes people replace the blower motors with a higher horse power. Has this motor ever been changed? I believe the original should be a GE motor
Nov 12, 2007 | Heating & Cooling
Heating & Cooling Logo
78 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
