Question about Refrigerators
On a standard frost-free fridge's lower section (main door) there is a funnel shaped type of cup on it's upper-back ceiling section that evacuates the overflow of water when the ''defrost timer'' goes on. the one I have to fix keeps overflowing inside the fridge not to say that it keeps freezing anything in that area (say a glass of water as a test). I've cleaned the outgoing drain hose as well as it's ''S'' plastic shaped section installed outside on the upper back of the fridg but, no succes achieved. Should I assume a defective defrost timer...Your help would be much appreciated. Thanks Gilles.
  • 943 Answers
Hi thanks for the question did you remove the funnel shaped piece cause thats where it builds up remove thst piece an clean thanks the appliance doc
Posted on Sep 18, 2008
I have a frost free refrigerator (MODEL #: FGTD 20V4GW2 and SERIAL #: ba00230071) yet the ice/frost builds up of the door, top and front of the freezer. Also the bottom compartment where the milks,...
if ice is on the door and ceiling and frozen water dropleats on the food packages the door was left open and the air ducts are frozen.when you open the freezer door do you hear the fan blowing,if not it could be bad or iced up,if the ice is on the inside back wall of the freezer you have a defrost problem,get back to me and tell me if the ice or like snow is just on the back wall or if the door was left open ice will be on ceiling ,door and shelves and food packages,also that's not a good model number if the freezer is on top look at the left wall up near the ceiling in the fridge section,you should see a tag there with the model number.
Sep 25, 2011 | Frigidaire 14.7 Cu. Ft. Top-Mount...
My freezer (upper) works but my fridge (lower) doesn't. There's nothing clogging the vent. What could be the problem? Thank u!
My fridge is running but not cold enough: Start out with the easy stuff first...make sure the lights go out when you close the door(s), make sure the doors are closing properly and the gaskets are closing fully and are not torn or ripped. Check to make sure the evaporator fan in the freezer is working, this fan blows the cold air around. If the fan is not working, possible bad fan motor - check for power to the f
The most common fridge "not cooling" problem is a frost free failure. Remove the access panel in the freezer section to expose the evaporator coils. If the coils in the freezer section get plugged up with frost, this frost will block the evaporator fan motor from blowing the cold air around. The fan blade can also hit this frost and either become noisy or stop altogether. Locating the defrost timer can be tricky....they are often hidden behind the back bottom corners of the fridge at the bottom, in the last few years the timers have been located in the ceiling of the fresh food section, and some are behind the cold control cover. Once you locate the defrost timer, slowly turn the screw likeknob in the middle of the defrost timer with a straight screwdriver until the fridge shuts off. You are now in defrost. If the defrost heater (s) comes on now, replace the defrost timer and defrost thermostat. If the heater(s) does not come on, you can continuity test the defrost heater for continuity or test for 120 volts to the heater(s). If you have no power to the defrost heater (s) you can also bypass the defrost thermostat to see if the defrost heater will come on, jumper the wires together to bypass the defrost thermostat. If the heater now comes on, replace the defrost timer and defrost thermostat. If the heater itself is bad, defrost the fridge with a hair dryer, replace the defrost heater (s) and defrost thermostat. If the defrost timer seems "hot" to the touch or is noisy ( like a ticking or screeching noise )...replace it.
bobicehouse_88.jpg Defrost timer
bobicehouse_89.jpg Defrost thermostat
bobicehouse_90.jpg Defrost heater
Sep 11, 2011 | Sharp Refrigerators
Freezer is cold, but refrigerator is warm. The fan is running, but I don't feel cold air coming into the refrigerator compartment. There did not appear to be a large amount of frost anywhere, but just...
If the freezer is cold the compressor is Ok. Now if its a two door fridge . Open both the doors while the fridge is On. Press the lower door switch ( the lower light should turn off and you should hear the fan humming sound come on ). While holding the door switch pressed close the freezer door, you should see cold air come out of the slits in the back of the lower compartment. If not icicles have blocked the passages due to the non working of the heating coil.The heating cycle is controlled by the timer switch located near the compressor at the back. Unplug the fridge and remove the timer switch.Note the color of the wires and mark on the old switch. Replace and it will work.Only frost free fridges have heating cycle
Mar 07, 2011 | Refrigerators
Water collects under my refrigrator overnight resulting in a puddle in the morning
Check to find out if the water is coming from inside the fridge. If it is then open the fridge door, locate the dial which moderates the temperature located on the 'ceiling' of the fridge. Remove the light cover, remove the globe. Unscrew the two screws which hold the dial housing to the ceiling of the fridge, let this housing hang from the ceiling in the wires. This will expose a red funnel shaped tray, gently lift the tray and pull it out, you will most likely find the tray drain is blocked with gunk, clean and reinstall. Assembly is reverse of removal. If it is coming from the back of the fridge check that the plastic container mounted on top of the compressor has not got a hole in it, and check that the internal drain is dripping into it
Jan 08, 2011 | Frigidaire Refrigerators
Water is leaking from the inside.
This is the solution to a the same problem in a Westinghouse Freestyle refrigerator which is probably similar in principle. Basically the internal drainage system from the freezer is blocked. Open the fridge door, locate the dial which moderates the temperature located on the 'ceiling' of the fridge. Remove the light cover, remove the globe. Unscrew the two screws which hold the dial housing to the ceiling of the fridge, let this housing hang from the ceiling in the wires. This will expose a red funnel shaped tray, gently lift the tray and pull it out, you will most likely find the tray drain is blocked with gunk, clean and reinstall. Assembly is reverse of removal.
Jan 08, 2011 | Haier Refrigerators
Water is leaking into my fridge from defrost.
Most times this is a plugged defrost drain system. The defrost heater in the freezer section melts the frost and changes it to water, this water is suppose to flow down a drain system. If this drain system is restricted or plugged the water will leak inside the refrigerator. The drain system starts in the freezer section with a tray built under the evaporator coil. The water is funneled through a small hose into a cup in the top middle of the fresh food section ( not on all models, but this is the most common way ), from there, the water is directed out the back wall to a drain hose that runs down the back of the refrigerator into a condensing tray. The heat created under the fridge makes the water evaporate and disappear. Some of the cups ( in the top back of the fresh food section ) can be removed for cleaning. A turkey baster can be used to help clean out the drain system. Fill the baster with hot water and "blast" it into the drain hose to help flush it out. A piece of wire or pipe cleaner can also be pushed into the drain hoses to help clean then out. On a S x S style of fridge the drain system is in the bottom back of the freezer section and often you will have to remove the evaporator cover to access the drain hole. You can clean this out in the same manner as previously mentioned, but because of the water leaking into the freezer instead of the fresh food section you will have to remove the ice build up to clean out the drain system.
If in case the water is leaking on the floor then:--
There are several things to check for. The condensing defrost tray under the fridge can crack or develop a hole and leak onto the floor. A door gasket not closing properly may cause sweating and leak onto the floor. If your fridge has developed a frost free failure problem, often the frost will travel down the suction line at the back of the fridge and drip water on the floor. The heat exchanger tubing can separate and also sweat and drip on the floor. Ice maker and chilled water fill lines can crack and leak as well, this is fairly common with the plastic lines as they can dry out and crack.
Unplug the unit from main power outlet and empty whole unit and keep both the doors open and then connect the power after 24 hours and recheck.This procedure is called manual defrost reset.If this helps then its OK,but if this procedure not helping then its the faulty defrost unit and it needs to be replaced.
You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 30, 2010 | GE Refrigerators
I have a westinghouse freestyle fridge and it is leaking water seem to be coming from behind the tempreature adjusting knob. Do you have any suggestions. Thanks Michael model RJ452T-R
Nov 03, 2009 | Westinghouse Refrigerators
There is water dripping filling up the bottom under the salad container. The model is a LRTN22311TT.
Remove contents of fridge and check the drain line running down the top back of the back of fridge and follow to lower section of fridge (usually a back ledge or under the crisper sections) and locate a small round drain hole. Also, check to see that the drain collector (funnel looking thing at top back of fridge section) is located under the freezer defrost drain opening, to allow water to flow through the fridge into the drain pan under the fridge.
If something has obstructed the drain funnel, path, tube, or lower drain hole, remove the blockage to allow water to drain into underneath of fridge into drain pan for proper evaporation of water produced from the usual daily defrost cycle of fridge/freezer.
If that is not the problem, it could be that you have a leaking water supply line for your ice maker and you'll need to see if the freezer is allowing excessive water to flow out of the ice maker into the fridge section.
Another simple check/solution is that the fridge is not properly leveled, meaning that the front of the fridge should be slightly higher than the rear to allow for proper drainage and self closing of the front doors. This will help keep the water flowing in the built in channels and drains.
A perfectly level fridge isn't the right way to install most moveable refridgerators, while built in fridges (Sub Zero, etc.) are designed for plumb and level installations for proper functioning and use.
Apr 09, 2009 | LG LRTBC1825T Top Freezer Refrigerator
Whirlpool gold:upper half of refridgerator side not cold
Either the evap fan has a problem, or the defrost system has failed. You should never see frost in the freezer section as the defrost sensor should sense that the coils need to be defrosted before that much frost accumulates.
Unplugging to clean out helped because the frost got a chance to melt away.
If you find the evap motor is running, then the things to check are the defrost sensor, the defrost timer, and the defrost heater.
Reply back if you would like more info.
Jan 27, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerators Logo
57 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Richard Roth
Richard Roth
