Question about Toshiba Satellite A135-S4527 Notebook
Sir myheadphone and microphone jack is not working
  • vinod1077 Sep 18, 2008
    my headphone and microphone jack is not working
    Brigadier General:
  • 6,966 Answers
I am assuming that the internal speaker (and microphone if present) is/are working. If so then it could possibly be:
  • the jacks themselves; and/or
  • the wiring.
  • alternately, the plugs might just be inserted in the wrong jack, pls verify.
If the internal speakers work, then presumably the drivers/software are correctly installed making this a hardware problem. This of course would require a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Sep 18, 2008
    Scholar:
  • 65 Answers
1. Try the headphones and mic on another pc.
Make sure it's connected to the correct slot on the pc. Try them all when in doubt.
2. Go to start > control panel > open the realtek sound effect manager and go through the tabs
making sure nothing is muted. In the Audio I/O tab have the 7.1 speaker in the drop down selected so that all inputs are enabled.
3. Also in control panel make sure that in sounds and audio devices nothing is muted. Make sure the appropriate devices are selected in the Audio Tab and Voice Tab.
4. Make sure the drivers are up to date.
Here is the link for the drivers for Windows Vista. http://www.csd.toshiba.com/cgi-bin/tais/su/su_sc_dtlViewDL.jsp?soid=1603902&moid=1700045&rpn=PSAD0U&BV_SessionID=@@@@1427126072.1221710733@@@@&BV_EngineID=cccjadefejgdgeecgfkceghdgngdgmn.0&ct=DL&all_docs=false
If you've downgraded to Windows XP, it will not work.
6. Check the Device Manager. Right-Click on computer > properties > hardware tab > device manager
Make sure there are no yellow bangs. Find the realtech audio device and uninstall the driver, reboot and the computer will find it and reinstall it.
7. If you have downgraded to Windows XP this forum link tells where to get the drivers to get things working. http://forum.notebookreview.com/showthread.php?t=129243
    Genius:
  • 1,011 Answers
Sir,
Check if your micro (pink) and speaker (lime) jacks are really correct and fully inserted!
They sometimes stuck.
For test only you can use earphone instead of microphone for Line In.
Standard micro in Line In will NOT work.
Go to:
Start
Programs
Accessories
Entertainment or go to
Volume Control; right click on loudspeaker icon in Task Tray
Options
Microphone
Scroll down
Check "Microphone"
If the bar "Microphone" is available, the microphone is detected by Windows now go on
(If not, Windows has a problem with your microphone)
Just to check if your microphone is broken or bad, you can use your headphones instead. They really work!
Which one L or R is microphone now, I think it's L
Check "Advanced properties"
Check Micro "Advanced"
Open
Check "20db boost" or "1.MIC boost" depending on language version
Volume level can be left in any position.
Mute microphone!!!
3. Check audio now on windows base.
Start
Programs
Accessories
Entertainment
Soundrecorder
Else try.....
You need to add the headphones in the preferences. When you do that check the box to enable the headphone jack. The thing now with my laptop is that when I have the headphones plugged in the speakers work at the same time. I would really like to find a way to listen with headphones and not have the speakers on.
thanks
good luck
    Scholar:
  • 135 Answers
Test your headset on a different computer to check if it is working. If your headset is good the issue is with the laptop.
Plug in your headset on the computer, right click on the speaker icon beside clock, select recording devices, highlight microphone, select configure, click on set up microphone then choose headset microphone. Click next and next, your laptop will auto adjust on the headset. Just follow the wizard.
Hope this helps.
  • Toshiba Master
  • 6,487 Answers
Make sure soundcard is installed properly under device manager, if still have the same problem you may need to replace the sound card of the computer..
Hope that helps........
    Master:
  • 726 Answers
Uninstall the sound card and reinstall it if u don't have one download here http://www.toshiba.com/tai/
thankyou
    Sergeant:
  • 300 Answers
Www.toshiba.com , I'd go there and reload the sound driver in case it's missing or went corrupt.
Az.
  • 37 Answers
Try to check if you can see it on device manager(control panel > device manager) see if there is a yellow exclamation point, if there is then try reinstalling the driver if you cant see it then definitely you need to replace your motherboard if your sound card is integrated or you might aswell buy another sound card which is cheap nowadays
  • 4,472 Answers
Have the jacks ever worked? How long have you owned the laptop? Once I have more information I can assist you properly.
Thanks,
Lee
  • Lee A.
    Lee A. Sep 18, 2008
    First of all make sure you have no conflicts in device manager. Also you will want to go to your sound properties(the little speaker in the right hand corner of the taskbar). If you go to properties make sure your line in and everything else has a check mark and is turned up. If you still need assistance let me know. If you have a moment to accept and rate my solution accordingly it would be greatly appreciated as i strive to provide fast, accurate, and economical solutions.
    Thanks,
    Lee
  • Lee A.
    Lee A. Sep 18, 2008
    http://www.laptops-drivers.com/toshiba-d...
    You can get all the drivers for your system from that page. The realtek drivers for your sound card are also there if you need to uninstall and reinstall the drivers.
    Thanks,
    Lee
Sony Handycam ux10/ux20. Why isn't it recording audio?
sir,
please use an external microphone and test, if there any corrosion or dust inside the mic jack, it will cause to dis recording of audio, use some cleaner liquid in the jack, still the problem persist, must open the unit and check the audio circuit with test equipment like oscilloscope.
Feb 01, 2016 | Sony Video Cameras
My head phone works very good but the microphone doesn't work
When you say headphones do you mean the music headphones, like speakers, because they go in the headphone jack in the computer while microphones go in the microphone jack. The microphone is normally a pink color and the headphone jack is normally green. If you already knew this try wiggling the microphone to see if there is a brake in the wire, if that dose not make it fissile in and out then its something wrong with the microphone its self and should be replaced
May 03, 2011 | Logitech (980240-0403) Microphone
How to connect mike in computer
  • Look for the sound card on the back of the computer. This will have a 15-pin connector and several colored jacks.
  • Locate the microphone jack. Although some manufacturers will stray from the norm, the microphone jack is typically colored red or pink and/or will probably have a picture of a microphone.
  • Connect the microphone into the jack.
  • Click "Start," then click "Control Panel," then click "Hardware and Sound," then click "Manage Audio Devices" under the "Sound" category. This opens the "Sound" window.
  • Click the "Recording" tab. Here you will see a picture of a microphone. To the right of the picture should be a sound bar.
  • Test the microphone by speaking into it. If the sound bar lights up, then the microphone is plugged in correctly and ready to use. If the sound bar remains gray, then there is no signal. Try another jack on your sound card and repeat the steps to test your microphone. If you still can't get the microphone to work review your computer documentation or contact the manufacturer's technical support.
  • Mar 08, 2011 | Acer Aspire X1200 Desktop PC - Athlon X2...
    Can i work this mic with my computer?
    Yes. You should be able to plug it in it your microphone jack. First, find the mic jack. it should be located right next to the headphone jack. Open your sound dialog. You can find it by right-clicking the volume control and selecting recording devices. Look for your microphone in the dialog. It should have a green tick on it. If it doesn't, select it and click "Set Default". (note: your microphone may not show as a separate entity. if not, select your default microphone and test it by speaking into the MV29. The level should change)somervta.jpg
    Jan 20, 2011 | JVC MV29 Dynamic Microphone (MV 29, MV-29)...
    I have connected the speakers to the red jack plug at the back of the tower but no sound
    sorry sir, speakers must be connected to the green jack. red jack is for microphone. Let me know how you go either way....cheers from narayanan
    Dec 04, 2010 | Sony VAIO PCV-RS320 PC Desktop
    Nokia 3230 microphone ways problem
    please give mic ways for nokia 3230
    May 14, 2010 | Nokia 3230
    Computer Does Not Detect Headset Microphone
    Sound and Recording jacks stop working on the DV6000 series due to the ribbon cable running under the power button. when the power button is pushed it bends the flex cable and over time it breaks the connection rendering the front jacks useless you can buy a new upper button panel for about 20 dollars on ebay
    Aug 02, 2009 | HP Pavilion dv6000z Notebook
    Microphone doesn't work
    the jack of your pc has a hardware fault ,so it is not accepting the microphone.
    Oct 26, 2008 | ASUS M2NPV-VM Motherboard
    Jack for the external microphone
    There is an error in the MobilePro 900 manual (Pages 2-2 and 2-3). The jack on the front of the MobilePro 900 is a stereo headphone jack only. The MobilePro 900 has a built in microphone. There is no jack for attaching an external microphone.
    Sep 14, 2005 | NEC MobilePro 900 Handheld
    Toshiba Satellite A135-S4527 Notebook Logo
    266 people viewed this question
    Top Toshiba Computers & Internet Experts
    Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
