Question about Kenmore 75050 Wall/Window Air Conditioner
No water When I first got my ac i could see water coming from the back and hear it when i shut it off. I've had the unit about two months and do not see any water coming from the back or do i hear it when i turn it off. Is this normal and will my unit need repair if this water is not there. Weather is hot.
  • afflofh Sep 18, 2008
    This feedback is useful to know. I'll be checking for humidity in the air and see if it makes a differents. Also check for some water dripping. Thank you for your help.
    Problem Solver:
  • 15 Answers
That water is condensate that is removed from the air. If the humidity is low, you will notice much less water coming from the condensate drain line. I would expect to see some water though.
If the unit doesn't seem to cool as well as it did, then chances are it has a leak and has lost its refrigerant charge.
Posted on Sep 18, 2008
Not cooling room and every 45 seconds it makes a hum noise
window unit ac !! not a fridge . the hum you hear is the ac compressor trying to come on , but due to loss of gas charge it shuts right off again , this will require a professional ac repairman to fix this , 1st he needs to find leak then repair leak then add back lost gas charge , watch cost of all these services vs cost of entire new unit , it could get expensive
Jun 24, 2015 | Refrigerators
Why won't my compressor on my dometic not come on?
It really makes no difference what the AC unit is in, it's still AC. I've come across this situation many times, and found that unit is just low on Freon. Once, and only once, I hound a loose thermostat connection at the unit, so the compressor didn't know it was supposed to come on. Nonetheless, Check the connection AT the unit. If good, you'll have to get an AC man to recharge it because the charge line end is soldered shut. IF by chance there IS a fitting with a plastic cap on it, like on your tire fill, get a recharge kit with connecting line and recharge it with ONE canister of Freon. Get the kit from auto parts distributor, remove the plastic cap from the AC charge line, open the piercing valve on the kit line and connect to the can. DON"T pierce the top yet. Connect the other end to the AC charge line finger tight, now pierce the top of the canister with the T-handle/knob AFTER starting the AC to suck the Freon into the system and screw the piercing pin back out part way to release the Freon. NOTE: To get all the stuff out of the canister, stick the canister into a bucket of hot water you took up with you. Once the canister is empty, remove the kit line from the charge line, trash the empty, hide the kit line somewhere in case needed again(won't have to buy another kit, just Freon bottles), put the unit cover back on and stay cool.
Aug 17, 2014 | Dometic Rooftop RV Air Conditioner
Haier portable AC water collection tank full in one hour.
My unit was working fine for a couple years but now it won't evaporate. It still cools fine but it also collects about 16 ounces of water every hour and then shuts itself off until I drain it. I'm wondering it the evaporative mechanism it broken some how.
Jul 24, 2013 | Haier CPN12XH9 Portable Air Conditioner
Dear Sir,I have an Amana Distinction 2.0 Ton heat pump, SEER 14 installed in my department about 4 months ago. I've noticed that the AC has a regular pattern running in the on/off cycle and that i
You need a tech. All 14 seer units have an X13 motor which speeds up and down on start up. A tech will adjust your tstat programing. Fan stays on after unit is done cooling to help drain water in cooling and cool off heat strips in heating,
Jun 15, 2013 | Heating & Cooling
The indoor unit of my 1.5 T , 2 yr old split ac is making noise like cracking of ice or plastic whenever the compressor is tripped or restarted. I've noticed water leakage (splash) from indoor un
indicates dirty evaporator fins that are icing up
that will overload the compressor and trip it
the ni oise you hear is the ice breaking up and the splashing is excessive water in the blocked drain that cannot run outside
get in a technician to clean and service the ac
Nov 24, 2017 | Heating & Cooling
Sharp Air Conditioner Model AF-G501CM
if it is cooling properly I would not worry about it.AC unit should sweat if it is hot outside but depends on the humidity level.usually if it is real hot and it is not sweating it is low in freon.
Apr 22, 2012 | Heating & Cooling
I have a goodman gsc13 ac unit about 4 year old. When the temp gets around 90 or above outside the fan on the unit starts but the compressor does not. I had service check it out but that day they were...
It sounds like the unit may be over charged. Make sure the outside coils are clean and you have plenty of airflow coming out of the top of the outside unit. What could be happening is, when the temps get higher outside, so do the pressures in the system. The compressor has a thermal overload protection that will kick the compressor off if it gets to hot, which if the compressor is over charged, it will work twice as hard, over heat and shut off. You would need a technician to come out and get the refrigerant charge back to normal. Another thing that could be happening is a weak or faulty capacitor, which is a small round or oval metal object, found in the electrical compartment on the unit. This are fairly simple to change out if your comfortable with electric. I've also had to put what's called a hard start kit on compressors with the same problem, new and old. The hard start basically gives it that extra boost of power to get it up and going. I would start with the refrigerant charge and go from there. The electrical "humming" sound that you hear unless you turn the breaker to the furnace off, is the contactor on the outside unit having a call for cooling. The 24 volts come from the furnace, to the outside unit, and pulls the contactor in to power the unit with the 220 volts supplied. It is normal and you don't have to worry about that at all. I hope some of this helps and good luck!
Jul 05, 2011 | Heating & Cooling
My duo therm roof top camper air conditioner just shut off and will not come back on. Can hear a click when turning on now but nothing else. Note that heater will not come one either.
The click that you are hearing is the relay control board in the rooftop unit. This means that you are getting 12V to the board. It sounds like you are not getting 120V to the AC unit. Check the breakers in the breaker panel to make sure they are OK. If they are fine, then turn off the AC for 5 to 10 minutes and try again. There is a thermal protection device in the unit that prevents you from turning it right back on after a shut down. Try putting the thermostat to fan only operation. If the fan does not come on in fan only mode, then you have thrown a breaker.
Hope this helps,
Jun 27, 2009 | Dometic Rooftop RV Air Conditioner
Kenmore 75050 Wall/Window Air Conditioner Logo
266 people viewed this question
Top Kenmore Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
