Question about RCA D52W136D 52 in. TV/DVD Combo
Green looks brown
I am having trouble with my color on my RCA D52W136D. the color green is gone. when i watch football, the turf isnt green, and when i watch baseball and the grass is as brown as the dirt on the infield. what can i do to solve this problem. thanks for your time.
    Master:
  • 505 Answers
Maby its not tuned in the channel right
maby its the way the picture is
or try
turning the tv of for 40 minutes by the power point and back on that way it will reset all picture - and should go back to normal please let me now how this goes's
Make sure you un plugged it by the power point
Posted on Sep 18, 2008
Projection is messing up. Too much red and blue color.
A CRT projector requires Convergence and Color balance adjustments from time to time. These settings can drift. What you are seeing is a lack of Green color intensity. Do you see some pink in the 'whites'?
The Green CRT surface also burns off faster than the Red and Blue leaving behind the same appearance. As long as your Green CRT is not too burned by gaming or watching Golf and football, a local tv tech will be able to dial it in for you.
Jan 07, 2010 | RCA HD52W56 52" Rear Projection HDTV
Se ve doble en todos los canales como que los colores se hayan mesclado el modelo 904341172
Resolder the connections on the hv transformer. Check and replace the pico fuse beside the transformer. It looks like a little brown box. The middle one is the one. There are 3 together there. 400 ma is the value.
Nov 21, 2009 | RCA D52W136D 52 in. TV/DVD Combo
RCA D52W136D 52 inch has no green.
most likely its the Green CRt drive board you should be able to get a new CRT Drive board for about 30.00 at the following link. www.tvrepairworld.com
Aug 14, 2009 | Televison & Video
Wiring on a RCA RJ-45 wall jack
the RJ45 wallplate is not meant for ethernet. It's an 8P8C connector for a phone. Will it work as a network jack? Maybe. I wouldn't use it, but if you really want to try, wire it thusly:
1 Blue --- Orange/White
2 Orange --- Orange
3 Black --- Green/White
4 Red --- Blue
5 Green --- Blue/White
6 Yellow --- Green
7 Brown --- Brown/White
8 White --- Brown
I'd still recommend a CAT5 wallplate with a CAT5 jack.
Apr 11, 2009 | Computers & Internet
The sound went out while watching a program on the set.
It sounds like the IC that controls the sounds has gone. Once upon a time they used to start with the letters TDA and other sets of letters that would make them instantly recognizable but nowadays it could start with anything so unless you know what you are looking for call out a technician. Good luck.
Sep 28, 2008 | RCA D52W136D 52 in. TV/DVD Combo
Hello sjustinh,
It sounds like your color processor may have gone bad or at least the circuitry connected to it. To solve this problem you will need a schematic, a digital storage oscilloscope, a signal generator, and a multimeter. Now if you don't know what these devices are and do not have a background in electronics, I would suggest that you take the TV set to a qualified TV repair person. I am not trying to put you down or anything its just that this problem requires that you open up the set and using the schematic trace down the signals that control the LCD screen and find out the condition of the signals that display green. Since green is the result of the algebraic addition of red and blue, you may have a problem in the circuitry that controls that function.
I hope this helps,
Thank you,
Shuttle83
Sep 18, 2008 | RCA D52W136D 52 in. TV/DVD Combo
RCA HDLP 50W151 scenium color wheel
They make two different color wheels for the Rca DLP are you positive you got the right one. As usually its a straight forward install no adjusting needed. Post the chassis number off the back of your set and I will try to help you out with it.
Apr 07, 2008 | RCA HD61LPW42 61" Rear Projection HDTV
TV RCA SCENIUM D52W136D 52in
Problem solved, it was my green driver this time and only $25 to replace.
Jan 16, 2008 | RCA D52W136D 52 in. TV/DVD Combo
RCA 56" Rear Projection Television
Not sure if you have the same problem I have but my colors are all off too.  I have a 52" projection and from calling RCA with my problem (colors off & have shadows) they said all projection tv's color need to be adjusted every so often (which they do not tell you) after purchasing this tv for $1000.00 13 mos ago I have the same problem.  It will be approx. 500.00 to fix the problem and I got no where with the RCA 800 number.  A friend of mine had the same problem so I am sure its the same.  Good Luck!
Oct 21, 2007 | RCA HD52W59 HDTV Projection Television
RCA D52W136D 52 in. TV/DVD Combo Logo
105 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
