Question about NetGear WGR614 Wireless Router
Setup netgear I have set up my netgear now it is asking for a passphrase can i change from securityenabled to nonsecurity ntwork
  • Anonymous Sep 19, 2008
    no wpakey
  • 6,487 Answers
Yes you can disable the wireless security from the router follow this;
Open up a web browser and type http://192.168.0.1. If prompted for a username and password the defaults are:
User Name: admin
Password: password
Once in the setup utility go to the “Wireless” tab then on the wireless part you can disable the security of the router..
Hope that helps...........
Posted on Sep 18, 2008
Change username
1. Open your web browser and type in your router's IP address. The default IP address for Netgear routers is http://192.168.2.1.
2. Enter your username and password once prompted by your web browser. The default username and password for Netgear routers are admin and 1234 respectively.
3. Select "Set Password" from the left hand navigation menu on the router's manager menu.
4. Type in the old password, which should be 1234 if it is set to default and then type your new password twice.
5. Click "Apply" and the new password will take effect immediately.
Nov 05, 2013 | NetGear FR114P Router
Passphrase or code to set up netgear router
It sounds like you are setting up or getting into a Workgroup and not a router configuration. To set up your netgear router would not ask you for a passhprase for mshome unless you set the router's SSID to be mshome. Normally the router's SSID will be Netgear or Default unless you changed. During setup you should go into the router's wireless configuration and change the SSID to something such as Your Last Name (ex. Smith_Network) and then set a password under security. If I were you at first I would not set a password. You can always log back into the router and set the password for wireless security later. Just make sure you can see your network SSID from the laptop and try connecting. If it connects then you can go back and set the wireless security.
Mar 19, 2012 | Toshiba Computers & Internet
I want to put a pasword on my netgear to stop people using my internet its unsecure at the moment
1. Use an ethernet cable to connect a computer to any one of the four LAN ports of the NETGEAR router.
2. In a web browser, enter the router's IP address - either http://192.168.0.1 or http://192.168.1.1 by default.
3. When prompted for a Username and Password, enter the default username and password (admin; password) unless you have already changed it. NETGEAR recommends changing the default password to increase the security of your network.
4. Select Wireless Settings from the Setup menu in the left-hand navigation bar.
Under SSID Name, Give a Unique name for Wireless N/w
5. Under Security Options, select WPA-PSK (Wi-Fi Protected Access Pre-Shared Key).
6. Under Security Encryption (WPA-PSK) > Passphrase, enter a passphrase.
7. * The passphrase may either be a string of 64 hexidecimal digits, or word/phrase of 8-63 ASCII characters.
* SAVE or KEEP NOTE of the passphrase - it will be required to connect wirelessly to your network.
8. Click Apply to save your settings.
9. Scan and Connect to your Wireless N/w on your Wireless Computer with your Password
Oct 01, 2010 | NetGear WIRELESS-G WGR614 802.11G WIRELESS...
I am trying to connect another computer to my wireless network but i do not know my netgear code, where do i find this?
Netgear code? Can you be more specific?
Are you referring to the password required to connect to your wireless network called "Netgear"? I assume you're being asked for a password on the 2nd computer when trying to connect to the wireless network called "Netgear".
  1. In a web browser, enter the router's IP address - either http://192.168.0.1 or http://192.168.1.1 by default.
  2. When prompted for a Username and Password, enter the default username and password (admin; password) unless you have already changed it. NETGEAR recommends changing the default password to increase the security of your network.
  3. Select Wireless Settings from the Setup menu in the left-hand navigation bar.
  4. Under Wireless Network, enter your desired network name in the Name (SSID) box. This is currently set to "Netgear" most likely.
  5. Under Security Options, select WPA-PSK [TKIP] + WPA2-PSK [AES].
  6. Under Security Options (WPA-PSK + WPA2-PSK), enter your desired network password into the Passphrase box.
    • WRITE DOWN or KEEP NOTE of your network name, security option and passphrase - you will require them to connect wireless computers and devices to your network.
  7. Click Apply to save the settings.
Once you've set this password, you can use it to connect to "Netgear" on your second computer.
Jul 25, 2010 | NetGear WGR614 Wireless Router
WGT624 Wireless Router: how to reset the passphrase. I can not access the...
Use a wired computer to access the setup page of the router.
In the address bar of a web browser, type 192.168.1.1 or www.routerlogin.net.
By default, the username is admin. Password is password.
Once on the setup page, go to Wireless Settings. You will see the passphrase and network key on this page.
I hope this helps!
May 15, 2010 | NetGear WGT624 Wireless Router
Can't get my passphrase to open netgear wireless
  • log in to the netgear router's interface using www.routerlogin.com
  • username- admin , password : password
  • Click on wireless settings under setup . ( 3rd option from the top )
  • Under the security options .
  • U can find ur security passphrase to connect with netgear wireless.
In case of further assistance , do revert back
May 09, 2010 | NetGear WG111V2 Wireless Adapter
Lost password for netgear router wnb834b
Most of the NETGEAR devices, except ReadyNAS products and Fully Managed switches, have the following default username and password:
  • Username = admin
  • Password = password
    • For older devices, password = 1234
If you have changed the default password and have forgotten it, you will need to reset the NETGEAR device to factory default settings in order to use the default username and password. Click here to learn how to reset the NETGEAR device to factory default settings. Please note: restoring a device to its factory default settings will erase any changes you have saved to the device.
Apr 20, 2010 | NetGear RangeMax NEXT WNR834B Wireless...
I setup a netgear wireless router and once i try connecting thru a laptop using wireless connection it asks for the passphrase but once i put it in it says its invalid, why if thats the right passphrase??
what is the Operating system on the laptop ?
Sometimes on Windows 7 it will not accept the network key?
You will need rto change the security type to WPA
Change the wireless channel to 6.
try to change the SSID also.
then try to connect to the new network and see if that works.
You will need to open the set up page of the router.
click here for more info about routers and network
Jan 12, 2010 | NetGear WGR614 Router
I want to setup a wireless connection
To set up wireless connection, first you will need to access the router set up. yhen change the wireless settings on the computer.
Secure the wireless network and then try to connect to the wireless network ?
Click Here for step by step info
Nov 22, 2009 | NetGear WGR614 Router
Netgear Wireless router logon problems
You probably typed in the router password instead of the Wireless password. Connect your PC to the router via a network cable type in your web bvrowser 192.168.1.1 , login to the router and in the Wireless security section change the passphrase to something and write it down then try re-connecting via wireless after unconnecting the net cable
Aug 09, 2009 | NetGear WNR2000 Wireless Router
NetGear WGR614 Wireless Router Logo
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
